Old 06-04-2003, 01:32 PM
Brian Baker's Avatar
When installing the remote setup, did you eliminate the factory filter housing? If so, you cannot conclusively say the problem was with the filter(s).
  #42
Old 06-04-2003, 01:51 PM
GTO's Avatar
GTO GTO is offline
I did eliminate the housing but there is nothing in it! The passages are all open and you can clearly see this. When the first filter went bad I replaced it with an HP2 on that housing. This brought my pressure back and everything was OK. I went for a ride and when I came back I changed the oil and installed another HP2. When I fired the motor I had no pressure whatsoever! I shut her down and did a visual check and found nothing so I thought that maybe it took a while to come up to pressure because you can't get 2 bad filters in a row right? Well I fired the motor and still nothing. Changed gage, still nothing. Had I found my remote setup I would have solved it last night! Brian I am POSITIVE that the filters are at fault! I will be sending them to Fram for inspection and hopefully they will be honest! I want nothing from them! I might just cut them open myself to see what the problem was. Hey, come up for a beer and some Black Bear wrestling and you can help me inspect them! ... Eric
Runner Up Q16 Norwalk 2013!
  #43
Old 06-04-2003, 02:33 PM
Black Bear wrestling? I'll pass. Canadian beer sounds good though (I always did like Molson). Maybe at Norwhack?
  #44
Old 06-04-2003, 02:59 PM
60man's Avatar
60man 60man is offline
Worked as sales rep for NAPA for ten years I will use nothing but NAPA Gold or Wix filters. They back their filter with engine replacement if their filter was the culprit.I have cut open many different brands of filters. Most are tin cans with cardboard glued to about 1/2 the filter media of a Wix and incorperates a piece of bent tin for by pass spring. Having said this I will say I have not cut open a HP series Fram. Might prove interesting. I know the consumer grade Fram is nothing I would consider using on my John Deere much less my race car.
Outlaw Pontiac Racers Association"For Those Who Live The Legend"
ECM member.
MANDRA
  #45
Old 06-08-2003, 07:55 PM
dragula81's Avatar
dragula81 dragula81 is offline
60Man is exactly right. I worked for a NAPA at one time and we made a counter display by cutting open about 5 different brands of oil filters including Fram. I personally bought and cut open each of these fitlers myself (got the Fram at Wal-mart) for the display so there was no "trickery" involved.
The NAPA Gold (made by Wix) had metal end caps glued to a fiber heavily pleated element and a heavy duty spring loaded bypas valve on the end.
The Fram had cardboard end caps glued to a paper filter with literally a string tied around the pleated element to keep it from "popping open" and the bypass valve was just a bent piece of flat metal...no spring at all.
The NAPA and one of the other filters were very similar. I think it was the Motorcraft filter (which may be made by WIX also), I don't remember.
The poor quality of the cheap Fram was so obvious that any idiot could see it. We would still have "Fram people" come in and look at our display and still argue that they would never stop using Fram's. Some people are hardheaded.
Drag
http://webpages.charter.net/dragula7
Drag
www.dixiemusclecars.com
The Southeast's only online Community dedicated to the American Muscle Car!
2006 PBM GTO LS2
1995 Arctic White Trans Am LT1
1981 Trans Am Daytona Pace Car
1969 Gold Poly Firebird w/400
  #46
Old 06-09-2003, 08:18 AM
rasilverbird rasilverbird is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Mr_GTO:
Fram's are junk.<HR></BLOCKQUOTE>Word. I'll never use another Fram product. AC Delco for me.
1996 WS6
1968 GTO
1968 GTO - 400/400 - Currently being rebuilt - 455/T56
1996 WS6 - LTI M6 - Sold 5/11
1979 Trans Am - 403/Auto - Sold 12/18
  #47
Old 06-09-2003, 07:57 PM
khkiley1 khkiley1 is offline
I think this
link was posted once before but it is extremely informative. This guy took the time to cut open a bunch of filters and compare them on his site.
Worth a look.
Kurt
The IQ and life expectancy of the average American just passed each other going in opposite directions.
The IQ and life expectancy of the average American just passed each other going in opposite directions. - George Carlin
  #48
Old 06-09-2003, 09:00 PM
Tim Corcoran's Avatar
Anyone who has over a hundred bucks in his motor should read the oil filter study. The Frame filter is a piece of you know what. If you've been lucky so far that's great but your living on borrowed time.
Tim C
65 LeMans, 3500lb. D-ports and a flat tappet cam, 10.92@120
Tim Corcoran
  #49
Old 06-10-2003, 08:24 AM
Fox Fox is offline
Yep I use nothing but AC Delco filters in mine.
"Man did not weave the web of life, he is merely a strand in it.
Whatever he does to the web, he does to himself."
- Chief Seattle
  #50
Old 06-10-2003, 08:43 AM
mikeb mikeb is offline
I used my last fram several years ago. There are lots of stories of fram filter failures on the various messageboards I read. I actually cringe whenever I see a race car sporting a fram filter.
I usually pick up a purolator or A/C for my T/A and motorcraft for my brand X vehicles
  #51
Old 06-10-2003, 09:50 AM
sscherin sscherin is offline
Anyone cut open a Napa silver filter?
the PN's match the Napa gold and wix lines.
going by a quick visual check they look the same.
GURU: One who knows more jargon than you
Scott Schering
70 Firebird 455 12.34 @ 108.2
Http://www.pontiacs.org
William's Law--
There is no mechanical problem so difficult that it
cannot be solved by brute strength and ignorance.
Scott Schering
  #52
Old 06-10-2003, 12:09 PM
Steve C. Steve C. is offline
The Fram HP series compettion oil filters are a very different animal than a regular store bought Fram filter. Besides being larger, the case and insides are different.
I have been using a Fram HP-2 for years. Also the NAPA (WIX) #1049 is a larger size filter that is very similar in size to the Fram HP-2.
Old information here:
  #53
Old 06-10-2003, 02:24 PM
Ditto to what Steve said. Sheesh! I've been going to the same diner for breakfast every Friday for 5 years, and the food is great, but because one person tells me they went there and got sick from eating the food, I should stop going?
Of these Fram failures, has anyone documented that it was an HP series filter that failed? No? I'll keep using the HP1 with confidence, thank you. Been using the HP1 for 5 years now without fail.
  #54
Old 06-10-2003, 03:43 PM
basketcase70gto basketcase70gto is offline
What 60Man said is exactly right. I worked at a local carquest for 5 years. Our filter rep showed up one day with a filter cutter so we decided to check things out. We took both a Carquest blue and red filters off the shelf and cut them open along with a ac delco, fram,and a quaker state. The Carquest filters are also made by wix and the blue\red is the same as the napa gold\silver lines. The only filter that was more scary inside that the fram was the quaker state. That filter had the little string tied around the element to keep it from blowing apart( maybe that makes it better than the fram?) Cardboard end caps and a stamped piece of tin for a bypass spring is not what I would consider a quality filter. A dirt track buddy of mine would not listen to me because his high-buck engine builder recommends the fram. He learned the hard way when the filter element came loose inside the can and blocked all the oil flow through the filter. The bypass on the filter adapter was plugged so it roasted the motor! Fram filters- great marketing, crappy filter
  #55
Old 06-10-2003, 04:43 PM
Regarding these "strings" around the outside of the filter element, I think the issue with them being there is getting blown out of proportion. The oil enters the filter on the outside of the element and exits through the center. If anything, the element media would collapse in a failure, not "blow out". The "string" is probably there to hold the element in place (or in shape) while the end caps are being placed on it in manufacturing.
  #56
Old 06-10-2003, 06:34 PM
dragula81's Avatar
Hey Brian,
I assume the string is actually on there to keep them from "blowing out" like an umbrella during the manufacturing process. When they are being "stuffed" into the cans. Maybe I didn't use the correct wording.
Thanks,
Drag
Drag
2006 PBM GTO LS2
  #57
Old 06-11-2003, 01:45 PM
sscherin
The Napa Silver and Gold oil filters are both excellent oil filters as pointed out in the oil filter study. The part numbers are different between the silver and gold filters. They both contain the same suffix but the prefix is definitely different. The reason the suffix is the same is to make it easier when matching up applications, and the different the prefix is to differentiate between the gold and the silver. I have inspected both the gold and the silver filters with the metal casing removed. At first glance they look exactly the same, but after closer examination you will notice more filter media surface area on the gold than the silver. Basically the only difference between the two is the gold has more pleats than the silver.
Tim C
Tim Corcoran
  #58
Old 06-11-2003, 03:57 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
I have been using Fram HP-2 filters on my 10 sec 455s for 9 years. Never had a problem.
73 Firebird 455 D-Port, 3250 lbs.
Best ET: 9.93 @ 133 mph with a 1.318 60'
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
  #59
Old 06-11-2003, 05:30 PM
TTS's Avatar
TTS TTS is offline
Basketcase I had the same thing happen in 84' to a Dodge van, 318 engine. A couple of days after oil change the engine seized. The Dodge dealership found the Fram oil filter had disassembled. Fram bought the engine, so I have less problems with the company, I won't buy a filter from them though.
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson
"If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
Right and wrong doesn't need facts all the time.
-Lighthouseman ("lawyer")
Starnes Performance Automatics
www.Starnesperformance.com
  #60
Old 06-12-2003, 11:48 AM
stu stu is offline
Ok I'll never buy another Fram, I get AC or Fram dependng on what's in stock and never had a Fram issue but what's the harm in AC.
