Old 07-08-2006, 09:41 PM
GTOINDY GTOINDY is offline
Default cam or converter
There is something wrong with my setup. either the cam or the torque convertor must go. The car feels like it is towing another car down the track.The best 60' time is 1.90 it looks like it's in slow motion at the line.
Any ideas?
400 Pontiac bored .030 over
CAT H beam connecting rods
Comp cam solid lift cam 51-000-5
duration @ .050 248 intake 256 exhaust
lift intake .531 lift exhaust .550 lobe separation
108 Intake center line 108
1.5 roller rockers
#13 heads 2.11 1.77 valves
Edelbrock RPM intake 850cfm
Edelbrock carb
MSD billet distributor/ MSD blaster 2 coil
69 TH400 Trans Continental converter 3000 stall 10”
12 bolt rear end Moser axles and spool 3.73 rear gear boxed lower control arm Adjustable upper arms Air bag in right coil Adjustable drag shocks on all Four Corners Moroso Trick springs
M/T slicks 29.5 X 10.5
car weight is 3200lb
Vince
Old 07-08-2006, 09:57 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Anywork done to the heads? What is your other times like 330' 660' and 1/4 mile? Does the car lay down the whole track or does it seem to run better in a certain portion of the track? This information will help diagnose what is going on during your run.
That cam sounds pretty healthy and the car seems to have alot of good parts that would make it run good as well as being pretty light.
Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 07-08-2006, 10:41 PM
Robert
Robert
Heads are pocket ported By Kauffmans but no flow numbers
1/8 [email protected]
1/4 [email protected]
The car never seems like it pulls hard I have a 70' GTO that is much more fun to drive
Old 07-08-2006, 10:00 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Carb? I have seen a few threads which do not lean favourably to the edelbrock carbs on pontiacs!
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 07-08-2006, 10:04 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Timing?
russ467's Avatar
russ467 russ467 is offline
I would look at how fast your TOTAL timing is coming in, then how well the carb is responding. You need a holley based double pumper or a very well set up quadrajet.
70 Formula
Old engine:
467 HO headed
6.79 1/8th mile @ 101.87 no N20. 1.44 60ft
6.23 1/8th @ 111.83 w/nitrous
1.37 60ft
New Engine
IAII 535
Calvin Hill Eheads
Few test passes made. Tore it up. Just got it fixed.
Old 07-08-2006, 10:48 PM
Default timing
Timing is set at 15 with a total of 36 in at 2500rpm. Cliff R set up the carb and I have also used an Edelbrock 750 performer with not much difference in performance.
Old 07-08-2006, 10:55 PM
russ467's Avatar
What kind of distributor are you using?
Vacuum advance?
70 Formula
Old engine:
467 HO headed
1.37 60ft
New Engine
IAII 535
Calvin Hill Eheads
Old 07-08-2006, 11:02 PM
Vacuum advance?
MSD billet distributor Vacuum advanced is removed.
Old 07-08-2006, 11:00 PM
Tom Hand's Avatar
Tom Hand Tom Hand is offline
Exhaust Guru
I would think that it will be way cheaper and make an easier to drive car if you swapped the cam for one much, much smaller. The converter it would take to work with that one will be very expensive and then you will have a strip car that will be annoying to drive on the street.
Tom Hand
Old 07-08-2006, 11:11 PM
Tom
I am starting to think the same way about the cam. The car will be driven on the streets once in a while but mostly a drag car.
russ467's Avatar
If I were you, I would first try to lock the distributor to give you full advance all the time. That should wake it up. I also think you may need more converter, but you still should be getting way better than a 1.90 60ft unless you are spinning!
Last, I would see if you could borrow a known good 750 double pumper to try.
70 Formula
Old engine:
467 HO headed
1.37 60ft
New Engine
IAII 535
Calvin Hill Eheads
Old 07-08-2006, 11:18 PM
No tire spin at the line. Cliff R ran my carb on his car and it ran mid 11's with no problems. How do you lock the distributor in a full advance?
Old 07-08-2006, 11:23 PM
russ467's Avatar
I dont run an MSD distributor, so I dont know for sure on yours. I think there is a kit you can buy that will lock it out.
70 Formula
Old engine:
467 HO headed
1.37 60ft
New Engine
IAII 535
Calvin Hill Eheads
Old 07-08-2006, 11:38 PM
JKGTO's Avatar
JKGTO JKGTO is offline
That cam is way too big for a 400. Nothing you can do is going to make it run very well except some 4:56 gears and an 8" converter. Jim
74 LEMANS GT 350 4SPD MAROON
Old 07-08-2006, 11:39 PM
GOAT490's Avatar
GOAT490 GOAT490 is offline
I ran the H0-3 cam with similar specs in a 462 with about 11:1 compression and a similar setup to yours and it ran pretty good. I think the cam is WAY TOO BIG unless you go to 4.56 gears and/or a bigger convertor. A 750cfm should be plenty for those cubes/rpm. What is your compression?
PHILLYGOAT
PHILLYGOAT
1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/
3550lbs/ Full Exhaust/ Foot Braking
1.41 60ft [email protected] [email protected](Pontiac Heaven)
More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379
GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4
Old 07-08-2006, 11:45 PM
PHILLYGOAT
heads are 13's and the block was not zero decked so it should be a little less than 10.1
Old 07-08-2006, 11:51 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Was the cam degreed?
Or just "line up the dots" and assumed to be "straight up"???
I'd at least try advancing the ICL to 104-102 degrees or so first...
That H-O cam is a hydraulic cam with roughly the same specs,INDY's cam is a solid cam,big difference in most folks books.
Old 07-08-2006, 11:56 PM
In that other thread you said you had gotten some mid twelves (12.53 IIRC) out of it but were having traction issues,what's changed since then???
Old 07-09-2006, 12:21 AM
you are correct the first day to the track it ran a 12.53 on small street tires 26" tall. I have also switched to the RPM intake hoping to get some low end torque
