2900DA 1.41 60ft 6.45@105mph 10.25@127mph
PHILLYGOAT 1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/ 3550lbs/ Full Exhaust/ Foot Braking 1.41 60ft [email protected] [email protected](Pontiac Heaven) ![]() More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379 GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4 Last edited by GOAT490; 06-03-2010 at 12:41 PM. |
just got out for the first time this year and i'm running great first pass off the trailer 8.97 154.9 mph 5.68 121 mph
'74 ventura (80% street/20%strip)
462 9.5:1, 670 D-ports, 91 gas 3750 w/driver TH350, conti 10'' 3.73, 275/60 MTDR 1.64 60' 11.97@111
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
1963 Lemans 3450# w/Driver All steel but the hood. All factory Glass
No Power Adders 535 IA II with Semi WP E-Head (R.A.C.E. Ported) 12.9 to 1 Comp Turbo 400 Manual Reverse 9" ford 456 14 32 15 3400 DA (PSN 2008) 9.801 @ 136.7 1.36 60' 6.22 1/8 Through Full Exhaust And mufflers Seats and Carpet Antique Licence plates
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 Last edited by JKrull66; 06-26-2008 at 07:24 PM. Reason: addition |
http://www.youtube.com/watch?v=iJrDl3nRNCM http://www.youtube.com/watch?v=Fvywdocl4GA http://ultimategto.com/icongraf/65headtitle.jpg |
Snuck up on you first round HEE HEE Tons of fun...LOL But you got me in the end John
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 |
I ran a 11.55 at 117 in my all steel 64 GTO Convertible with a 400 engine many years ago. Hurt a lot of parts including the car to get there. Young and Foolish. Some say that is a pretty good time for a vehicle of that type with a tire that will fit under the wheel houses without mods.
I have driven a Vega that was faster than 9.40s but that was the best I did with the car. Have to admit that the Old Man (Pontiac Dude) and many others have got me covered on this topic pretty good. Tom V.
First time out at Grand Bend going for my license it ran 9.59@140. 6.13 in the 1/8. 1.35 60'. 1970 455, 4.25 stock crank with Ross NOS pistons and Chevy 6.8 Oliver Billet rods. Ron's 4" toilet on alcohol. Could not weigh car but think it's about 2800 with me in the seat. E-heads are non wide ports. First time with injection and alcohol so I was just playing around, LOL! It started with a 9.8 off the trailer but was very lean. Richened it up and ran 9.7. Once more and ran 9.59. My day was over and we packed up. Ran at an airport race the weekend after and I richend it up again and it ran a 6.13 with a 1.45 60'. We're going to Armdrop soon and am hopeing to run in the 9.30's-9.40's. With a little NOS added I should be in the 8's. ... Eric
Runner Up Q16 Norwalk 2013! |
new best yesterday at the track in bradenton
'67 firebird 3550 w/driver 462 w/stock rods % crank E-heads flow 300 @ .600 victor w/ 1" spacer 850 holley .605 lift 260 @ .050 lunati roller 12.8:1 comp. 2" headers th-400 w/ 9" trans speciaties 3500 converter 9" rear w/ 3.73:1 275-60- drag radials 60'----1.599 330---4.37 1/8---6.69 mph--105.04 1000'-8.72 1/4---10.44 mph--130.92 |
84 TA, 2900lbs w/driver
406 ci trw pistons stock rods stock crank 670 heads .575 solid, flat tappet torker 2 950 carb (alky) th-400, 12 bolt w/4.10's 29-10 drag slick 1.40 60' 10.49@ 127 Billy Farrell
1984 TA, 400 PONTIAC, th-400, 4.10 12 bolt 10.49@ 127mph 1.40 60' R/U Pontiacs in the Park 2006(SAT) R/U Pontiacs in the Park 2007(SUN) Last edited by 84TA400; 06-29-2008 at 09:45 AM. Reason: forgot name |
My car has full interior other than front race seats, could be street driven with the exhaust bolted back on and street tires, but I have not driven on the street since I broke-in this engine in March 2006. March 2006 in street trim with full exhaust including over the rear tailpipes, 265/95 M/T street ET radials and #62 D-ports it went 11.52 @ 117 (1.66 60'). After swapping converters and removing the exhaust I was able to get a best of 10.99 @ 121.7 (1.52 60') at VMP's PIP race 19 May 2006. 1 July 2006 I swapped on a set of Edelbrock aluminum heads. I have been running the same engine combo 463/E-heads since 1 July 2006. 300+ passes on the shortblock, 200+ passes on the heads
1969 Firebird, full interior, #3535 lbs w/driver 463 CID, 103 N crank 4.21 stroke, +.035 pistons, 73 2-bolt block Crower solid flat tappet cam Edelbrock aluminum cylinder heads Q-jet on a Tomahwk aluminum intake manifold VP-110 race gas T-400, 373 gears, 30x9 Hoosier radial slicks @ 23 PSI Quickest pass is 1.42 60', 6.55 @ 103 = half track, and 10.32 @ 128 = 1/4 mile pass Fastest MPH is 129.9 at Cecil County, down hill...
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Most of mine is in my sig.,but I'll post some more details.Race only
'68 Firebird 3100 lbs '68 400 block .060 over with 4 bolt billit caps filled to water pump holes. 4.25 eagle crank,6.8 rods,SRP pistons Comp 290b-6, 255/265 flat tappet around .600 lift with Harland Sharp 1.65 rockers KRE 310 cfm 74 cc dports,11.5-1 compression will run on 93 but usually run on 100LL Victor intake,1050 Dominator Turbo 400 ,ATI 9" 4500 stall converter Moser/Dana 60 rear with spool and 3.73 gears Hoosier 30x10.5 radial slicks 92.5 circumference Best footbrake times on 9" tire 1.35 60' 6.30@107 1/8 10.01@131 1/4 Best tbrake times on 9" tire 1.30 60' 6.25 @ 107 1/8 9.93@ 132 1/4
Mark 1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD.... 1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs (1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor [email protected] on 150 shot |
78 ta 3540 lbs
67 400 block / 455 crank stock rods 230/230 490/ 490 b.m 2 cam harland sharp 1.60 6x 8 heads 40 off 9.0 com. rpm intake 750 holley t 350 2800/ 3000 stall 373 stock posi. 8.5 3 inch exsuhst headmen headers mt 315 60- drag radials 12.7 -105.78 1.74 60 foot na 11.78 - 112.78 1.59 60 foot 100 shot
1978 ,t/a 3660# 455 2010 / 1/8 7.86 1/4 12.40 @ 109,19 http://www.youtube.com/watch?v=6PaHbLnszS0 http://www.youtube.com/watch?v=XMxhM...eature=related 12.01@109 http://www.youtube.com/watch?v=MC-dganA2jQ 100 shot 11.78. A,ll new head cam combo 96 ported bye Mike Chell!! Comp cam yes the 284 XE. Firsthand outing of the street 7.69 1/8 12.15 109.47 hot and humid.not hooking. 1.73 60. |
Best ET/ MPH - 1/4) 9.78 @ 136.23 1/8) 6.108 @ 112.22
Best 60' time- 1.31 Engine - 455, 10.5 to 1 compression Induction- E-heads, N/A, 1050 Dominator on alcohol Car- 67 Firebird, ladder bar, mini tubbed Weight- 3245 lbs. w/ driver Tires- 31- 13 Goodyear slicks Rear gear- 12 bolt w/ 4.33's Transmission- 1.76 Powerglide, 8" BTE 6000 stall convertor |
Best ET/Mph 1/4) 9.228 @ 145.62 (2017) 1/8) 5.827 @ 118.10 (2021) Best 60'- 1.26 Engine IA2 529ci 13:1 compression Induction- Standard port E-heads, N/A 1250 Dominator on alcohol Car 67 Firebird, ladder bar and leaf springs, mini tubbed Weight 3275 lbs. w/driver Tires- 29.5-11.5W Hoosiers Rear Gear -12 bolt w/4.11's Transmission- 1.80 Powerglide, 8" FTI 6300 stall converter
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion 2024 Chief of the Pontiacs |
| The Following User Says Thank You to Probird For This Useful Post: | ||
1964 faux GTO, built by twooldgoats. Damn nice car.
482ci factory block and crank built by Ace @ PPR, Lunati roller, Venolia/Scat, HighPorts, Victor/1050, Dougs 1 7/8" headers (way too small) Hughes 400 & convertor, 3.89 9", 28x10 MT tuneup by Koerner Racing dyno Tucson 10.39@125 at Pontiac Heaven with 2 flat tires and a leaky framous valve SIGH...all these years and still not as fast as Jack Ferris
![]() My Daddy bought me a car but all I got was this old Pontiac.
1969 trans am clone, 3385lbs, ladder bars, stock frame rails, all steel except hood and front bumper, 29.5 x 10.5 tire, no power adder, 523" tiger heads, single cast 4, 1150 carb
60'- 1.286 330'- 3.573 1/8- 5.482 mph- 128.43 1000'- 7.132 1/4- 8.525 mph- 160.35 |
4.25 Crower Billet Crank
468 C.I.D. with Oliver rods 400 1970 Block KRE ported e-heads flowed 345 on intake KRE sheetmetal dual 4 bbl intake 750 dual 4 bbl Holley carbs Comp roller cam, int gross lift .724, exh. .693 lobe separation 104 deg. and installed at 104 60' 1.367 sec. 1/8 6.153 sec. @ 111.64 MPH 1/4 9.680 sec. @ 138.47 car and driver wt. 3410 110 octane C.R. 13.1 to 1 Ladder Bar rear with coil overs, 4.33 rear ratio in Ford 9" Rear tires 10.5 @ 31.0 Dia. Headers 2" into 3 1/2" collectors Turbo 400 std. gear ratios Shifts at 7100 to 7200 RPM |
an update
At Norwalk I ran my personal best 10.52 @ 128 with a 1.49 short time
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright" |
70 GTO, track only
3800 lbs 469 cu in, factory block and crank 72 cc e-heads smallish comp solid roller Victor with a 750 holley T400 with a 4000 ATI converter NO electronics 12 bolt 4.10's 29 x 10.50's 1.56 60' 7.28 @ 101 in the 1/8 11.11 @ 121 in the 1/4 77 Can Am, street and strip well over 4400 lbs! 472 factory block and crank 72 CC E-heads Comp Roller, .660 range Victor with a 1050 Dominator T400 with a 4500 Coan NO electronics 9" with 4.10's 28 x 9 ET streets 1.72 60' 7.90 @ 82 in the 1/8 11.62 @ 124 in the 1/4
Paul FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first. My site... needs updated- www.fastrestorations.com 68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs! |
