Old 10-20-2010, 11:42 AM
Bnick166's Avatar
Bnick166 Bnick166 is offline
Mornin' fellas.
Back from BES and what a cool experience.
Tony and his guys are great.
Class act all the way.
We ran it in on race fuel then switched over to 93 octane pump gas.
Had to make some changes to the dist first
We started with the 1050 Jeff Esmel built but it was very lean down low (at tip in) then it would pick-up.
Switched to 1100 pro syastems carb for first few pulls.
Best we got on race fuel was 705hp @ 7200
After we were comfortable with everything, we switched back to Jeff's carb to fatten it up on the bottom without leaning it out on the top end.
After a few pulls we were headed in the right direction. This thing LOVES fuel.
The more fuel we put to it....the more the torque came on.
With Jeff's carb we started with the supplied 86/92 jets and .045 high speed air bleeds and wound up at 99 jets and .026 high speed air bleeds.
Horsepower was virtually unchanged between C25 and 93 octane.
Best on pump gas was....(going from memory as I forgot the dyno sheets)
704 hp @ 7200 607 tq @ 5100
Can't seem to get vidio clip to load.....
  #42
Old 10-20-2010, 11:55 AM
slowbird's Avatar
slowbird slowbird is offline
Very nice!!
Did you have to richen it up more once you changed over to pump gas?
  #43
Old 10-20-2010, 12:31 PM
Polar-Pontiac's Avatar
Polar-Pontiac Polar-Pontiac is offline
Great job nice power.. I can't wait til my new 505 is ready go..
  #44
Old 10-20-2010, 12:51 PM
Bnick166's Avatar
Originally Posted by slowbird View Post
Very nice!!
Yes...richened it up and pulled out a little bit of timing.
Here's a link to one of the pulls. TURN IT UP!
http://www.youtube.com/watch?v=yg9aA2fioQs
  #45
Old 10-20-2010, 12:53 PM
bankbook's Avatar
bankbook bankbook is offline
Graet build Brad!
You have to be extremely happy with that engine
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
  #46
Old 10-20-2010, 01:05 PM
Nice numbers. Hope you can post the curve. Just about exactly where I expected peak tq and power rpm's. I suspect you will be able to run 89 octane and still get similar numbers. Nice combo.
  #47
Old 10-20-2010, 01:21 PM
R 70 Judge's Avatar
Sounds like a great engine! Did you happen to catch the V/E number? I'm just curious.
James
1970 Trans Am
  #48
Old 10-20-2010, 01:38 PM
Bnick166's Avatar
I don't have the print out sheet at this time. Amidst all of the excitement and getting everything loaded up for the trip home...I knew I'd forget something.......
I forgot the dyno print outs. I'll get Brian to send them to me.
  #49
Old 10-20-2010, 02:20 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Very nice Brad! Congrats on a nice build!
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
  #50
Old 10-20-2010, 02:23 PM
Gach's Avatar
Gach Gach is offline
Awesome !! I can't believe that thing made 704 hp with only 9.80 compression. Uncle Tony is one of the best.
Congrats on a awesome street motor.
  #51
Old 10-20-2010, 03:21 PM
Ron H's Avatar
Ron H Ron H is offline
Nice build. Congrats.
68 Firebird
Are you running with the wind or breaking it?
  #52
Old 10-20-2010, 03:35 PM
Silver Judge's Avatar
Wow, great #s for another Pontiac powered pump gas monster !
Congrats BNICK !
You shopping for drag chutes now ? Seems you may need one to slow the torquey beast down at the track
501 HP, 554 ft lbs TQ
  #53
Old 10-20-2010, 05:46 PM
Probird's Avatar
Probird Probird is offline
Very nice. I was pretty close, only 10hp off. That thing should run pretty well.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
  #54
Old 10-20-2010, 05:51 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Good numbers, these heads like RPM, who said a Pontiac can't make power over 6500RPM????
Calvin Hill
Hill Performance
708-250-7420
  #55
Old 10-20-2010, 07:13 PM
Bnick166's Avatar
My hat's off to Roland Racing, All the guys at BES, Len Caverly, Jeff Esmel, Dave Bishoff, all the great people on the Pontiac Zone and the PY Forum for their input and inspiration and everyone else involved in this build. I tried to spread it around a little bit to each of the Pontiac Vendors and buy at least 1 thing from everyone I could think of. When I found out what it would cost to buy an engine such as this...I thought...I can build it cheaper than that.
Don't try this at home, friends.
My next one will be a one and done build....here's what I want, call me when it's ready.
Again....my most sincere gratitude to everyone involved.
  #56
Old 10-20-2010, 07:22 PM
dda72's Avatar
dda72 dda72 is offline
Nice job Brad!
  #57
Old 10-20-2010, 07:25 PM
Daniel Barton Daniel Barton is offline
That is pretty good power... you should be real happy!
  #58
Old 10-20-2010, 09:22 PM
Bnick166's Avatar
OOOPP's...I mis-spelled Dave's last name.....should be Dave Bisschop.....(of SD Performance fame)
Sorry for butcherin' your last name Dave.
  #59
Old 10-20-2010, 09:27 PM
grandville455's Avatar
grandville455 grandville455 is offline
Very Nice numbers!! Congrats!.. so the 99 jets that was sqaure jetted then i take it?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
  #60
Old 10-20-2010, 09:32 PM
Bnick166's Avatar
Yes...square jetted.
Tony said the easiest way to lean it down after I add my complete exhaust for the street is to just change the High Speed by-pass bleeds from .026's to .030's.
