#41
another issue not entirely relevant to us here but if moisture gets in the rollers, and more specificly water or mud, it will do a roller in in like half an hour, I seen that happen in mud bogging. not relevant to most of us but hey who knows
#42
If you happen to go the steel bushing route instead of the genuine Oilite, (I wouldn't, grease or no grease) I would apply a reasonable amount of grease but not so much that it would fling off. This is why I like the genuine Oilite bushing idea so much. There is no risk of grease contamination whatsoever, and the bronze is softer than the transmission input shaft. As I have said in a previous post, knowing what I know today, I would go Oilite or a ball bearing. Oilite is pre-lubed and gentle on the input shaft, while a ball bearing was OEM. |
#43
From my experience on OEM cast and Scat forged cranks the Timken 7109 is flush when installed. The photo on the Summit Racing site is a representation, not the actual part. I am not familiar with the Tremec, I can only speak to what I have run...Muncie, Autogear and GForce transmissions. The inner diameter of the 7109 is 0.59 in. As you said, put a mike on your input shaft and verify it. Curious...does Tremec spec a bushing or bearing? Good luck...keep banging those gears. |
#44
Gotta Luv some old Muscle.. 64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror 3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna Silvermist w/BlackVinyl Top http://s161.photobucket.com/albums/t201/dracowizard/65/ |
#45
We will see what happens as the summer progresses... |
#46
Un-equal pressure to the pressure plate fingers might cause the same noise but I'm just speculating.
#47
But glad the Oilite bushing works for ya. |
#48
He admitted after I asked that he put the bushing in dry thus creating the issue to begin with.
#49
My 81 Trans Am has made the same noise he's talking about a couple times, there was also a pulsation in the clutch pedal when it happened.
