Old 03-10-2014, 08:35 AM
mike leech's Avatar
mike leech mike leech is offline
Originally Posted by Stan Weiss View Post
Mike,
I do not not know who's calculators you are using? But if you are using the ones on my web site, they are not correct at the et and speed that you are running. They show to much HP. They were put on the web page in 1997 and for slower cars are not that far off based on a very old and very simple formulas. An NHRA Pro Stock at 2350 lbs at around DA = 0 runs around 6.44 et and 214.x MPH. That is around 1480 HP. What does the calculator or slide rule you use show for their HP?
Stan
3 different slide rules say 1000 on the button. and every online calculator shows 1038ish, which is bs IMO. the slide rule is the slide rule and accepted by even the likes of Chris uratchko as accurate.
i'm very confident it makes 995-1005ish.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #42
Old 03-10-2014, 11:12 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Originally Posted by Badbird69 View Post
Crickets..........
Those ET slips are not crickets
First Pontiac powered street car in the 7's
[email protected]. 3460#s
  #43
Old 03-10-2014, 11:15 AM
LiL Jack's Avatar
Talking
Originally Posted by 65nss4spdGTO View Post
How much did that 565 with canted valve heads make again that you built?
  #44
Old 03-10-2014, 11:23 AM
LiL Jack's Avatar
Originally Posted by p4msi1 View Post
Well its not eheads, just mild pump gas motor with tigers. Its also a chassis dyno which nobody here likes either. I am posting this as a stall tactic while the eheads guys start to scramble like frantic squirrls in the middle of oncomimg traffic, looking for the 1000+ dyno sheets. I think the CV-1 crowd is starting to crack a smile.
Dump sheets are for Internet racers.
How much are the CVwhat guys smiling when we skull drag and donkey stomp the phuck out of them on the track?
Just sayn
  #45
Old 03-10-2014, 11:44 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Originally Posted by LiL Jack View Post
Dyno sheets are for Internet racers.
Just sayn
true story.... some people like to race dynos.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #46
TRUTH
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #47
Old 03-10-2014, 11:46 AM
Originally Posted by john marcella View Post
True motor people.
LMAO. im sure you guys will show more than a 1000 with mikes engine!
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #48
Old 03-10-2014, 11:47 AM
Originally Posted by David Holmberg View Post
My point was, ET is what matters the most.
The dyno is a tool to check progress, to help select shift points and converters with.
I've seen many (chassis) dyno queens come to the track and get embarrassed by cars with less power @ the same weight.
But I really wasn't trying to start a debate.
X2!!
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #49
S/st 54's Avatar
S/st 54 S/st 54 is offline
Just sayn
Sooooooo can you produce a 1000hp E head dyno sheet n/a..........it doesn't seem as hard as it is for you to produce a .00x reaction time.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
  #50
Old 03-10-2014, 11:51 AM
S/st 54's Avatar
And fwiw I'm still trying to show a .90 mph worthy of the HP I've already made but HEY y'all can laugh at my timeslips all ya want......cause the way I see it timeslips just mean I'm trying! Pics of engine stands well......... just mean it's gona!..........
  #51
Old 03-10-2014, 12:07 PM
S/st 54's Avatar
Seriously? I'll give that one BUT! Can you blame the guy for grabbing a bat and taking a swing at it? Plus that car is already on the track running! Once again laugh all you want but timeslips look better than engine stand pic!???? Right? At least me and Keith have some what of a baseline and that kicks the crap out of the other question.......should we change engine stands? Will a different engine stand actually produce some kinda track result?
BACK TO TOPIC! We have seen the cv-bash the phuck out of those guys threads......I'm curious about MR FREAKIN Marcella's question! I would like to see those ehead 1000k dyno sheets do they exist? MR. MARCELLA'S exist buuuuuut any others?
I will give mike leech his credit because he's has worked his tail into the ground to show the end all be all result "the timeslip"..........but I agree with Marcella. Where are those 1k dyno ehead results? Not any other option that we have , where are the ehead results.......via that tool called a dyno?
  #52
Old 03-10-2014, 12:24 PM
john marcella john marcella is offline
And some people like to calculate their HP from a ET slip but only after they run in -0 DA air conditions. They forget about the rest of the year???
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #53
Old 03-10-2014, 12:37 PM
mike leech's Avatar
Sometimes the ones on stands never do! But you're right we gotta try and work it out.
EHTTFMF!
  #54
Old 03-10-2014, 12:41 PM
mike leech's Avatar
Has it occurred to anyone that john may be asking this for a reason?
EHTTFMF!
  #55
Old 03-10-2014, 12:50 PM
Stan Weiss's Avatar
Curt,
What heads were on this engine?
Stan
Pontiac Pump Gas List
  #56
Old 03-10-2014, 01:08 PM
GTOGEORGE's Avatar
East Coast Weather!
GTO George
  #57
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Jack,
Post your 1000 HP E-head dyno sheet.
This isn't about the CV-1's, they have not made 1000 HP.
Calvin Hill
Hill Performance
708-250-7420
  #58
Old 03-10-2014, 01:34 PM
Chris Petersen's Avatar
Chris Petersen Chris Petersen is offline
Send a message via MSN to Chris Petersen
I thought I read here somewhere in the Race section that making 1000HP from E-heads, was like falling off a log? Maybe I'll have to break out the search feature...
Where are the E-head nut-swingers now?
463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO!
  #59
Old 03-10-2014, 01:41 PM
Jack,
Calvin Hill
Hill Performance
708-250-7420
Jack, you have been called out! Hahaha Post it
John Marcella
[email protected]
ph. 248-259-6696
  #60
Old 03-10-2014, 01:42 PM
Originally Posted by GTOGEORGE View Post
East Coast Weather!
GTO George
10 min before it starts snowing
John Marcella
[email protected]
ph. 248-259-6696
