Prev Previous Post   Next Post Next
Old 03-30-2014, 09:41 AM
mike leech's Avatar
mike leech mike leech is offline
Default what will my old worn out eheaded engine make NA
Have a date set to dyno on april 2.
Changes
Ports are .220 wider pretty much all the way
slight increase in valve size to 2.275 from 2.25
intake valve switched to ti
intake swap from a real nice victor to an even nicer massaged bop. Much larger
maybe .4 to .5 of a point more compression
belt drive
The rest is the same as last year what say you?
BTW a note to johnta1 and Stan....please try and think through your responses before you post. I know its hard and you really want me to slow down or somehow fail. But to keep this thread clean understand in advance that 1300,1200,1100 and likely 1050hp are not likely lifting the valve .780 with a bracket set up. Additionally it will be tempting to say 850, but that will only make you look bad. If you truly are interested and have additional questions I will respectfully answer them. If not flame away.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
