#41
Like I said, call a machine shop, see who they use, or ask someone at a shop to ask the tool truck guy who they use. Maybe ask an airframes & pp person, see who they use. They probably have a service, if you have a friend, ask them to submit on your behalf.
Call Butler or Dave at SD, see who they use. Shoot, you could probably yellowpages it. .
#42
I guess all I had to do was Google "torque wrench calibration Seattle" to find a couple local places that can do it.... You'd think I'd know how to do that by now.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
#43
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
#44
That's Snap-On's recommendation, to be at the bottom of the scale, but in some cases, that's not 'zero' or 'zeroed'. Some start a 20ft lbs, or more.
All I know is that it shouldn't be backed off all the way to the bottom, past the scale or bottomed out. Or that's what's locked into my head. Since mine are Snap-On, I will 'adjust' my 'head-lock' to the above process pulled from Snap-On themselves. .
#45
#46
For general repair work such as suspension parts I use a Craftsman click type torque wrench that I've had for the last 25yrs. I always store it back to it's lowest setting and it still looks brand new although I've never had it calibrated.
For building engines I purchased 2 Warren Brown deflecting beam torque wrenches. One is 3/8 and the other 1/2 drive. They are made in Australia and very unique in design in that they don't have any parts that will go out of calibration with normal use. I actually spoke with the manufacturer who claims they are the most accurate torque wrenches and would put them up against any brand torque wrench. He said that he has tested his companies torque wrenches that were in use for 30-40 yrs and still perfectly accurate. If handled with care they will always stay calibrated. |
#47
Interesting. They've made a genuine improvement to the $10 "American style" deflecting-beam torque wrenches. Like the American-style, they don't need calibration, and they're reasonable accurate. The Warren & Brown web site doesn't have much for info or photos, though. I'm guessing there's no ratchet at the end.
http://wbtools.com.au/products/defle...rque-wrenches/ |
#48
#49
It's been awhile, but I purchased them directly from Warren Brown. At the time they had an international price that was cheaper than buying them in Australia.
#51
Thanks. When I converted the Australian price into USD it came in at $150. Not a bad price...
#52
I bought my Snap-on click type about 35 years ago & it has never been sent in to be checked & tested, but I've bought some cheap ones & checked it against my Snap-on one & it is right on with all of them & I have 4 of them now. But I always unwind it to back past 20lbs until it stops moving & store it in the box it came with. I use it for TQ only & have never dropped it or has it fallen of of any surface. I like my Snap-on click type as it has been a good working tool for a long time.Also most of the dealer around here charge $ 125.00 to have it sent in & calibrated.
#53
http://www.harryepstein.com/index.ph...que-28771.html http://www.harryepstein.com/index.ph...que-28772.html I've got 1/4", 3/8" and 1/2 drive deflecting-beams that I use for dynamic torque measurement--the 1/4" is used to measure rotational torque of rear axle assemblies, the 3/8 is typically used for assessing the torque required to rotate the crank 'n' pistons of a freshly-rebuilt short-block, while the 1/2" readily measures the break-away torque of most main cap and head bolts. While the ("American-style") deflecting-beam torque wrenches are wonderfully accurate, repeatable, and don't require calibration, they require considerable care and a bit of skill to use them properly. In short, for actually torquing bolts, they flat-out suck. I hope the Australians have improved the usability of the American-style deflecting beams. If they have, they've got a great product. Failing to include a ratchet head is an indication, to me, that it's still more about "cheap" than "good"--but I'd love to use one a few times and see for myself. Quote:
As said in an earlier post, I know of (and posted links to) two different companies that will test 'n' calibrate your (click-type) torque wrench for about fifty bucks plus shipping. After thirty-five years, you're due for a proper servicing. |
#54
The Warren Brown torque wrench is definitely not cheaply made. It is heavy and if you saw it in person you can tell that it is high quality. I am a contractor by trade and very anal when it comes to tools as I always spend extra to get the best available. The lack of a ratchet mechanism is definitely a PITA. This torque wrench is better suited for precise work where time is not an issue. It wouldn't be that great in a production style shop.
It is differs from an "American-style" deflecting beam torque wrench in that you don't have to read a scale as you torque a bolt. It has a spring loaded pin that you must reset before you torque each bolt. When the correct torque is reached the pin makes an audible "pop". Like I said, not great for speed but very accurate. I only wish us Americans would have come up with this unique idea. |
#55
Got an e-mail from Warren & Brown early this morning. Wilmington Instrument Co. is the U.S. distributor for their (Warren & Brown) torque wrenchs as well as CDI wrenches.
#56
Get a adapter like this and you can "ratchet" your beam torque wrench. https://store.snapon.com/Ratchet-Ada...r-P646913.aspx
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
#57
#58
My snap on 1/2" drive, click type, cam operated torque wrench was factory recalled. the ratcheting head was replaced with non selectable head. Then re-calibrated. It only tightens.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
#59
#60
I'd want compensation for that loss of utility. More realistically, I'd want another torque wrench. |
