Old 05-11-2016, 09:36 AM
grandville455's Avatar
grandville455 grandville455 is offline
Originally Posted by 68greenbird View Post
Good luck keep us posted, MDRA cancelled there event this weekend there ,saying track is still to green . August 27th and 28th new date. Was going to look you up.
Yea with all this rain and not much time to prep it , i'm not sure how it will be either!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
  #42
Old 05-14-2016, 10:58 PM
Default New Bests
More new bests, air was very good!! 1" Tapered spacer added since last time out. If I can get it to leave harder, 9's are there! Try tomorrow and see, going to try 2800 and see if it likes it.
ID:	428440   Click image for larger version
ID:	428441   Click image for larger version
Darby
  #43
Old 05-14-2016, 11:13 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Awesome job, Darby!!!
Go fast, see Elvis!
  #44
Old 05-14-2016, 11:57 PM
BADDTA's Avatar
BADDTA BADDTA is offline
Well done Darby!
Brian
Boobs & bacon
  #45
Old 05-15-2016, 12:12 AM
stroker461's Avatar
stroker461 stroker461 is offline
Congrats Darby!!!!!
  #46
Old 05-15-2016, 12:31 AM
cosgrove cosgrove is offline
You are knocking on the door. Good luck tomorrow.
69 Firebird, 536, Wideports, Cal Tracs, 275 radials, 3200#, a little spray 7.75 @ 173, 4.92 @ 142
  #47
Old 05-15-2016, 07:06 AM
Congrats!
Good luck today!
  #48
Old 05-15-2016, 09:13 AM
455firebird1969's Avatar
Good job Darby! 10.0 on pump gas @ #3600 lbs gets my attention. What intake are you running? I made a few changes to my car that lightened it, but I only tied my best ever ET so far. I don't doubt you'll run nines, you alway seem to make your car faster. Congrats!
  #49
Old 05-15-2016, 11:16 AM
JSPONT's Avatar
JSPONT JSPONT is offline
Great job, your tuning ability is showing!!
  #50
Old 05-15-2016, 12:15 PM
ta man ta man is offline
Good going!
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
  #51
Old 05-15-2016, 08:31 PM
update for the day... DA was about 11-1200 today
Had my best 60 ft this morning trying 2800, went 1.414, but only a [email protected]
then i dropped it back to 2500 to see difference and it went [email protected] with a 1.422 60 ft, Ive got aissue with my alternator tho, my battery was only 43% on my smart charger, 12.12 volts when i got home tonight, so i know that was part of the problem today besides the air too, cause we had a nice tailwind and shouldve ran better in morning, but i dont think i was getting the fuel supply i needed with such a low battery, with only pump running im 14.2 at alt, but 13.8 at battery, but turn fans on now im only 13.5 at alt and 12.77 at battery, Ive got 4 gauge welding cable so i know its not that its just a stock 94 amp oreilly alternator... all in all im very pleased with the weekend, and i know i will find my 9 come fall!
Darby
  #52
Old 05-15-2016, 09:27 PM
JSPONT's Avatar
Very cool, keep posting the progress! At least you can get out there and run!
  #53
Old 05-15-2016, 09:56 PM
https://www.youtube.com/watch?v=IMJl...m-upload_owner
Darby
  #54
Old 05-15-2016, 10:52 PM
slowbird's Avatar
slowbird slowbird is offline
What rear tire you running?
  #55
Old 05-15-2016, 10:54 PM
Phoenix 28.5x9...17psi
Darby
  #56
Old 05-15-2016, 11:02 PM
slowbird's Avatar
Mickey's pro bracket radial will get you in the 9s. Radial is the way to go!
  #57
Old 05-16-2016, 10:59 AM
torqjunki's Avatar
torqjunki torqjunki is offline
Very nice Darby. Awesome video. What springs and shocks you running in front? Air pressure in rear tires?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
  #58
Old 05-16-2016, 11:05 AM
They might brian , but i just bought these phoenix's lol
Darby
  #59
Old 05-16-2016, 11:06 AM
Thanks! Calvert 90/10 up front and santhuff 200 rate springs
Air pressure yesterday was 17 psi on my gauge, on a very good digital it was 16.2, I think the car hooked better closer to 15.5-16 on my gauge tho..
Darby
  #60
Old 05-16-2016, 11:07 AM
dci dci is offline
That's awesome Darby !!!!! Only a couple clicks away from a 9second pass. Very Nice !!!!
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
