#41
Pump gas and compression; With these big cams there is a lot of bleed-off
from the high percent of overlap which in turn lowers compression and with the alluminium heads which you can run more compression makes it able to get away with the higher compression if that makes any sense. All I kmow is that it works for me and a lot of my friends in the same situation I've always used race gas when dynoing my motor for the ease of reading the plugs, they stay cleaner but the next time I use the dyno I'm going to run pump gas first and the race gas and maybe even E-85 just to see what kind of power it makes over gas. And some thing I've found that usually any thing under 200LBS of cranking compression is usually safe for pump gas. I hope this helps any one trying to run pump gas and higher compression. GT |
#42
E85 you are going to need a different carb unless you want to do a bunch of work on dyno time. It would be cool to compare it all. I am a pump gas guy and my High Port 461 is 11.5-1 static CR. I have started out with 99 octane mix and will go to a 95 mix, Finally 92 all pump gas if everything looks good. It cranked 175 psi, but that was before the engine was ever started. It might come up a tad with broken in rings. Can you post a cam card ? |
#43
My RAIV 400 I was racing in the old NMCA Top Stock had no audible detonation on pump gas but picked up 8 hp on race gas at it's 10.25:1.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#44
If it picked up HP it NEEDED it!Tom
#45
With a longer duration cam the valves are open for a longer period of time allowing more complete cylinder filling and more time for exhaust scavenging which increases volumetric efficiency (VE). With both valves being open longer during overlap allows the gas discharge to speed up and creates a super charging effect which further increases VE especially at peak torque RPM. Also the more compression the more VE. With a smaller cam and lower compression all these properties decrease so to answer your question, NO.
Tim Corcoran |
#47
Black Friday sale will have them at 40% off. Get on it.
#48
What is 40% off?
Tim Corcoran |
#49
Speedmaster parts(heads etc)... what title of thread is
#50
Where are they 40% off? I looked at Summit and they are more than eheads
Tim Corcoran |
#51
Friday on Speedmaster website
#52
I'll get that info up soon for everyone.
GT |
#53
Sale is on now!!
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected] 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1972 LeMans 350 Pontiac H/S Drags project Last edited by Johnny406; 11-24-2023 at 01:32 AM. |
#54
i just ordered a set of the bare cnc 78cc heads and guide plates.....shipped total was under 1400. with the money saved i can put good valves and springs in.
#55
Sale is on the Speedmaster site.
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
#56
The HR springs that came with mine were OK. Machine shop did not like the locks though but retainers were OK.
#57
CNC 78cc for later reference when guys who buy them today try to sell them for more later. ha
| The Following User Says Thank You to 65madgoat For This Useful Post: | ||
#58
it dont seam like the sm heads carry a good resale value like the eheads and kre's. i think its best to buy those if you know you can use them and get your monies worth
| The Following 2 Users Say Thank You to performerrpm For This Useful Post: | ||
#59
Black Friday on 9" pumpkins too.
#60
I just placed an order for a set of the 78 cc bare heads and guide plates. I could not resist the black Friday price, I guess this will be my Christmas present to myself. I should buy 10 sets and let them sit for a couple years then re-sell them.
Tim Corcoran |
| The Following User Says Thank You to Tim Corcoran For This Useful Post: | ||
