Old 11-18-2019, 07:37 PM
Scott Roberts Scott Roberts is offline
Originally Posted by Stan Weiss View Post
GTO George,
Don't think you should at least wait until Jim gets it apart and sees what is wrong before you have him changing heads?
Stan
Looks like George was making a suggestion that would help with head gasket issues... less movement with a solid head vs a water head... you would know that if you were actually involved in a race car in the last half century....
  #42
Old 11-18-2019, 09:01 PM
Stan Weiss's Avatar
Scott,
It must be nice to have deep pockets and be able to just throw money at every problem.
Stan
Pontiac Pump Gas List
  #43
Old 11-18-2019, 09:11 PM
Scott,
Stan
It is... truth be told, it's about progressing one's race program.... if he can swing new heads and avoid gasket issues, he is ahead of the game...
It's not 1965 Stan.... cars are faster and more expensive to maintain... that 63 blown Tempest is my dream car!
The 62 and 63 are the most beautiful cars ever made in my opinion.....
  #44
Old 11-18-2019, 09:42 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Originally Posted by GTOGEORGE View Post
Maybe try a solid head like KRE's Solid Cast Aluminum HP head!
I run a IMI starter on my engine.
GTO George
No new heads, George. Hopefully, we can weld them up and move on. There's already more weld than head, anyway. Besides, I like having the fastest combo using the oldest Pontiac aftermarket head (not counting Mickey Thompson heads). They are already dry-decked and I run water only in the heads and not in the block. Paul Carter is a great engine builder and I trust we'll get it sorted.
I run two solenoids---Ford type in the passenger compartment to route power to the All Pontiac starter. I'm not sure which solenoid is acting up. I hate intermittent electrical problems. I'll definitely replace the Ford solenoid and see if the starter needs work or replacement. The All Pontiac starter has done yeoman work, starting the engine when it was NA and since I added a blower with no issues until now--over ten years.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #45
Old 11-18-2019, 09:48 PM
Mark G Mark G is offline
I agree 63 /64 is my dream car I just love them..... Here Scott ….https://www.youtube.com/watch?v=axOjlB3z1Wc You can sell the Chevy motor ..
  #46
Old 11-18-2019, 10:25 PM
Love it... repaint and engine change and it's perfect! Most beautiful car GM ever made...
  #47
Old 11-19-2019, 12:09 PM
Stan Weiss's Avatar
We here @ Computer / Keyboard Racers hope to have improved products for the new racing season.
Stan
  #48
Old 11-19-2019, 10:17 PM
cnc's Avatar
cnc cnc is offline
Maybe some different rims for the rear to get a 275/60/15 back under the car , some mods to the frt stab bar bushings to give the frt end some more travel and some control arm bushing work too....that's the plan anyway
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
  #49
Old 11-22-2019, 01:53 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
One of us is doing better on the diet plans than the other.. Not saying who .. The goal is not only to balance out the front to back weight a little better, but to have the bumper and lower pan quickly removable with 1/4 fasteners. The car sits so low, loading and unloading and strapping it down are a real pain. I have to drive it up on a couple of stacked 2x8's to be able to get underneath the front to loop the axle straps in.
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
  #50
Old 11-22-2019, 03:34 PM
Also planning on welding in a Anti Roll Bar and hopefully a fresh but still slow bullet in the spring. I dont want to be too optimistic, but it would be nice to finally get the hood painted too HAHA
1972 Pontiac LeMans
Thanks to
  #51
Old 11-22-2019, 07:49 PM
ta man ta man is offline
Rollbar,needed safety equipment,cup holder and stereo.
  #52
Old 11-23-2019, 07:40 AM
taff2's Avatar
taff2 taff2 is offline
Just a couple of upgrades for me - build new 420 engine with upgraded solid roller, Wenzler tunnel ram intake, new (ha!) ported 7H1 iron heads, Holley HP efi, D/A QA1 rear shocks,, rear gear change, uprated TH400 with t/brake,bump box, new hood turbo intakes, mufflers on turbo down pipes, B&M pro ratchet shifter and Shiftnoid, new driveshaft, extra driveshaft loops, new rear wishbone, bigger diam 4 link tubes, bigger ali radiator and cowl, 16 v system, 295 MT ET Street S/S radials,new front bib spoiler/splitter, and all the necessary new safety gear-harness's/Hans device/crash hat/flexplate and shield/blanket/window net. And leather bind the carpet edges-it is a street legal car after all. It's never ending.
  #53
Old 11-23-2019, 05:10 PM
I don't feel so bad now. It sounds like you're starting over!
Jim
7.75 @ 178 pass:
  #54
Old 11-23-2019, 10:12 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Swap out the 3/16 steel half mid-plate with a 1/4 7075 aluminum.
Engine tear-down will determine what's needed beyond the 2 cylinders which are down on cranking compression we're been running with.
Transmission is back out after swapping the case, forward gears were not working properly. During the tear down today we found a cracked forward clutch piston.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #55
Old 11-23-2019, 10:29 PM
MUSLCAH MUSLCAH is offline
If I can get a new switch ....so my factory power antenna works..I’ll be happy.
  #56
Old 11-27-2019, 05:23 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Just got my GTO from the chassis shop. Now to put it all together.
Short list...cm tube core support, cm engine crossmember, cm tube trans mount, racing brakes, tubular control arms, coilovers all 4 corners, upgrades cm full cage with snout bars, cm frame stiffener front to back that also strengthens year control arm mount, new year frame rails, mini tub.
1969 GTO, 3370 lbs, 10.5” tire...
07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads
  #57
Old 11-27-2019, 06:26 PM
76TA462 76TA462 is offline
Last winter was EFI and ignition system. I had plans this winter to sort out the AC I pulled out mid-eighties. Argh, at the end of this season my previously excellent running 462 started some super serious oil consumption and smoke spewing that verrry quickly worsened, so this winter’s project will be fixing things to get to where I was last winter. Sucks. But, next spring will be a blast again!!!
  #58
Old 11-27-2019, 08:06 PM
Old Goat Racer's Avatar
Getter dun Adam and bring it to Gateway on May 9 2020
https://www.wwtraceway.com/new-mothe...ay-may-9-2020/
Everybody knows somthin.
Nobody knows everything !
  #59
Old 11-27-2019, 09:07 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
Looks good Adam , car needs a rack n pinion though . Mike sr
505 CID, 3560 lbs,Tiger heads, NA.
8.99@149.8 mph, 1.29 60', stock suspension
  #60
Old 11-28-2019, 07:49 PM
It sure does Mike. 😆
1972 Pontiac LeMans
Thanks to
