Old 12-31-2019, 10:17 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by slowbird View Post
Alum rods?
Bill Meyer the Callies rods in this build alum or steel?
The Callies ultra steel rods checked out ok, I'm replacing the rod bolts and I'll run them for another season. Next set will be aluminum.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #42
Old 12-31-2019, 10:25 AM
slowbird's Avatar
slowbird slowbird is offline
Just a fyi when i ran a Scat crank at the 1000hp level with steel rods we could never get the mains to look great. The more we opened up the main clearance the better things looked. We came to the conclusion that the crank was flexing causing the issues. We've since went to a bryant crank and are now closing up the clearances without issue. I feel the Scat crank probably would have benefited from alum rods over the steel rods. I think the alum rods would cushion things better causing the crank to flex less. Just our observation
  #43
Old 12-31-2019, 11:17 AM
Mark G Mark G is offline
I am over 1000hp Scat crank Oliver billet rods same bearing 2012 every thing checks perfect. NHRA pro stock engine builder. Will be close to 1200hp this season with the bigger jets I don't foresee any problem.. Just hang on..
  #44
Old 12-31-2019, 11:33 AM
slowbird's Avatar
That's great. How many runs have you made at 1000+hp?
  #45
Old 12-31-2019, 11:53 AM
PAUL K's Avatar
PAUL K PAUL K is offline
I'd be very curious if the person that told you this actually tested this or just guessing based on theory.
My neighbors Grandfathers best friends Uncle who lived across the street from Grumpy the Cat (RIP) tested this very same deal and found six horsepower. However they don't know how much of the power was from the two different cam cores, reduced friction or controlled windage. He felt like he completely waisted a lot of time, money and effort on the project...FWIW
BTW....he was not related the the guy that lived across the street from Tom Molnar. But did give Tom's three legged dog biscuits occasionally.
Go fast, see Elvis!
  #46
Old 12-31-2019, 12:13 PM
I have no idea motor been together 2012 I don't keep track ..LOTS ...lol
The only time IMO a Bryant crank is needed is in a boosted application 1500hp +
  #47
Old 12-31-2019, 12:16 PM
slowbird's Avatar
You've been making 1000hp since 2012?
  #48
Old 12-31-2019, 12:33 PM
Yep every time I turn on the bottle made 800hp n/a spray 250/350
My buddies ford scat 4340 2000+ hp 4" stroke no problems
Throwing money at every problem is your way of doing things .. And your still not fast..
  #49
Old 12-31-2019, 12:39 PM
slowbird's Avatar
It isn't about a Bryant crank, it's about the center counter weights, without them things flex especially with steel rods. Guys are making big power with other cranks and everyone i know of runs alum rods. Like i said just an observation based on my personal experience and based on talking to others who had similar experiences as mine.
  #50
Old 12-31-2019, 12:43 PM
slowbird's Avatar
You've been at it for 10yrs and your still not close to me and you're a couple hundred lbs lighter than me. I'll admit im not fast at all but what does that make you??
  #51
Old 12-31-2019, 02:08 PM
GTOGEORGE's Avatar
Remember in Canada their one (1) HP is only worth .78 of an American HP! LOL! JK!
GTO George
  #52
Old 12-31-2019, 02:09 PM
PAUL K's Avatar
GTO George
Go fast, see Elvis!
  #53
Old 12-31-2019, 03:13 PM
I'm slow track 12 hrs away if I had a track in my back yard like you I would be in the 7's for sure.. Yes I am close to you we are both in the 8's ...lol
  #54
Old 12-31-2019, 03:15 PM
GTO George
You LOVE Canada George you talk about it all the time ..You even race here now and then..
  #55
Old 12-31-2019, 09:44 PM
Dragncar Dragncar is offline
Mike made the steps up in power and what he told me the forged crank was fine to 1000HP, then had issues. Had issues with his Ross pistons past that too.
The fully counter weighted billet crank, reinforced billet pistons and dry sump went a long way in fixing his issues. Said he could have went without the dry sump but did not want to go through all the building and testing with the potential problems with a high end wet sump.
I thought it was now pretty much common knowledge that a Pontiac needs a fully counter weighted crank to make big power-big RPM. Especially NA.
Or you will have main bearing issues just like Brian said.
What Pontiac folks could use is a forged fully counter weighted crank like the BBC guys have for 900$. Pontiac guys would pay 1500$ for them. But the dies cost 150K and you have to wait 10 years to get your money back.
  #56
Old 12-31-2019, 09:45 PM
It appears you want some of me.........OK, got your wish.
  #57
Old 12-31-2019, 10:27 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
And once again Thanks again Aaron and Billy for sharing information on your build.
I hope that motor exceeds your expectations on longevity!!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
  #58
Old 12-31-2019, 10:54 PM
slowbird's Avatar
Sound like Mike just threw money at issues like i do or so i heard. Lol.
Mike and I shared quite a bit of info and both of us experience similar issues on some things.
  #59
Old 01-01-2020, 12:55 PM
PAUL K's Avatar
I have no idea why you are bothered by this post. It's actually very informative if you understand the basic theory of making horsepower. You need to stop smoking that California funny stuff... it will make you less paranoid (seriously it's a proven fact that stuff makes you paranoid). Not everything is about "Dargncar". In fact very little is about you!
Go fast, see Elvis!
  #60
Old 01-01-2020, 01:25 PM
If the shoe fits ...lol
