Old 06-08-2023, 08:16 PM
1968GTO421's Avatar
Originally Posted by 64speed View Post
I used the Borgeson. Its great!
If its the Borgeson 800130 box with the correct steering stops that is good news. I'm still cautious on this but pending any action for now.
Who did you get your Borgeson from with the correct A-body steering stops?
Did you have to specify that your Tempest is an A-body, not an F- or X-body?
Thankyou, David.
GTOAA--https://www.gtoaa.org/
  #42
Old 06-08-2023, 08:57 PM
64speed's Avatar
64speed 64speed is offline
I bought it from a speed shop called Yogis. I would have to lookup the number I have but it works great
The Following User Says Thank You to 64speed For This Useful Post:
  #43
Old 06-08-2023, 09:38 PM
69gtocv 69gtocv is offline
Originally Posted by JLBIII View Post
My bad Will. It worked this time. Thanks (I think) spent more than I should have, again.
You got lucky! I just tried that 10% code and Summit told me it could only be used once and it must have been you!
  #44
Old 06-09-2023, 03:48 AM
64speed's Avatar
Thankyou, David.
Did you know the Borgeson facility and sales office is in Travelers Rest?
  #45
Old 06-09-2023, 07:31 AM
grivera's Avatar
grivera grivera is offline
You may have to call in- that code is on a catalog I got from the Cruisin’ Ocean City Maryland event and thousands of people likely have the same one.
Will Rivera
  #46
Old 06-09-2023, 07:39 AM
roger1's Avatar
roger1 roger1 is offline
The Borgeson 800130 has 88 degrees of total travel. A stock Saginaw 800 A body box as well as 67-81 F Body 800 boxes have 87 degrees. Virtually the same. All owners of the Borgeson box that have posted in this thread have said they work great in their cars.
It's only the 3 generation of F Bodies that had boxes that limited the travel of the Saginaw 800 from 60 to 70 degrees of travel according to this article:
https://www.motortrend.com/how-to/cc...g-box-upgrade/
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
The Following 3 Users Say Thank You to roger1 For This Useful Post:
  #47
Old 06-09-2023, 03:35 PM
1968GTO421's Avatar
THANKYOU David, I didn't know that. Wow that's within 3 miles of my house. I need to check that out!
Post#46 by roger1 seems to resolve the difficulties surrounding A-body vs F-body steering boxes and travel stops.
  #48
Old 06-09-2023, 05:04 PM
I found a quick ratio power steering box for my ‘64 Le Mans convertible in the local Pick-Your-Part yard for $40. This was over 20 years ago, good luck finding anything like that nowadays in one of those yards.
I pulled it off of a ‘79 -‘81 WS6 T/A, I scouted out a box that showed no signs of seal leakage that i could clean, paint and use it as-is. The steering coupler and lines all mated right up. I put a seal kit in my power steering pump and it’s working fine, so there are ways to get a quicker power box on the cheap.
I’m guessing this one is a 15:1 ratio as it has 3 turns lock to lock, much nicer than that 4-1/2 turn original power box. Seems to make low speed turns while parking and U-turns just fine, I don’t have to make a 10-point turn just to turn around on my street.
  #49
Old 06-09-2023, 05:22 PM
Sirrotica's Avatar
Back in the 70s, early 80s, one of the first things to get removed from second gen T/As was the steering boxes in yards. I've swapped a good many back in the day. They were usually under 50 bucks used.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #50
Old 06-09-2023, 05:24 PM
70GS455 70GS455 is offline
The Carhex box is affordable
Sent from my SM-S901U using Tapatalk
  #51
Old 06-09-2023, 06:04 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I could have sworn I read A body and second gen F body cars have a different degree of turn one with stops the other without.
Skip Fix
The Following 2 Users Say Thank You to Skip Fix For This Useful Post:
  #52
Old 06-09-2023, 06:10 PM
Schurkey Schurkey is offline
I found a quick ratio power steering box... ...off of a ‘79 -‘81 WS6 T/A, The steering coupler and lines all mated right up...
1. Your original PS hoses should be set-up to seal against an inverted flare. The new box should be set up for an O-ring seal. There's an adapter insert kit that can be pounded into the new box to provide an inverted flare seal. No idea why yours isn't leaking. Are you using the hoses from the new box on your vehicle, or your vehicle's hoses on the new box?
2. The F-body uses steering stops in the box. Probably about 30--35 degrees of Pitman arm travel. The older A-body would use steering stops on the knuckle and lower control arm, and 45-ish degrees of Pitman arm travel. So again, I don't understand how you're not seeing a restricted turning radius.
  #53
Old 06-09-2023, 07:44 PM
The article specifies that the 3rd Gen F-body boxes have restricted travel. It doesn't say that the 1st and 2nd generation boxes don't have restricted travel.
Look at one of the actual references that article mentions:
https://www.chevelles.com/threads/sa...#post-11389061
Most 1st and 2nd Gen F- (and similar-year X-) bodies are restricted to ~70 degrees of travel. About 35 degrees either direction.
A '75 Nova (X-body) steering gear DESTROYED the turning radius of my '68 'Camino.
I was wrong about the PS hose connectors on the '79--81 F-body box posted earlier. The hose connectors changed for '80, I thought they changed earlier than that. If he got a '79 box, the hose connections would have been a direct match for the existing hoses on the vehicle. If it was an '80--'81, the hose connections would have been the O-ring style instead of the inverted-flare.
The Following User Says Thank You to Schurkey For This Useful Post:
  #54
Old 06-09-2023, 09:25 PM
1968GTO421's Avatar
I may check out Borgeson's facility for the hell of it. But possibility of getting a box with restricted travel is money I can't risk since there doesn't seem to be a way to check it easily without taking the box apart. I've checked boneyards for a 75 mile radius and only found "antique" cars from the 1980's. Older ones were sent to the crusher years ago. No good chance of finding a good used box there.
I believe I need to stay by my words in post #39. Thanks to all who have posted here with good info.
  #55
Old 06-09-2023, 09:50 PM
roger1's Avatar
You don't have to worry about it with the Borgeson 800130. It's a completely new box, not a rebuilt and it is stated by them that it has 88 degrees of travel.
  #56
Old 06-09-2023, 10:05 PM
1992--1998 Jeep GRAND Cherokee steering gear is a near-drop-in replacement for the '64--'72 A-body.
Fast ratio, second-biggest torsion bar. ~88 degrees of Pitman arm travel--about 44 degrees each way. Almost perfect.
Dirt-cheap at a Treasure Yard. Clearly, you want one from a sealed system so there's no dirt or water entry, and low-mileage would be recommended.
Will require new-style O-ring hoses, or the inverted-flare adapters with original style hoses, or the O-ring-to-37 degree flare "JIC" connectors for hot-roddy PS hoses.
Needs a commercially-available rag joint assembly, but your rag joint is probably wiped-out and needs replacement anyway. MAYBE you can adapt the Jeep U-joint system to the A-body steering column, and if so, that would be better still.
I'd prefer a genuine Jeep unit scored at a Treasure Yard, however you could roll the dice on a rebuilt unit from your favorite parts-store (NAPA, O'Reillys, Advance, etc.) but you need to know that the mass-market rebuilders DO NOT guarantee that they use "correct" torsion bars or "correct" gear ratios in the rebuilt units.
  #57
Old 06-09-2023, 10:40 PM
I didn't call in but I did a chat session about it. They wouldn't budge so I told them I would go elsewhere. Ended up getting one from Jegs at a discount as well.
  #58
Old 06-11-2023, 06:06 AM
64speed's Avatar
Summit has really gone down hill. I tried a lot of different stuff on this car that sometimes did not work. About a year and a half into this build they sent me a letter that told me I was gonna lose my shopping privileges if I didn’t stop returning stuff because I had a 28% return ratio. I called and explained my position and the lady I spoke to was rude. I shop anywhere I can but Summit now if I can. They ruined a 27 year relationship with a “corporate” letter.
  #59
Old 06-11-2023, 09:13 AM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
Back in 2010 I installed a gearbox from Napa 88-277060. The box is still in use and serves me well for LONG distance driving, carving the Tail of the Dragon, some Autocross and semi-daily usage. If there was any reduced turn radius, it is nothing that I have not been able to live with.
(back in 2010 it was $139.00 out the door...)
https://www.napaonline.com/en/p/NSP8...pressionRank=1
1966 GTO Resto-Mod. 2nd owner California car, Factory Air, Power Windows, Kauffman Heads, March Serpentine, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R Level 3, Yank 2400 Stall Converter, Dutchman Axles, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust, Continental ExtremeContact Sport 02
  #60
Old 06-11-2023, 09:33 AM
Formulajones's Avatar
A 28% return ratio? Yikes!! LOL
https://youtu.be/XqEydRRRwqE
