Old 03-02-2025, 02:33 PM
Schurkey Schurkey is offline
Originally Posted by grivera View Post
So they’d be ok with the temps being below 150- assuming you could get it that low?
I wouldn't be. I'd want 170--200-ish. Newer cars go hotter, they don't even turn on the electric cooling fan(s) until 210 or so.
  #42
Old 03-02-2025, 05:38 PM
59safaricat 59safaricat is offline
Mine never gets above 140F bypassing the radiator. I have started and driven it in below zero weather with no problems. If the temps are freezing or cooler, let the trans warm up a few minutes. The engine will need to warm up a few minutes before driving, anyway.
  #43
Old 03-02-2025, 06:48 PM
grivera's Avatar
grivera grivera is offline
My bird has a 4l80e with a tsp converter, auxiliary trans cooler and the cooler in radiator - stays between 160-190 normally.
Will Rivera
  #44
Old 03-02-2025, 06:52 PM
ta man ta man is offline
Transmission temps not engine temps.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
  #45
Old 03-02-2025, 07:41 PM
turbo69bird's Avatar
Heat kills transmissions , cold doesn’t
Why would it?
Trans fluid doesn’t thicken like motor oil.
There’s no reason why a cool (let’s face it we aren’t talking cold at 100 degrees. ) transmission would be hurt by that temp?
When we fly airplanes we wait for 100 degree oil temps to do our run up. 1700 RPM w prop torque on it. And that’s an engine with aircraft oil in it .
Keep in mind these airplane engine max RPM is 2600 drop dead max.
960 HP @ 11 psi, 9.70 at 146.
  #46
Old 03-02-2025, 07:53 PM
Yes. Transmission fluid in the pan at 170--200 ish. Newer vehicles can be warmer than that, since the radiator isn't fan-cooled until 210 or so, so even the "cool" tank of the radiator--where the trans cooler lives--is going to be plenty warm.
  #47
Old 03-03-2025, 08:10 AM
My 2019 GMC trans fluid never gets that hot even when towing.
The Following User Says Thank You to ta man For This Useful Post:
