#41
Here’s the old yet still valid HO racing recommendations for camming and gearing a 350.
The gearing recommendations are probably even more valid today with the under 10 to 1 compression that needs to be run.
| The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
#42
What's a 524886 cam? Assuming it's Pontiac, where was it used?
#43
The 524886 was known as the number 6 hydro cam .
It was only used in 58 thru 62 motors and is a tad hotter then the 067 cam. The 886 has 60 degrees of overlap while the 067 has 54.
| The Following User Says Thank You to steve25 For This Useful Post: | ||
#45
I’m looking to stroke my 350 with a 4.00 kit from butler. Is there a way I could contact you for info? Sent from my iPhone using Tapatalk |
#46
You should be able to message me through my member profile page.
#47
I see no one commented either positively or negatively on my reduce the weight comment.
While lots of folks are concerned about power, one can easily pull a quarter of a second off a quarter mile time, and with some careful planning and purchases, more than 1/2 second while EVERYTHING else is left alone. Easy reductions: Aluminum wheels Aluminum intake manifold Less easy reductions: Aluminum transmission case Aluminum rear drums (in some cases) Distributor housing (both CI and AL used) Water pump housings same as above And you can go overboard if you have a mind to do so (an AFB weighs less than a Q-Jet or Holley, and a TQ weighs even less). Not going through everything, but I took almost 500 pounds off of a 1974 GTO. That is 8.6 percent of the shipping weight for the car. Jon
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
#48
-Fiberglass/Carbon Fiber hood and trunk lid. -Wilwood replacement calipers to replace the iron units -Aluminum radiator -Gear reduction mini-starter Not all of these are cheap, but between those 4 items, there's an additional 50-75 lbs of weight off the vehicle without touching anything that would start to make the car suck to drive. If the car has drums all around, I'd swap to 4 wheel 11" discs with the Wilwood d52/d154 calipers. More repeatable stopping power and much less unsprung weight on the car. Headers are sometimes lighter than manifolds, but I didn't specifically include them because they can at some points start impacting quality of life via ground clearance and added noise.
#49
Sure you can pay for some lightweight components, some cheap and some crazy expensive.
And you can strip out insulation, power accessories, comfort accessories like air conditioning and heating etc, etc, etc. I stripped over 300 pounds out of my 1964 GTO 455 HO powered bracket car by removing seats, carpet and floor insulation, inner fenders, radio, heater, wiper assembly and such. Mostly to reduce drivetrain stress and breakage, less to improve performance because I was bracket racing not class racing. I eventually put almost all of those things back when I was done racing the car. Honestly when you’re starting a build and going to be down on cubic inches just to prove a point I just don’t see the point of that. Just build more power with a larger engine to begin with for pretty much the same money. Buying a bunch of lightweight body parts and taking weight out of the car is much more expensive than just upping the cubes from 383 or 388 to 461 or 467. On the street cubic inches are your friend. I’d rather have a lightly modified 455 than a heavily modified 350, less stress and lower RPMs required with more inches. Back about 45 years ago one of my younger brothers friends had a very nice 1969 Charger with a 318. He did end up with a 440 in it, and eventually stripped several hundred pounds out of it by removing most of the interior, air conditioning, heating and whatever else. Took what was a decent cream color original paint job and primed it flat black. It was a teenager’s hot rod and we really didn’t know that this car would be so valuable today. But even back then I had to just shake my head knowing he had essentially ruined what started out as a very nice car. ![]() Just add cubic inches during the build, it’s free horsepower. Being a Pontiac there’s no big block or small block so almost all the same engine parts interchange between small and large cube engines, we should consider ourselves lucky that it’s easy to take advantage of more cubes in the same package.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
#50
B-Man - I will completely agree about the cost of building an ultra high performance 350 and a mildly modified 400 to get the same power. In my neck of the woods, 455's have been "son, haven't had one of those for years" for decades; while obviously the power potential is greater, not sure about the cost.
Much of my weight savings was because I NEEDED different parts, and the aluminum was not that much more: Steel wheels were insufficient width for the tires I wanted Desired wide ratio transmission Using original RAIV intake with no crossover I still have all inner fenders, insulation, seats, uphostery, etc. When different parts are going to be used, why not lighter parts. The problem I now have is the low first gear, the reduced weight, and the power is too much for the tires; I guess I went overboard ![]() Jason - I looked unsuccessfully for years for someone with an English wheel to do hood and deck lid; is fiber even an option for a 1974 GTO? Jon
#51
https://www.vfnfiberglass.com/73-74gto.htm There's a ton of people these days that can custom create almost anything from glass or carbon. You pay for it though unfortunately.
#52
We build Pontiac 350's occasionally. The builds are usually for older cars that still retain their original motor. We just built two recently. The one gentleman owned his Firebird since 1974 when he was in high school. He originally wanted us to restore the original two barrel. I talked him into doing a period correct build and we used headers, a vintage aluminum intake manifold and a Holley 600. The other guy wanted more power, but to run on 87 octane. We used a 4.25 stroke crank in that engine.
Both guys were happy with the results. |
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
#53
Franks Pontiac has 8 400 blocks and 5 455 blocks for sale on his site now.Not cheap but he does a great job describing what he sells.FWIW,Tom
#54
Appreciate these 350 threads. As the owner of an original, survivor ‘68 350 2bbl Lemans, I like the subtle options while keeping it stock appearing. I have a drop in TH350 to replace the ST300. Also planning a 4bbl, 067/2800 cam, 60psi oil pump and a move to dual exhaust. Car runs so good now, that I don’t have the motivation to take it apart yet though…maybe someday. Thanks for all the 350 tips!
