Old 08-13-2025, 05:46 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
John: politely asking how your fuel hose were rigged. I know it is still quite raw but as in FAA air worthiness directives you may save others from the pain if we can learn from your tragedy.
After seeing this damage, I went to check my EFI high pressure fuel line, and discovered some chaffing of the line from rubbing against the transmission housing and back of the block, WOW! I enclosed the fuel line with about 20" of 3/4 rubber fuel line, essentially forming a conduit. So guys who are also running your high pressure EFI along the frame and back of the block near the transmission case, check it now. Sorry for your loss, but thanks for the heads-up.
The Following User Says Thank You to 68WarDog For This Useful Post:
  #42
Old 08-13-2025, 07:01 PM
gman005's Avatar
gman005 gman005 is offline
Originally I had run like a stock fuel line. I couldn't get it to run right. So I brought it to a shop. It ended up being a bad efi unit so the shop bought a new unit and installed it at that time they rerouted the fuel line behind the back of the engine.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
The Following User Says Thank You to gman005 For This Useful Post:
  #43
Old 08-13-2025, 07:06 PM
Perhaps your insurance company should have this information along with the receipt for the work.
Faulty fuel line installation caused that fire almost certainly.
