Old 12-20-2015, 05:49 PM
The Boss's Avatar
The Boss The Boss is offline
That's a very rare & valuable exhaust manifold!!!
And go racin' in the street.
  #702
Old 12-21-2015, 08:46 AM
wovenweb's Avatar
wovenweb wovenweb is offline
I'll try running with just the one, I don't think it is going to work well...
  #703
Old 12-27-2015, 11:22 PM
wovenweb's Avatar
Originally Posted by BigJoel View Post
Ram Air 2 Heads on E-bay
http://www.ebay.com/itm/181967258588?
What will they bring?
Bid to $US 1,782.11 but didn't hit reserve. I did inquire, the owner did not have any flow numbers on the heads. That along with no shipping makes it a bit more difficult of a sale.
  #704
Old 12-28-2015, 12:13 AM
1971455HO's Avatar
1971455HO 1971455HO is offline
I agree on the no shipping!
I'm guessing no flow numbers because he didn't finish them, just bare cores with new guides &seals. I expected them to be pricey, and I would have bid, but local pick up only knocks that in the head. 2800 miles between me & him.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #705
Old 07-06-2016, 07:59 PM
70L34 70L34 is offline
This is one of my favorite threads. Since I am new to Firebirds in general, can someone summarize the telltale signs of a RAII Firebird in case I am lucky to ever come across one?
  #706
Old 07-06-2016, 08:29 PM
PurelyGTO68 PurelyGTO68 is offline
I believe all RA II cars have a build date of 05C or later (3rd week of May) so anything earlier would not be a candidate. Also must be a non-A/C car.
If you find a car that meets those first two criteria then other clues would be round port heads with "R" and "A" on the end exhaust ports, Ram Air pan and hood baffle, open hood scoops, HD axle with 3.90 or 4.33 gear set and M-21 trans (if manual). I think many or most F bodies had the 3.90 gear set but the 4.33 may have been available as an option.
If you find a car with some or all of these items then a PHS inquiry will confirm or deny RA II heritage.
Sent from my XT1585 using Tapatalk
  #707
Old 07-06-2016, 08:51 PM
1971455HO's Avatar
For identification purposes 1968 RA II heads are as follows: Code # 96, Casting # 9793596, Screw in Studs, 2.11 intake, 1.77 exhaust, Volume 71cc.
These are good high compression round port heads. RA 1 & RA III are also good heads, however, they are D-port. Not saying you can't get D-ports to flow great numbers, but for the sake of describing RA II heads, remember they are early round port heads.
If you happen up upon an abandoned 1968 firebird and you see heads attached to an engine that bear this description, you may wish to take a much closer look at what you have found.
Verify the casting numbers to be sure. Don't mistake 1971 400 Cu In #96 heads for these. The 71's are great for bumping up the compression on 455 engines with their 96cc volume, but won't do much for your 400 engine.
Hopefully, other guys will chime in and give you a lot better quick reference than I can.
Ol' man Smith
Son video'd this...
  #708
Old 07-06-2016, 11:58 PM
Thanks guys, this is exactly what I was looking for.
  #709
Old 07-08-2016, 12:29 PM
ID wise, early heads are marked R on one end exh port and A on the other, later castings are 96. If the Firebird has Round port heads, pay the guy before he figures out what he has. Look at the difference between D port and O port, (middle exhaust port area) and you will be able to spot them across the parking lot. Of course there are many O port heads, RAII, RAIV, 455HO, 455SD,along with Aluminum Edelbrock, Kauffman, etc. But any O port head will be worth more money, along with Exhaust Manifolds/ headers.
Bill Nye.
  #710
Old 07-08-2016, 05:59 PM
My RAII heads have both casting marks.... R, A and 96. It is my understanding that early heads had R on the left exhaust port, two center ports blank and A on the right exhaust port. Later heads added 96 on the center ports but the R, A remained.
If this is correct, then it is super easy to identify RA II heads with zero chance of confusion by looking for the "R" and "A" cast marks on any round port head. Some may have 96 on the center ports while others may not so it isn't really that important for identification purposes initially.
  #711
Old 07-08-2016, 06:08 PM
The Boss's Avatar
The #96 cast on the center exhaust ports appeared some time during the night shift of D228, the heads cast from the day shift do not have it and ALL of the heads cast on D238 have the 96 as well (along with all of the ones cast after that).
My heads are the non 96 ones.
The heads on this motor are not the ones I have now but identical to them.
  #712
Old 07-08-2016, 09:15 PM
Did not know that! That's odd they changed castings in the night? I think my heads may be D228, Marked R A .
Bill Nye.
  #713
Old 10-28-2023, 01:35 PM
1oldgoat's Avatar
1oldgoat 1oldgoat is offline
Looks like this thread has been quiet for years. Is there an updated list of know RA II Birds?
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor
68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black
68 Firebird 400 Conv. Auto, Red/Parchment/Parchment
69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor
71 GTO 455HO 4spd, Lucerne Blue/Black/Black
71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue
  #714
Old 12-14-2023, 03:05 PM
RA1John RA1John is offline
I started a Registry for '68 RA Firebirds around 30+ years ago. Collecting anything I can find regarding surviving RA & RAII Birds. Currently updating the matrix. While most owners are glad to help, some prefer to not share details so there are some gaps.
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
  #715
Old 12-17-2023, 02:54 PM
BirdBrain BirdBrain is offline
This thread is extremely out of date. You should start a site, John. You have the info on both of my RAII birds...both of which are not in this Roll Call since I found both in the last two years.
Ambition is a dream with a V8 engine. -Elvis
  #716
Old 12-17-2023, 03:36 PM
johnta1 johnta1 is online now
I have a rudimentary page I had set up for the RAI & II. John had sent me some of his data, which I included. Not sure how updated it is though.
Most data is from this site or from John. I may have added some of my data.
RA I & II
That page also has a link for the form to send/update info.
  #717
Old 09-14-2024, 06:56 PM
RA II GTO on BaT with a 455 in it. (no mention of RA II until end)
68 GTO
  #718
Old 09-15-2024, 09:58 AM
68pongto's Avatar
68pongto 68pongto is offline
It is almost a twin to my RA II except for 4-speed and hideaways! It's amazing that they are still surfacing. I like how the guy just kind of nonchalantly mentions that it is a RA II at the very end?!
  #719
Old 09-15-2024, 03:56 PM
wovenweb's Avatar
68 GTO
Maybe they changed the ad but this was the first line now and honestly what I recall reading last night:
  #720
Old 09-15-2024, 05:56 PM
You're correct.
I didn't notice it. Just saw that it had a 455 in it.
When I saw the BHC, I knew it was a RA II. Then read it again (guess not well) with the 455 being built and Aluminum heads and didn't see it mentioned until the end.
