Old 12-02-2014, 10:23 PM
marks73ta's Avatar
marks73ta marks73ta is offline
Don, dumb question but are your valve covers a bolt for a stock Pontiac bolt pattern? Such as my KRE D-Ports? I really like the shape of those and I need clearance for poly locks and girdle. Thanks.
Mark
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
  #722
Old 12-03-2014, 09:51 AM
dci dci is offline
Yes they are. They will fit any Pontiac head as long as it has the factory Pontiac bolt pattern. These are cast aluminum and you may need to clearance them in spots to clear some stud girdles. They are right around .180" thick though so you don't need to worry about grinding through.
Don Johnston
DCI MOTORSPORTS LLC.
330-850-5050 shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 heads !!!!!!
  #723
Old 12-03-2014, 09:57 AM
dci dci is offline
I decided to extend my Black Friday sale until the end of December for those who might be getting that big Christmas bonus!!!!! See the classifieds.
Happy Holidays!!!
Don Johnston
330-850-5050 shop
330-628-3354 cell
  #724
Old 12-04-2014, 10:54 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Two sets of these neat heads are under construction here now. These arrived very securely packaged. IMHO these are high quality castings with no visible porosity. The machine work appears to be of very high quality/accuracy. No issues with these. Thanks again Don for your valiant efforts.
  #725
Old 12-05-2014, 08:59 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Hey Jim,
Keep the updates coming, plenty of interested parties are watching this. Can you provide any details on the 2 builds you're working on?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #726
Old 12-06-2014, 12:03 PM
dci dci is offline
Thanks Jim for the kudos!!! Please do keep us all up to date with your progress. It's an honor to have people such as yourself working with my heads. The builds that your involved with are really cool builds, and I am as excited about seeing the results as your customers are. Keep us posted!!!!!
Happy Holidays!!!
Don Johnston
330-850-5050 shop
330-628-3354 cell
  #727
Old 12-06-2014, 12:15 PM
dci dci is offline
I do have the water cross over configured and test fitting it right now. Here is a pic of what I came up with. I know some of you want a stock appearing part. So what I did was scan the water cross over from a 1965 Tripower intake and reconfigure it for my intake. That way it still resembles a factory look and a bonus is that the thermostat is easy to get to. Sorry I only have one pic right now to show, but I will be taking more.
Happy Holidays!!!
Don Johnston
330-850-5050 shop
330-628-3354 cell
  #728
Old 12-06-2014, 06:59 PM
RAMAIR RICK RAMAIR RICK is offline
Don your intake water crossover looks like it will interface with the factory style, timing cover back side for coolant flow, is that a correct assessment of it? Also what factory style Thermostat housings are able to bolt onto to your new water crossover design?
Thanks in advance
I can see all of your pieces of the DCI Ram Air V are coming together nicely.
  #729
Old 12-08-2014, 12:05 PM
dci dci is offline
Thanks Rick for your support and enthusiasm for my new heads. It's guy;s like you that keep me going when the going gets tough. My water crossover will indeed interface with the factory timing cover just like the factory set up. It will still need the rubber o-ring that goes in between it and the timing cover. This is basically a copy of the factory 65-66 tripower water crossover just tweaked a little for my intake. So a factory or readily available reproduction water neck will bolt on without any modification. I also kept the boss for the water temp sending unit. I am fitting this to the engine right now and will post pic's as I progress. As you can see I made the part with an FDM printer so that I could physically fit the part on an actual engine. This way there is no guessing whether or not that it will work.
Don Johnston
330-850-5050 shop
330-628-3354 cell
  #730
Old 12-11-2014, 04:25 PM
dci dci is offline
Posted some more pic's over on facebook if anyone is interested of the water crossover I am making for my intake. I set the intake on the heads and fitted the crossover before making the final drawing modifications for the tooling. The pic's below are from the cad drawings of the part that we scanned and used to print it as a solid part. I have the actual crossover fitted on the engine in the pic's on facebook.
Don Johnston
330-850-5050 shop
330-628-3354 cell
ID:	384183   Click image for larger version
  #731
Old 12-21-2014, 10:29 AM
shaker455's Avatar
shaker455 shaker455 is offline
Hi Don,
I'm not sure if this was asked but what are you doing for rocker arm & pushrod locations for your RAV?
Jeff
Carburetor building & modification services
Servicing the Pontiac community over 25 years
  #732
Old 01-29-2015, 01:07 PM
dci dci is offline
I just received a shipment of DCI RA5 intakes. Bolted one on to check bolt hole and port alignment. Everything looks spot on.
ID:	388729   Click image for larger version
ID:	388730   Click image for larger version
ID:	388731   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #733
Old 01-29-2015, 01:11 PM
dci dci is offline
Jeff, sorry some how I missed your post on 12-21-14. My heads can be run with a stud mounted rocker like Harland Sharp with guide plates. I also contracted Harland Sharp to make shaft mounted rockers with ratios from 1.5 up to 1.95. I just got them in as well and will take some pic's and post them here when I get a chance.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #734
Old 01-29-2015, 08:28 PM
blueghoast's Avatar
WOW I'd marry those if I weren't married. LOL
Man that stuff is very impressive. Some day Some day.
Going to own a set of them. Thanks for the eye candy.
GT.
  #735
Old 01-30-2015, 12:40 AM
Curious George's Avatar
Curious George Curious George is offline
That is the coolest thing I've ever seen in my life!
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
  #736
Old 01-30-2015, 11:00 AM
dci dci is offline
Thanks guy's, I really appreciate the compliments!!!!
I finally got the Harland Sharp shaft rockers. These are 1.95-1 ratio, but they can make these in any ratio from 1.5-2.0.
ID:	388811   Click image for larger version
ID:	388812   Click image for larger version
ID:	388813   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #737
Old 01-30-2015, 11:16 AM
mysticmissle's Avatar
Nice pieces. Price range of shaft set up?
  #738
Old 01-30-2015, 11:25 AM
dci dci is offline
Thanks!!! Projected to be Under a $1,000.00.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #739
Old 01-30-2015, 11:44 AM
The Boss's Avatar
The Boss The Boss is offline
That's some really sexy **** you've got there Don!
And go racin' in the street.
  #740
Old 01-30-2015, 12:34 PM
estep455's Avatar
estep455 estep455 is offline
now that's awesome!!!!!!!!
