Old 06-01-2018, 04:35 PM
poncho4554spd poncho4554spd is offline
I decided to do a little work on the hood before fitting the front sheet metal. It looked as though the hood was stored on its side in a wet area or possibly on dirt in a shed or something. About 3/4 length of the one side of the hood where the outer skin is attached to the inner skin it had rusted in between the 2 layers and had thick layers of rust scale to the point of spreading open the seam slightly. I cleaned it all out with a sharp pick and sandblasted all around the areas. Lucky the pieces are still solid enough to be ok. After sandblasting I treated the bare metal with a metal conditioner, then sanded scuffed and epoxy primered. Next step will be to squeeze some panel bond in a few areas of the spreaded side seam for a little extra strength and the close back tight. Then onto the top and finally start fitting the front sheet metal.
ID:	484406   Click image for larger version
ID:	484407   Click image for larger version
ID:	484408   Click image for larger version
  #742
Old 06-08-2018, 05:00 PM
I put a little 3m panel bond between the inner and outer skins on the passenger side of the hood and squeezed everything tight back to where it should be and let set up for 24 hours then removed the clamps and sanded the edge so it now looks correct. The top side had a bunch of surface rust here and there so I sandblasted carefully to remove the heavier rust and primer. I DA sanded with 80 grit. Next I will hit it with a metal wash, fix some dents and epoxy prime the top side.
ID:	484951   Click image for larger version
ID:	484952   Click image for larger version
ID:	484953   Click image for larger version
  #743
Old 06-13-2018, 10:48 PM
I treated the hood to a BASF acid wash, sanded some more and began the body work. I will finish the body work with 180g and epoxy prime then guide coat.
  #744
Old 06-14-2018, 07:52 AM
Ready to spray the epoxy.
ID:	485270   Click image for larger version
  #745
Old 06-14-2018, 08:13 PM
Epoxy is down on the top of the hood and will be ready to block sand. Next step will be to start bolting the front end on to refit everything then start on the doors and quarters and epoxy them. I will then block sand the and fix any remaining issues found then reprimer and block again
ID:	485313   Click image for larger version
  #746
Old 06-14-2018, 09:48 PM
necdb3's Avatar
necdb3 necdb3 is offline
Going to Johnson's tomorrow night?
  #747
Old 06-14-2018, 10:19 PM
Probably not tomorrow, my son has a baseball game but hope to get up there for the next one. I would like to get a closer look at your TA. I saw it before parked up there but wasn't able to get a closer look.
  #748
Old 12-05-2018, 07:43 PM
necdb3's Avatar
Any updates?
  #749
Old 12-06-2018, 07:40 PM
[QUOTE=necdb3;5963380]Any updates?[/QUOTE
I took a break on the car to work on outer wheel houses, quarters, trunk drops and tail panel on my 74 super duty. I did assemble and fitt the front end, then removed. It has been block sanded, and touched up where needed. Doors have been stripped and am getting ready to epoxy them. The parts will be painted with a coat of Lucerne blue soon, then the shell painted separately and assembled.
  #750
Old 05-23-2019, 09:51 AM
Been doing some work on and off on the car. Just wanted to post the progress as I said that I would.
ID:	512769   Click image for larger version
ID:	512770   Click image for larger version
ID:	512771   Click image for larger version
ID:	512772   Click image for larger version
  #751
Old 05-23-2019, 09:57 AM
Some more pics of body work needed on the doors and deck lid
ID:	512774   Click image for larger version
ID:	512775   Click image for larger version
ID:	512776   Click image for larger version
ID:	512777   Click image for larger version
  #752
Old 05-23-2019, 10:03 AM
Parts in epoxy waiting first blocking
ID:	512782   Click image for larger version
ID:	512785   Click image for larger version
ID:	512787   Click image for larger version
ID:	512788   Click image for larger version
  #753
Old 05-23-2019, 10:07 AM
The shell starting to be stripped.
ID:	512790   Click image for larger version
  #754
Old 05-23-2019, 10:16 AM
Hood, doors and decklid primed with filler primer and blocked. Under hood painted black, and finally some color on some of the sheet metal.
ID:	512792   Click image for larger version
ID:	512793   Click image for larger version
ID:	512794   Click image for larger version
ID:	512795   Click image for larger version
  #755
Old 05-23-2019, 11:50 AM
unruhjonny's Avatar
I have a question for you, or anyone else who might care to speak up;
What is the way that hoods were painted originally?
I seem to often see paint being applied to the top of the hood, with the bottom masked off;
But I would think that paint would have been applied to the top and edges, with overspray observed on the underside.
If I am guessing correct, this picture shows that the top was painted, and the hood is upside down about to be masked for the edges to be painted.
looks great!!
This is inspiring for people like me.
1970 Formula 400
  #756
Old 05-23-2019, 01:40 PM
looks great!!
Thanks. Our buddy has been helping some also when his shop is slow. Im not sure the technique from factory. In this case the blue you see is tinted primer on the top side. The hood was flipped, taped and painted rally black. Next it will be sprayed on the top and outside edges in topcoat.
  #757
Old 05-23-2019, 04:26 PM
Norwood's Avatar
Norwood Norwood is offline
Over spray on the bracing would be correct
  #758
Old 05-23-2019, 04:40 PM
unruhjonny's Avatar
ok - thanks!
Do you have, or know someone who has collected images of under hood overspray?
1970 Formula 400
  #759
Old 05-23-2019, 08:59 PM
Norwood's Avatar
Here is one that I have, this car is a low mile survivor 1973 Buc Red Trans Am
  #760
Old 05-24-2019, 08:11 AM
Judge273's Avatar
Judge273 Judge273 is offline
Pretty sure they way we repaint our cars is no where near how the factory did.
Overspray is a indication that masking tape wasn't in the mix at the body paint station.
Mike/Illinois
