Old 11-22-2010, 04:19 PM
SD421's Avatar
SD421 SD421 is offline
Originally Posted by SupergasDil View Post
Rear American Torque Thrusts and Hurst cheater slicks
Dil, Sweet project!!!! What size wheels and what are the slicks capped on? Im kinda going for the same look with my 66 goat but Im going to be running steel black wheels instead.
-sd421
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
  #62
Old 11-22-2010, 05:19 PM
Brian Baker's Avatar
Brian,
There is a guy out in Oregon that is reproducing Hurst tires using the original tread molds. They are putting most of them on new radial casings. Same deal with my front HURST Super Cushions. If you are building a nostalgia ride you gotta put the right tires on it. Check out all of the great options he has at www.hurstracingtires.com
Thanks for the link...this is FAR OUT !!!
  #63
Old 11-22-2010, 10:11 PM
SupergasDil's Avatar
SD421,
Check out the link http://www.hurstracingtires.com/ it has all of the info for each tire. I'm running 4 1/2" rims on front and 7"s rear with an 8 1/2" tread. I know they are narrow. My friend Nck Anderson with the 62 Tempest gave me the Americans and with the offset they have it's the widest tire I could put under the body. Maybe I'll go wider later down the road but for now, that's it.
  #64
Old 11-22-2010, 10:23 PM
SD421's Avatar
SD421,
Cool, thanks for the response. Ive been up on their website many a times drooling. Was just wondering what size you are actually using cause I think our cars are alike in the rear wheel fitment area.
Are you running 15" wheels? Are they the HURST 28 3/4"x8 1/2"x15" PIE CRUST cheaters capped on RADIAL 235/75/15
Also, the company that you bought the front axle kit from. Is it the Chevy kit ??
Thanks,
Don
1966 GTO
KRE Tri-Power
  #65
Old 11-22-2010, 11:22 PM
SD,
Yes on the tire size size and 15" on the rims. Only dif is that my tires have the 2 grooves cut in the tread. The axle kit from speedway motors is the set up with the chevy spindles. You can order 4 1/2" or 4 3/4" bolt pattern
  #66
Old 11-23-2010, 01:07 AM
SD421's Avatar
SD,
Cool, thanks for the info. Cant wait to see her finished and running.
1966 GTO
KRE Tri-Power
  #67
Old 02-19-2011, 06:01 PM
The weather is beautiful which helps in the motivation department so I spent a little time working on the dash layout. I'll cut the holes tomorrow
ID:	235265   Click image for larger version
ID:	235266   Click image for larger version
  #68
Old 02-19-2011, 06:03 PM
I tried a few layouts and like this one the best. You can see the outlines of the other holes where I was moving the gauges around.
ID:	235268   Click image for larger version
ID:	235269   Click image for larger version
  #69
Old 02-19-2011, 11:16 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
So what are you going to use to cut the holes-plain old holesaw? Reason I'm doing an engine turned dash insert(from Speedway-aluminum) with Autometers foo my IA/Camaro.
Skip Fix
  #70
Old 02-19-2011, 11:27 PM
Steve Barcak's Avatar
Dil,
Have you decided what to use for your induction? carbs? injoectors? or?
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
  #71
Old 02-20-2011, 02:54 PM
Hi Skip, yes hole saw in the drill press. The speedometer I'm going to have to jigsaw and clean up with the 1/4" grinder.
Steve, Carbs on this one since she's going to be street strip. Ultimately, I'd like to put a couple of classic Holley 850's on. I have 2 Demon 850's which just aren't right for the look I want, but will probably use them to get her going. My other thought was to use a couple of Carter/Edelbrock which would be period correct in the looks department but a little less on performance and quite a bit less on cost. I know you can buy used carbs cheap but I have never had good luck with a used carb let alone 2 on the same engine. Almost $1,000 for the 2 holley 850 double pumpers, and about $600.00 for the 2 Edelbrocks.
  #72
Old 02-20-2011, 07:06 PM
Okay, I spent some more time on the dash today and made some good progress.
ID:	235381   Click image for larger version
ID:	235382   Click image for larger version
  #73
Old 02-20-2011, 07:08 PM
I couldn't find a 2 1/16" hole saw so I just used a 2" and gave a quick reem with the 1/4 grinder
ID:	235384   Click image for larger version
ID:	235385   Click image for larger version
  #74
Old 02-20-2011, 07:13 PM
I decided to go with the Stewart Warner classic gauges to keep with the period 60's look. I also chose to set the dash face out at the first ridge rather than setting it further back in the dash where the original gauses were. I moved it back and forth and just liked the closer, more straight up look, rather than leaning back deeper in the dash.
ID:	235387   Click image for larger version
ID:	235388   Click image for larger version
  #75
Old 02-28-2011, 09:38 PM
Worked on the steering column yesterday. Took off the shift indicator, cut off the shifter and gear indicator, ground down the leftovers, filled with plastic, primed and painted. Now it looks like a 4 speed column.
ID:	236219   Click image for larger version
ID:	236220   Click image for larger version
  #76
Old 03-01-2011, 11:24 AM
I use knockout punches for gauge holes etc.. Still adding to my collection but love these things.
http://www.mygreenlee.com/GreenleeDo...db_next_page=1
Your project is lookin good Dil
  #77
Old 03-01-2011, 05:20 PM
Skip Fix's Avatar
I tried cutting the outer outline in the thinner sheet with a jig saw and got alot of chatter. Any suggestions?
Skip Fix
  #78
Old 03-01-2011, 05:54 PM
Thats why I fell in love with those punches ^^^^ ! Plasma cutter and/or die grinder?
  #79
Old 03-02-2011, 03:51 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
... thinner sheet... Any suggestions?
A nibbler makes a neat cut in sheet stock.. The one I've got (air tool) handles up to 16ga steel.
  #80
Old 03-02-2011, 12:36 PM
Skip Fix's Avatar
The speedo and tach holes are 4 5/8 so probably not a punch for those. 2" will get the other gauge holes and 0.5 for the turn signals. I have a hand nibbler that didn't do too much.
Skip Fix
