Old 12-08-2013, 08:16 AM
The purpose is as 71HOT/A said.
The same reason they put that metal 'spring' thing on the cowl for the Formula hood.
  #62
Old 12-08-2013, 10:54 AM
Norwood's Avatar
Norwood Norwood is offline
This thread has become a learning experience for me....
  #63
Old 12-08-2013, 11:55 AM
njsteve's Avatar
njsteve njsteve is offline
Like I always say: "I'm not a failure, I am just an excellent bad example."
I guess I am glad afterall, to have started all this insanity with my shake-enstein resto.
The Following 3 Users Say Thank You to njsteve For This Useful Post:
  #64
Old 12-08-2013, 12:07 PM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
Shake-enstein....like it..
Didn't mean to devalue anyone's cars or parts here...But I will probably get another air cleaner form the parts bin and weld tabs on it to hold the SR shaker on the car. that was a great suggestion. Orig air cleaner and shaker will go to storage. I"ll fab up a GP air cleaner to do the trick.
And if a chance to fix the SR comes up, I'll change them to Shake-enstiens!
  #65
Old 12-08-2013, 12:27 PM
blue71ta's Avatar
blue71ta blue71ta is offline
a GP air cleaner will sit too high on the carb, you'll need to start with a Formula air cleaner with the deep, drop base. If you use the GP one, your hood won't close. Just FYI
  #66
Old 12-08-2013, 12:28 PM
2manyT/A'S's Avatar
GP air cleaner won't work.......needs to be from a W66.(if you want to close the hood)
Eye Candy......garage band?
Go full screen & turn it UP!
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
  #67
Old 12-08-2013, 12:37 PM
Judge273's Avatar
Judge273 Judge273 is offline
Ok now I'm confused? W66 is a Formula (that part I know). So you meant non RA? So if that is the case isn't a dual pre heat needed for TA? So then a modified W66 air cleaner with tabs added and another heat riser needed for a 71-72?
Just trying to learn here....
Mike/Illinois
  #68
Old 12-08-2013, 12:42 PM
transam1972 transam1972 is offline
Default 1970 brochure shaker
I mentioned this earlier...has anyone seen the curved front,no drain shaker?...had to be the prototype...and I will have mine, shaker,not stirred...oh, and think of how much they saved when 72 used the accelerator kick down switch...and in 73 even more when they deleted it...I don't buy the engine drive by noise...thoughts?
  #69
Old 12-08-2013, 02:57 PM
2manyT/A'S's Avatar
You got it.....any 70-72 Formula dual snorkel with the mods you described will work.on a T/A...
  #70
Old 12-08-2013, 03:05 PM
Norwood's Avatar
and I have the tabs.....
  #71
Old 12-08-2013, 03:28 PM
2manyT/A'S's Avatar
Off topic..not shaker parts...but relevant,I believe....
I think there is a market for these & should be simple to make....
ID:	345900   Click image for larger version
  #72
Old 12-08-2013, 03:57 PM
Norwood's Avatar
Ok what is it
  #73
Old 12-08-2013, 04:26 PM
2manyT/A'S's Avatar
Ok what is it
Hint......it's a ground strap......
  #74
Old 12-08-2013, 04:40 PM
Default ground strap
is that the ground strap used on the rear tail panel?...if so I need one, mine is mangled
  #75
Old 12-08-2013, 05:55 PM
2manyT/A'S's Avatar
Give that man a CIGAR!
Tag light ground strap.
They are almost ALWAYS rusty,mangled or missing....
The Following 3 Users Say Thank You to 2manyT/A'S For This Useful Post:
  #76
Old 12-09-2013, 10:48 AM
OK so who has a relatively junky formula air cleaner? Just needs to work since the orig stuff goes on the shelf.
any other applications, like chev Camaro or whatever?
then again maybe I can make one by adding the deep drop to another air cleaner. Can't be more complicated than hanging quarters on a GP...
  #77
Old 12-09-2013, 11:11 AM
Judge273's Avatar
Anyone try the repop air dual snorkel that is suppose to be for TA RA IV and 455 HO with tabs and lid?
Mike/Illinois
  #78
Old 12-09-2013, 11:26 AM
Unfortunately, no other applications, the snorkels are positioned differently than a '69 GTO or '70-72 GTO/455 GP dual snorkel aircleaners. Have repaired & restored a bunch of factory dual snorkels.
  #79
Old 12-09-2013, 11:30 AM
Depends on what ones building/restoring, they fit, but many differences in details of the repro drop base aircleaner.
  #80
Old 12-09-2013, 11:40 AM
Judge273's Avatar
The Keith application: For driving it, and keeping the OEM on shelf?
Mike/Illinois
