Old 06-26-2014, 04:12 PM
David Holmberg's Avatar
Other than the chambers (and plug angle) the heads are the same as the normal E-heads. Many have upgraded to roller springs without any issues. In fact I don't think I've heard of one issue with the valves supplied by Edelbrock.
  #62
Old 06-26-2014, 05:48 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Dave I agree on the valves, but if you check with Edelbrock tech they will often waffle if they are OK with roller spring pressures.
Ferrera makes many of the Edelbrock valve but to Edelbrocks specs-and they won't tell you which ones.
That is part of why on my '09 project we used a custom Manley intake and cut down a Pontiac Ferrera 6000 exhaust valve to 1.72 for it. All of my Pontiac E heads have gotten either SI or Ferreras.
Skip Fix
  #63
Old 06-27-2014, 10:25 AM
77 TRASHCAN's Avatar
Originally Posted by 900HP View Post
Here they are semi-finished
Mark,
How did your headers compare to the chassis models???
The standard wive's tale is that one installs tri-y's to pickup low RPM power, somewhat sacrificing top end...??? (especially for a street driven vehicle)
I've seen the opposite happen on a SBC engine. I had a 292 cid (283+.060) built for a driver. Was blessed to have the builder give it a whirl on the dyno (this was 1985 mind you). He tried a set of tri-y's on my engine, that had also been tried on a 355, and 406. Each engine responded the same... sacrificing low end and making more top end...compared to his standard 4 into 1 chassis headers that he ran on every SBC he tested....
Thanks!
Shut it off
Shut it off
  #64
Old 06-27-2014, 12:43 PM
900HP's Avatar
900HP 900HP is offline
Let's not muck up this thread anymore than we already have. The 4-2-1 headers when properly designed and built will make a much wider power band than a 4-1 with no downsides. There is so much to header design I don't know where to begin and I'm only at the tip of the iceberg.
As far as our 4-2-1's to chassis headers? There was no comparison. No comparison at all.
Throttle's Performance
(701) 893-5010
https://www.facebook.com/pages/Throt...70911996281602
  #65
Old 02-27-2015, 10:03 PM
AC445 AC445 is offline
Default Edelbrock cnc chamber 61515
Hello all,I called Edelbrock tech again and asked if 61515 is going to be available bare.They said not that they knew of,but they did tell me this head uses MPI valves.Does anyone know how they compare to Manley or Ferrea? Thanks
  #66
Old 02-28-2015, 01:28 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Are the springs still of poor quality?
  #67
Old 02-28-2015, 04:07 PM
shaker455's Avatar
shaker455 shaker455 is offline
I see Butler offers these 65cc as cast heads as well & will port & fit with valves...not a bad deal is they have them in stock.
I used an out of box set on a 462 & did pretty well...560hp & 600Tq
Carburetor building & modification services
Servicing the Pontiac community over 25 years
  #68
Old 03-01-2015, 11:35 AM
Half-Inch Stud's Avatar
Would be dramatically informative to run those "Long Ys" on a DYNO, then the 4- tube, then PMD Long-Branch:to generate BSFC maps with constant HP curves.
Comparison would propel our Hobby ahead in all Street, and most Strip concerns.
  #69
Old 03-09-2015, 01:59 PM
cgeise's Avatar
cgeise cgeise is offline
In stock is the key -- Edelbrock it terrible at delivering product any more --really bad.
  #70
Old 03-10-2015, 10:44 AM
Overkillphil's Avatar
shaker, did you use the 65cc ones on the 462?
  #71
Old 03-10-2015, 04:36 PM
shaker455's Avatar
Phil,
No, I had the out of box 72's fully assembled
