Old 12-11-2014, 08:49 AM
Rob B's Avatar
Rob B Rob B is offline
Default back to post #22...
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
  #62
Old 12-11-2014, 11:02 AM
Old Goat Racer's Avatar
I've run this setup for the last 10 years on 1 of my race cars. 1 motor does it all. "Race only"
Mid 11's.
Everybody knows somthin.
Nobody knows everything !
  #63
Old 12-11-2014, 09:00 PM
60man's Avatar
60man 60man is offline
Mid 11's.
Ditto...that's what I ran. Used the "trick" over drive pulleys too..
ECM member.
MANDRA
  #64
Old 12-11-2014, 10:02 PM
Half-Inch Stud's Avatar
Hey, let's not overlook the TIMER for auto shutoff.
That'sa why I ditched my electric motor belt-driven water pump & went back to a vee belt.
  #65
Old 12-11-2014, 10:54 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
Compute your pulley ratio before you change anything. I chased overheating problems on my '66 for many years....Timing, carb tuning, 3 core, big 4 core ...switched to an aluminum rad, no thermostat, 160 degree, 180 degree, 190 degree, moroso restrictor plates (all 3), new hoses...spring in the lower rad hose, 4 blade, 6 blade fan, 7 blade fan, new fan clutch, shroud no fan clutch, electric fans (2). Turns out my water pump pulley was larger than my crank pulley....effectively underdriving my fan and water pump. I went to the junkyard and asked if they'd point me towards the Pontiac section. After perusing a bunch of engines I found a smaller water pump pulley on a Pontiac engine. After switching the pilley and installing 2 different belts, my overheating problem was solved. The engine now resides in TEXAS in a first gen Firebird. No Problemo!
Divide the crank pulley diameter by the diameter of the waterpump pulley (8" diameter crank pulley and a 6" pulley waterpump pulley gives you a 133% overdriven water pump and fan. I had CVF Racing make an overdrive crank pulley kit. Works great! Check it out, do the math and let us know what you come up with. Hope this helps.
  #66
Old 12-11-2014, 11:45 PM
Probird's Avatar
Probird Probird is offline
Originally Posted by 60man View Post
Try a Moroso electric fan drive motor. Glorified heater blower motor with mounting brackets. Belt drives the water pump with pulleys. There are still lots of guys using this system. Then you still bolt a "lightweight" fan to hub. I did that for years on my 11 second motor. I could keep motor cool in lanes and pit cool down without running motor. Not sure I have pics. Wouldn't use for street.
Years ago I ran the Moroso setup too. The motor that comes with it is one speed. While at a swap meet one year I came across a guy that had a whole box of rear defrost motors. I bought a couple of them for $5 a piece. They looked just like the Moroso motor except they had 2 speeds. Low speed was the same as the Moroso motor. Using the high speed wire really picked up the water flow and cooled a lot better. That was the best $5 I spent that year.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
  #67
Old 12-12-2014, 11:37 AM
Even though your radiator is only 4 years old, it is clean inside, yes? No clogged up tubes?? Just askin..........
  #68
Old 12-12-2014, 09:00 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
^^^^The only thing that could have clogged it would be cobwebs!
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
  #69
Old 12-12-2014, 09:52 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Come on now it's an 80% drag car that's impossible
Illinois Outlaw Gassers
6.27@107
9.97@131
  #70
Old 12-13-2014, 01:18 AM
grandville455's Avatar
grandville455 grandville455 is online now
LMAO
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
  #71
Old 12-13-2014, 07:55 AM
Bud Lyons's Avatar
With a 3/4 race cam
  #72
Old 12-13-2014, 10:11 AM
I did similar in 90's only 3 speed fan motor... later found an aluminum toothed pulley in used machine scrap pile at work that was about same diameter as the Moroso pump pulley(way bigger than optional "overdrive" pulley that really isn't overdrive ratio). Scrounged up a different belt. Added a cheapy flex fan to pump as well. Low speed was good to get motor warmed if needed on cool days/nights... medium adequate for most all else... Hi got switched on when on return road and brought temps down quick. Hi sucked a bunch more amps though but that may have been the added flex fan load as it notably moved more air.
I still have the pulleys, a few belt sizes and the original Moroso motor n bracket. Moroso motor got real hot, real quick trying to run the big pulley and fan. I may revisit this with different motors/fan/better charging to test. My stock altenator didn't keep up trying to street drive with it in traffic is why I abandoned it.
  #73
Old 12-13-2014, 10:38 AM
jm455ho's Avatar
jm455ho jm455ho is offline
Where did you get the "overdrive" pulley?
www.hobracing.com
  #74
Old 12-13-2014, 02:38 PM
Gary H's Avatar
Gary H Gary H is offline
Default Good Advice
^^^^^^^^ My thoughts also
  #75
Old 12-13-2014, 06:11 PM
Probird's Avatar
Summit lists both a 10 tooth and a 14 tooth pulley.
  #76
Old 12-13-2014, 10:02 PM
60man's Avatar
Yepper...
I had mine wired to a tempt control sensor and a manual over ride..
ECM member.
MANDRA
