Old 11-01-2017, 11:13 PM
70TA-RAIII 70TA-RAIII is offline
Thanks! I'll update the thread as I work my way thru the car with clean up and maintenance upgrades.
John
Old 11-02-2017, 11:45 AM
l decided to rebuild the carb after noticing I would frequently have a different idle speed when I would come to a stop. Sometimes normal but usually high until I would blip the throttle to get it back down. I felt the throttle and it had a lot of slop in the primary throttle shaft. I ordered Cliff's bushing kit to fix it.
lt's back together and runs like new! The same idle speed every time I let off the throttle, just like it should.
I wish I would have bought Cliff's rebuild kit too, so I could get the grooved accel pump for the little rubber boot to fit in.
John
Old 11-03-2017, 11:36 PM
79firebird_99TA's Avatar
79firebird_99TA 79firebird_99TA is offline
Welcome to the forum! I too like the non-console. But I'm partial. My `79 Firebird doesn't have one .. and it has the correct hurst shifter with the 4 speed.
79 Firebird/`70 400 with `77 6x-4s shaved .065"/4 speed BW ST-10/Cliff Q-Jet/XE268/3.08
99 Trans Am/383 LS1/TSP headers and catback/custom grind cam/Vigilante 2500/Strano springs and Konis
08 Corvette - Base
(SOLD) 75 Corvette/L48 350 (LSx -4L60E one day)
Old 11-05-2017, 11:47 PM
Thanks! The car will stay non-console just like it was built.
After thinking it thru and listening to the various opinions here, pretty much everything on the car will stay as it's supposed to be.
I'll probably put in a different radio (the original doesn't work anyway) but only something that bolts in with no cutting or modification.
John
Old 11-06-2017, 09:39 AM
MUSLCAH MUSLCAH is offline
We just had a radio installed in my sons 64 GP....the radio is in the trunk....and you run it with your Smaaht Phone.....has hands free blue tooth ....a little mic near the rear view mirror....play list....all kinds of things...Slick set up.
Old 11-06-2017, 04:07 PM
unruhjonny's Avatar
John
Yay!!
I am posting this incase you don't already know it;
1) The AM pushbutton radio (as far as I can recall) is the same unit right up to 1977 - and is the easiest one to get.
2) a Pontiac enthusiast has created a device which makes worrying about upgrading radios almost pointless;
"Redi-Rad" https://redirad.com/
/\ I plan on buying one.
EDIT:
a) As far as I am aware, the AM radio face always has a 'script' style "Delco".
b) Radio came in single speaker output or dual speaker output;
As far as I know all radios which went through an 8-track player used a single output, and the tape playe split the output into two channels.
c) The AM/FM had two distinct looks; the early ones had a 'script' font for the "Delco" logo whereas the latter ones had "Delco" on a little rectangular 'box'.
I hope this helps!
1970 Formula 400
Old 11-06-2017, 04:51 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
The 8-track player was available with mono or stereo radios. There are two different wiring harnesses depending on the radio option. With the single-channel radio the front and rear speaker signals are passed through the 8-track unit and controlled by the balance knob on it. With a stereo radio the balance is controlled by the knob on either the radio or 8-track depending on what is being used at the time.
Old 11-06-2017, 10:31 PM
Thanks for all of the radio tips! I did not know about the redirad place. I like wiring so all of the wiring info is great too.
John
Old 11-07-2017, 04:21 PM
unruhjonny's Avatar
thanks for the correction Dennis(?)
1970 Formula 400
Old 11-09-2017, 07:46 AM
Norwood's Avatar
Norwood Norwood is offline
I would certainly say it’s a 1
Old 11-11-2017, 01:10 PM
Norwood's Avatar
I’ll take your word for it.
