Old 09-02-2021, 07:27 PM
Gary H's Avatar
Gary H Gary H is offline
Originally Posted by Half-Inch Stud View Post
Finally got the Pan on. 1-piece Pangasket TQd to 12 ft-Lbs. Checked and mostbolts relaxed to 9 ftLbs, so re-torqued to 12. Probably check again later huh.
Rotated engine upright, Put in Cam and lifters with Rev Lube. Then did the rookie move with the Oil Pump Drive: off align. Magnet gotit. Misaligned again and walked away. Really never messed up the oil pump drive install twice.
If the retaining tabs are still on the oil pump driveshaft, and the driveshaft isn't installed properly on the oil pump, I doubt you're going to be able to get it in the correct location now. Likely you'll have to pull the pan back off and loosen the oil pump bolts up, then lift the pump enough to line the shaft with the pump.
  #62
Old 09-05-2021, 06:09 PM
77 TRASHCAN's Avatar
A Snap On torque wrench, that'll do the job!!!
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
  #63
Old 09-09-2021, 03:00 AM
NeighborsComplaint's Avatar
72cc Speedmaster heads are going to be at 11.8:1 on a zero deck 455+.060 w. flat tops. You don't think that won't detonate?
Triple Black 1971 GTO
  #64
Old 09-09-2021, 03:03 AM
Dragncar Dragncar is offline
You are going to need a custom cam designed for exactly what you are doing. The wrong cam and you are in trouble.
Big cooling system and all the rest is needed also.
  #65
Old 09-09-2021, 05:38 PM
Half-Inch Stud's Avatar
Hanging my hat on a pair of them 0.080" thick Cometic gaskets to keep the Pump gas real.
  #66
Old 09-09-2021, 11:52 PM
pokey1 pokey1 is offline
I ran my 455 with stock rods and crank, stock flat top pistons (except they were the TRW forged version) and ram air III heads.. it ran awesome ... until unleaded fuel came along. I am thinking it was about 11.5 : 1 compression but never really figured it out. Ran it that way for several years before finally changing it. Still have all those parts ;-)
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and
9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches..
