Old 09-05-2024, 02:10 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
Thanks…
Reading about other heads and the associated guideplate machinations, fiddling, welding, etc., it’s nice to see it seems he’s making that end an easy out.
costs too much
Old 09-05-2024, 03:37 PM
jhein's Avatar
jhein jhein is offline
To me, this is a no brainer. I know there are still a lot of unknowns but the Youtube video that he made shed a lot of light. If these heads were available when I did my motor, that's what I would have used, Even if they had the same performance as Edelbrock or KRE out of the box, they still win based on looks alone. If the performance is better then it's just not even close.
My only worry would be that it the Pontiac community started using these instead of Edelbrock or KRE, then maybe those would eventually die leaving us with only one source for aluminum heads. Which could be fine, unless or until something happens and these disappear too.
The Following User Says Thank You to jhein For This Useful Post:
Old 09-05-2024, 04:17 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The Mopar guys have a stock looking aluminum head-even tested on Engine Masters I think against some others. Friend has a set on his 500 inch "383".
Skip Fix
Old 09-05-2024, 10:40 PM
Dragncar Dragncar is offline
Not sure why special pistons would be needed. My High Ports have a 2.20 valve and generic Butler Ross pistons, 4.155 bore.
Old 09-05-2024, 11:12 PM
slowbird's Avatar
slowbird slowbird is offline
Your butler pistons are based on eheads. If you move the intake .080 you think the valve will still line up with valve pocket in the pistons?
That .080 plus a 2.19 intake valve is like running a 2.270 valve in eheads. How many shelf pistons have pockets for that? Guessing not many.
Old 09-06-2024, 03:37 AM
The pistons have one big valve pocket that is the same one both sides of the piston and its big enough for a 2.20 intake valve on both sides.
Move that intake .080 towards the middle and there is nothing but room. And the other side is big enough for a intake valve so why would a exhaust valve hit anything ?
Am I missing something ?
Old 09-06-2024, 08:48 AM
slowbird's Avatar
Yes you are. Not everyone runs Butler pistons. Also did you check radial clearance on your pistons? .080 is a noticeable move.
Don did a good thing by moving the valves but he might have created other issues by doing so.
The Following User Says Thank You to slowbird For This Useful Post:
Old 09-06-2024, 05:10 PM
I ran it all by Jeff at KRE so he knew exactly what pistons I was using. I did check piston to valve with a soft spring with the cam when it was a .447 lobe and it was fine. Then I had it re ground to a .431 lobe so the clearance got even larger.
Old 09-06-2024, 09:02 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Butler pistons have some of the largest valve pockets in the industry "for a reason".
If the information posted in this thread about valve sizes and relocated valve guides is correct one better be sure to check the piston to valve clearance carefully and in all directions.
A 2.11 intake valve has the potential to flow 350 plus CFM in a standard port Edelbrock head.
A 1.66 exhaust valve will support 900 plus horsepower.
Go fast, see Elvis!
Old 09-06-2024, 05:17 PM
Oh I get it. its cheaper for them to buy and it leaves more room for guys making mistakes.
I bought them a LONG time ago and to tell you the truth I wish I would have bought newer more modern pistons. I swapped out the crank and rods from the original plans anyway.
They are 1/16 rings, back cut with gas slots and those spacers, big pain.
I wish I would have bought pistons with int/ex reliefs and metric rings. Has to be a little more power going that route.
I could have cut my heads a little less to get the CR I was after with new pistons.
But so far so good with the engine.
Old 09-06-2024, 09:58 AM
adamo adamo is offline
Why doesn’t anyone ask don if they will need dedicated pistons? Or is everyone doing the liberal thing and talk and complain with out even knowing anything?
Old 09-06-2024, 10:19 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Cant wait to see the 48s flow test ! As cast model program showed potentially 320 cfm
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 09-06-2024, 11:00 AM
jhein's Avatar
I just posted the question in the comments for the video. He has been responding to some so we'll see,
Old 09-06-2024, 10:18 AM
Something else to note as far as quality details he mentions is that they will have Helicoils for rocker studs and exhaust bolt holes
Old 09-06-2024, 11:04 AM
jhein's Avatar
Wow, that was fast. Here's his response:
"I did move the valves a little but hoping most available pistons will work. As we get things sorted out I will share that info."
Old 09-06-2024, 12:22 PM
slowbird's Avatar
Interesting
Old 09-06-2024, 12:34 PM
See how easy that was.
Old 09-06-2024, 01:23 PM
PAUL K's Avatar
Not sure if we know more now than before??
Go fast, see Elvis!
Old 09-06-2024, 11:29 PM
jhein's Avatar
Yep. He said "we'll see". Sounds like his goal is for standard pistons.
Old 09-07-2024, 08:18 AM
PAUL K's Avatar
Shouldn't be hard to make that work. The blueprint was drafted more than fifty years ago.
Go fast, see Elvis!
