Old 02-16-2026, 12:07 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default Thanks
Originally Posted by randy1966GTO View Post
Awesome job so far, congrats. I'm starting my build in a few weeks at my place in Pecan Gap, Tx and can't wait, had the slab poured in October. I agree that the doors got out of bounds, I went with the cheaper roll-ups over the sectional ones.
Thanks for the kind words.
We had the same plan at the same time. Mine was poured in Oct.
Please post up some pics of your progress.
I think everyone would like to see what you are building.
We may get some ideas from what you are doing.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
  #62
Old 02-16-2026, 04:05 PM
Joog Joog is offline
Originally Posted by skunkwerks View Post
That seems to work very well. I can tell it is very reflective.
I am going to see how much light I get from the four commercial 11X11 doors I have to install with one big glass section in each door. They are Overhead door model 418. Very curious as to how much light they let in and how my shop doors are positioned to the east and west.
I do like the look of the panels on the ceiling. Looks clean
The original plan was to do drywall, but then we realized how heavy drywall would be to go up that high. The drywall doesn't reflect as good as the white panels, and you don't have to spackle metal panels.
  #63
Old 03-02-2026, 09:59 AM
skunkwerks's Avatar
Default Little more progress.
Made some more progress on the shop. Put in another 35 hours of time and have gotten this far. About 2/3 of all the hard stuff is done. Trying to get it
dried -in before the rainy season.
ID:	665713   Click image for larger version
ID:	665714   Click image for larger version
ID:	665715   Click image for larger version
The Following User Says Thank You to skunkwerks For This Useful Post:
  #64
Old 03-02-2026, 10:34 AM
Ogre's Avatar
Ogre Ogre is offline
Thumbs up
Like it, like it, like it! I was wondering if you would be dried-in before the end of this week/coming weekend.
The major heavy rollup doors will take a while, but looks good so far.
Ogre
“Man will ultimately be governed by God or by tyrants.”
-- Benjamin Franklin
- (1706-1790) US Founding Father
  #65
Old 03-03-2026, 11:47 AM
skunkwerks's Avatar
Default Thanks
Ogre
Thanks Ogre,
Been fighting the wind trying to finish this. Texas this time of year is very windy during the daytime as you know. We switched gears and got some nice LED headlamps and have been working at night when the wind dies down. We worked until 11PM on Friday night last. Neighbors were cool and did not call the cops. Should have it done in two weeks unless the rain does not stop.
Doors are going to be picked up this Saturday unless it is raining.
Not easy handling 17 ft sheets for the roof. lost two with a small gust and they went flying and were crumpled on the fence like pieces of paper.
The trim will take some time as they are one piece special ordered stuff. no seams. with the exception of the gutters. . No one makes a 50 ft seamless gutter for metal building.
  #66
Old 03-09-2026, 02:58 PM
skunkwerks's Avatar
Default Adding Overhead doors
Started adding the overhead doors to the shop over the weekend due to the rain.
Working on the dry side.
Custom setting these doors up to follow the pitch of the roof when they open.
They are heavy. Insulated doors weight more than I thought.
Anyone have any recommendations on electric openers?
ID:	666017   Click image for larger version
  #67
Old 03-23-2026, 03:12 PM
skunkwerks's Avatar
Default little more progress.
Made a little more progress on the shop.
Basically dried in and got all the doors up.
Just the front metal remains and that should be done this weekend.
ID:	666809   Click image for larger version
ID:	666810   Click image for larger version
  #68
Old 04-06-2026, 09:18 AM
skunkwerks's Avatar
Default Sheet metal walls done.
Finished the walls and doors are installed. Only thing that remains is the gutters, down spouts, gable and corner trim.
Started putting in the electrical. Mounted the load panel and started with the EMT piping.
I like doing this inside stuff.
Thinking about this new Blue Aluminum air-line system instead of poly or copper plumbing.
Looks durable and easy to install.
ID:	667793   Click image for larger version
ID:	667794   Click image for larger version
The Following 3 Users Say Thank You to skunkwerks For This Useful Post:
  #69
Old 04-06-2026, 03:10 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
Your shop is coming out great.
I cheated and went the easy way. I had a bolt up kit installed in Jan. Mine is 30X40X12. I did have to get them to come back out and add doubles to the back wall. You could see it bowing in the wind shaking the whole building. For insulation I went with 2" foam board on the walls and ceiling, the company wanted $6000 for their wrap and I did it for about $3000
Name:	e28180da-34ea-4357-904c-685c36232ad2 (Medium).jpg
ID:	667801   Click image for larger version
Name:	6da50ae1-ce61-49bb-94c2-6e979856a17f (Medium).jpg
ID:	667802   Click image for larger version
ID:	667803   Click image for larger version
67 Firebird Convertible
  #70
Old 04-17-2026, 01:54 PM
skunkwerks's Avatar
Default Very Nice shop.
Very nice shop. I like the big doors at the end and the brick veneer.
My end walls were a little wobbly so I had to reinforce them with the vertical V shaped 6" perlins and that solved that little problem and provided lateral sheer support for the building on both ends.
I am going to do the same as you. Use 2" Poly-Iso boards to insulate.
Way cheaper and just as good as spray foam. I did use the bat insulation on the roof but I got a deal on it so it is extra insulation as I will add foam to the inner roof also.
I'm working on the electrical and the electric door openers at the moment.
  #71
Old 04-29-2026, 01:13 PM
skunkwerks's Avatar
Default Gutters and rake trim finished
Just a few update pictures. Finally got the gutters and rake trim installed. now the shop is dried in and sealed up. Only thing left is the corner trim.
Started working on the electrical. Bending conduit and box layout.
ID:	669017   Click image for larger version
ID:	669018   Click image for larger version
ID:	669019   Click image for larger version
ID:	669020   Click image for larger version
The Following 4 Users Say Thank You to skunkwerks For This Useful Post:
  #72
Old 04-29-2026, 02:50 PM
jwcfbd's Avatar
looks great
  #73
Old 05-01-2026, 02:01 PM
skunkwerks's Avatar
Default Thanks
looks great
Thanks,
You planning on putting HVAC in your shop?
