Old 02-12-2026, 10:33 PM
DOC DOC is offline
You mentioned that this will be a street cruiser / bruiser and driven to car shows. Not sure of what intake would be ideal, but I would focus on an intake that has great bottom and mid power/torque. That’s where the fun will be to be able to drive it routinely. I went down the rabbit hole of building a motor for max power and it was not ideal/fun for the street.
If running an automatic, make sure to get the right torque converter as well that works well for your needs.
Good luck and looking forward to hearing how it turns out.
The Following User Says Thank You to DOC For This Useful Post:
Old 02-13-2026, 07:20 PM
Pontiac Performance Author
what cam-heads? the forum members will come up with a HP/TORQUE number for us. JLM has the under-hood setup figured out. Ask him what air cleaner he used and then use any manifold you have that has the same height as the torker2. I agree with Gary H. None your manifolds will make your seat of the pants dyno feel any different. I just read an air cleaner article from 2002 Hot Rod. Marlan tested 7 different air cleaners on a 520 HP engine. The HP spread was 518-522. The drop base with a 2-1/2" filter made 522.
The Following 2 Users Say Thank You to KEN CROCIE For This Useful Post:
Old 02-13-2026, 09:06 PM
Steve C. Steve C. is online now
Ken mentions air filters. Maybe a bit off topic but some might find this of interest....
A very long time ago I had a 'experimental' Edelbrock cylinder head that was tested on David Vizard's flow bench.
I had the opportunity to have lunch with him then and found not only a nice fellow but pretty darn smart.
It was at that time I learned a bit about the K&N filters.
Take a few minites to watch this video starting at about 4.24 thru about 14.00
I believe what you hear will be very interesting.
Much more than they get more efficient when they get dirty !
Be patient and wait until the part about 'vibration'.
https://www.youtube.com/watch?v=ow5cGV7bXCw
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 02-14-2026, 01:58 AM
charlie66's Avatar
72cc Edelbrock heart chamber with the moved spark plug comp cam hydraulic roller 520/540 lift .050 236/242 on 110
My Half AN Injun.....
Old 02-14-2026, 05:00 PM
I've seen similar combos run in the 475-515 HP range. I have the same comp lobes in my 462 with 112 lsa and 108 isl.
Old 02-15-2026, 11:28 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I will agree 500 HP is about the limit for a stock intake. My first ported E head 455 259/264 SR I kept the HO intake until I found an extra Shaker base to "massage" for a Holley/Demon. After I found one swapping a Demon with an adapter for the worked Qjet at the track picked up 0.3 seconds. Swapped a Torker II on idled smoother and with jetting the car ran 10.90@123 in good air, 6.9 1/8 at 99 weighing 3750.
Skip Fix
Old 02-15-2026, 01:05 PM
Formulajones's Avatar
Formulajones Formulajones is online now
Yeah if I were really chasing power numbers I'd go with a good single plane every time, especially on a bigger inch motor. With Pontiacs and the 4.210-4.250 cranks they have absolutely no trouble making torque so sacrificing a pinch of that with a single plane really isn't a big deal anyway.
https://youtu.be/XqEydRRRwqE
Old 02-15-2026, 06:42 PM
charlie66's Avatar
I'm hoping to reach the 500hp range. I'm going to use the street Dominator intake. It will be match ported with some Plenum work at 10.53 to1.
Old 02-15-2026, 08:48 PM
ta man ta man is offline
You will be fine. Well thought out build that will make more power than most builds.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
Old 02-16-2026, 08:22 AM
charlie66's Avatar
Ok cool thank you!
Do you have a guess what it will most likely make?
Old 02-16-2026, 09:42 AM
PAUL K's Avatar
PAUL K PAUL K is offline
If you are using a factory manifold without modifications it's going to have a hard time keeping up with some aftermarket manifolds on a true 500 horsepower build.
Go fast, see Elvis!
Old 02-16-2026, 11:47 AM
Gary H's Avatar
Gary H Gary H is offline
Truth! I can be done with a factory intake, but it'll take some work. And you're still limited to a spread bore style carburetor with the factory intake, unless you run an adapter, which I'm not a fan of.
Old 02-16-2026, 12:50 PM
charlie66's Avatar
I'm using a Holley Street dominator that is port matched with some plenum work..
Old 02-16-2026, 10:48 AM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
462 O-port eheads, baseline ‘72HO intake-502HP
Swap to ported HO intake-558HP
Swap to ported RPM intake-571HP
Swap to ported HSD intake-574HP
HR 238/248 ~.650 lift 112LSA, QJet.
The Following 2 Users Say Thank You to 65 Lamnas For This Useful Post:
Old 02-16-2026, 05:11 PM
Skip Fix's Avatar
My ported T2 and the Holley modified by SD I borrowed from Steve C were identical on the dyno with a square bore carb. A Qjet needs a spacer for the front runners to flow better because the carb pad is closer to the top of the runners.
Skip Fix
Old 04-05-2026, 06:58 AM
steve25 steve25 is offline
The proper shape of the air cleaner base can add close to 6% more air flow over a crappy one as shown by these test done by David Vizard a number of years ago.
Old 04-05-2026, 01:12 PM
73ta's Avatar
73ta 73ta is offline
Aluminum China Repop HO/RAIV manifold been cnc ported by SD Performance on mine. 570 HP
Old 04-05-2026, 05:34 PM
That's pretty good. I've taken a few out of the box untouched and made good power with them. One made 507hp on a very mild pump gas 455 with no porting. So they'll support what the OP is asking for without any work if the rest of the combo is well thought out.
