Old 09-29-2024, 04:43 PM
BB70's Avatar
BB70 BB70 is offline
Doing some wet sanding on my paint, just about done w/1500. Next 2000 then 2500 and then try to buff it.
The Following 2 Users Say Thank You to BB70 For This Useful Post:
  #862
Old 09-30-2024, 07:49 PM
67drake's Avatar
67drake 67drake is offline
Put my new tail lights on today. They were hands down the worst part of the exterior, so money well spent.
ID:	640779   Click image for larger version
ID:	640780   Click image for larger version
‘55 Catalina
The Following 2 Users Say Thank You to 67drake For This Useful Post:
  #863
Old 10-04-2024, 07:43 PM
67ozzyville's Avatar
67ozzyville 67ozzyville is offline
I managed to fit new Koni shocks to the rear of my 76 GP
Not easy to get a hand on the top mounting bolts .
This was my second attempt as now I have a hoist.
It had an old pair of air shocks that were very rusted along with the top nuts and bolts .
On the exaust side I had to use gas axe on the rusted bolts.
A few burns and small fire the shocks are fitted, now to test this log weekend downunder, I think that it will not get the death wobbles anymore , front shocks done.
Sent from my SM-X200 using Tapatalk
The Following User Says Thank You to 67ozzyville For This Useful Post:
  #864
Old 10-05-2024, 12:35 AM
jhein's Avatar
jhein jhein is offline
Just been driving as much as possible. Season is coming to an end here soon so I drive whenever I can. She's been running really good so I'm happy about that. I've got a lot of other stuff to do so it stresses me out a little. But screw it, I drive.
The Following 2 Users Say Thank You to jhein For This Useful Post:
  #865
Old 10-06-2024, 05:19 PM
67drake's Avatar
Nothing, it’s my weekend to work.
But my son did go up by Green Bay to pick up a new motorcycle with my Duramax. He sent me a pic of my odometer. Just got broke in!
‘55 Catalina
  #866
Old 10-06-2024, 06:19 PM
Washed the white and green ones today. They are both going to a Firebird get together at my buddys house next weekend. Had to pull the silver one out to repair my garage door opener. Figured I'd pop a pic while all 3 are out.
The Following 5 Users Say Thank You to 71GP76TA For This Useful Post:
  #867
Old 10-06-2024, 08:25 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Hell yeah!
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
The Following User Says Thank You to Skidmark For This Useful Post:
  #868
Old 10-06-2024, 08:54 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Well, the other night, while headed home from the local pizza joint I had been listening to a friend play some blues music, the spider gears gave up there life!
Got it home, and my son pulled off the cover to find pieces and chunks of the spider gears stuck in the ring gear!
I have an Eaton posi unit along with a new ring and pinion ordered.
So most likely, it won't leave the garage till next year.
  #869
Old 10-06-2024, 09:15 PM
67drake's Avatar
Bummer
‘55 Catalina
  #870
Old 10-07-2024, 09:09 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
Took my 400 Pontiac powered studebaker to a local cruise in this weekend that was part of a festival. Stretched its legs on the way home.
ID:	641029   Click image for larger version
Clutch Guys Matter
_______________________________________
53 Studebaker, 400 pontiac
72 4-4-2 Mondello's VO Twister II
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
The Following 5 Users Say Thank You to Mr Anonymous For This Useful Post:
  #871
Old 10-07-2024, 12:49 PM
Verdoro 68's Avatar
We've been fighting getting the lower control arms back in on the Ventura. I pulled the steering to make more room to get the bolts in since I was going to replace it anyway...not so fast. I learned Venturas use different steering parts than Novas to clear the Pontiac oil pan and exhaust. Apparently the right part interchanges with a 6 cyl '69 Firebird. I never realized how easy I had it for parts working on an A-body. I've been burned on the parts more often than not when I order from Classic Industries. I know better and should always stick to Ames, but their Ventura selection is spotty.
ID:	641031   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post:
  #872
Old 10-07-2024, 02:48 PM
carcrazy carcrazy is offline
Sprayed a little epoxy primer on the front "nose" of my 67 GTO. Hoping to top coat the part sometime this week with SS SPI black.
The Following User Says Thank You to carcrazy For This Useful Post:
  #873
Old 10-09-2024, 10:24 AM
tooski tooski is offline
Default More than a day's work
New: control arm bushings, ball joints, outer tie rods, springs, shocks, brake lines.
Inner fenders tidied up and reinstalled.
Name:	Front suspension 1 A.jpg
ID:	641068   Click image for larger version
Name:	Front suspension 2A.jpg
ID:	641069   Click image for larger version
Name:	Brake lines (1) A.jpg
ID:	641070   Click image for larger version
Name:	Front end A.jpg
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
The Following 5 Users Say Thank You to tooski For This Useful Post:
  #874
Old 10-10-2024, 01:22 AM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
From this last weekend, nearly 1400 miles cruising the TX portion of Route 66.
ID:	641082   Click image for larger version
ID:	641083   Click image for larger version
ID:	641084   Click image for larger version
1966 GTO Resto-Mod. 2nd owner California car, Factory Air, Power Windows, Kauffman Heads, March Serpentine, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R Level 3, Yank 2400 Stall Converter, Dutchman Axles, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust, Continental ExtremeContact Sport 02
The Following 7 Users Say Thank You to RA66GTO For This Useful Post:
  #875
Old 10-11-2024, 07:15 PM
67drake's Avatar
Just went to check on one of our rentals in the next town. Figured we’d take the ‘55.
‘55 Catalina
The Following 5 Users Say Thank You to 67drake For This Useful Post:
  #876
Old 10-11-2024, 10:05 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Had some Pontiac buds over yesterday for a meet & greet/BBQ during the Fall OC show
ID:	641158   Click image for larger version
ID:	641159   Click image for larger version
ID:	641160   Click image for larger version
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
The Following 5 Users Say Thank You to OCMDGTO For This Useful Post:
  #877
Old 10-13-2024, 10:32 PM
67drake's Avatar
My machinist finished the heads for my ‘69 400, in the meantime I decided to have him tank and hone the block and polish the crank. He lives quite a ways from me, so decided to do the pickup/drop off today seeing as how I was driving across the state to my son’s house anyway.
I traded my son an 8.5 with 3.90’s to go into his GTO for one of his welders.
So lots of driving today, but worth it!
ID:	641224   Click image for larger version
ID:	641225   Click image for larger version
‘55 Catalina
The Following 3 Users Say Thank You to 67drake For This Useful Post:
  #878
Old 10-14-2024, 06:55 PM
John Milner's Avatar
John Milner John Milner is offline
It was a nice Fall day here in southern Oklahoma and I was off of work today. So I took advantage of that and cleaned some of the Pontiacs up and drove them around town.
The Following 3 Users Say Thank You to John Milner For This Useful Post:
  #879
Old 10-15-2024, 12:55 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Got my hood hinges back from having them refurbished and restored by Rowland Hall out in California. As you can see, he did an absolutely amazing job and they look factory fresh... and perform that way, too.
Finally got my hood aligned to good' nuff specifications. My hinges were badly worn and the passenger rear corner of the hood sat up too high while the gap between the fender and hood on the driver side was too narrow. I couldn't adjust out either one of those issues without exaggerating the other, but now I got it fairly well aligned. I could probably fine tune it more, but I need to learn to leave well enough alone before I scratch my paint or mess something up. These cars were far from perfect from the factory, anyhow.
She's ready to drive again after having stabbed back the trans, too! So far no leaks.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following 4 Users Say Thank You to nUcLeArEnVoY For This Useful Post:
  #880
Old 10-16-2024, 10:20 PM
4dblnkldude's Avatar
I melted a resistance wire on my 69 GTO.
The Following 2 Users Say Thank You to 4dblnkldude For This Useful Post:
