Old 11-21-2009, 07:31 PM
njsteve's Avatar
njsteve njsteve is offline
Thank you, fellow members of the Never-Ending Trans Am Restoration Support Group!
  #942
Old 11-21-2009, 07:32 PM
njsteve's Avatar
Originally Posted by 666 the legend View Post
..Whats the DEAL with the VALVE COVERS..?? were they all PAINTED..?? Cause I wanna go with the chrome look on mine..and also the INTAKE..?? I wanna go with the RAW ALUMINUM..
Painted valve covers and intake in '72.
  #943
Old 11-21-2009, 07:34 PM
666 the legend's Avatar
666 the legend 666 the legend is offline
...DAMN IT..!!
  #944
Old 11-21-2009, 07:40 PM
njsteve's Avatar
Hey, it's your car, do what you want if it makes you happy. It's pretty easy to swap a pair of valve covers back. (a little harder if you have A/C, though) :-)
  #945
Old 11-21-2009, 07:48 PM
..Yeah I know..I was just hopin they had BOTH styles...But Im definitly not gonna paint the INTAKE..I would think the PAINT would HOLD in the HEAT.Plus..I think the CONTRAST of the colors looks nice...
  #946
Old 11-21-2009, 07:54 PM
While were on the subject.Are the VALVE COVERS for a 72 just for that car..?? or are there INTERCHANGABLE years..??
  #947
Old 11-21-2009, 07:59 PM
njsteve's Avatar
Same old valve cover. There is a much thicker valve cover gasket and longer bolts, though, for the 455HO engine because of that metal cage contraption under the valve covers that help direct the oil.
  #948
Old 11-23-2009, 05:28 PM
njsteve's Avatar
With the help of a board member on the Yenko.net website who identified the random old coil I had in my parts box as an original 1972 Pontiac coil, I was able to test it, clean it up and install it.
http://www.yenko.net/ubbthreads/show...e/0#Post429806
I then tossed the Pertronix coil that had been frying my points, into the "extra parts" box.
Here's the new/old coil in place.
And the third set of points I've replaced in the three years the engine has been up and running. Both contact surfaces on the lever arm pad and the base pad have been crystalized to the point that they wouldn't conduct electricity any more. (Ignore the dust - I had it sitting on the sanding table when I was prepping the coil for paint). I guess I will stick to the stock ignition parts from this point on and forget the aftermarket crap.
  #949
Old 11-24-2009, 03:44 AM
Transamric's Avatar
So Steve,....this is a #425 or #424 coil?
Old 11-24-2009, 08:08 AM
njsteve's Avatar
425. I am still trying to figure out whether it should be a 424 since 424 is what is listed in the 1972 repair manual. But then again the coil spec section of the repair manual has several typos including a typo under the ohm ratings for that coil saying it should range from "3000 - 2000" ohms". (It should read 3000-20000 ohms like the 71 manual says).
Anyone out there have a definitive answer? If its supposed to be a 424, what application does a 425 fit?
  #951
Old 11-24-2009, 07:27 PM
Transamric's Avatar
Well, I've always believed the #424 to be correct for '71 & '72 Pontiac V-8. Maybe I need to check this out further. Best I can do for now, is these two pics. The one in the bracket is my 05D '71 84,000 mile VN TA, that I have owned since '84. The other out of a bracket is the coil from my 45,000 mile '72 Esprit, built 10D. They are both #424.
Perhaps the 425 was a Service Replacement coil, since you mentioned someone stated a parts catalog showed the 425 as "correct". I do know for sure, that for many of these years, the M.P.C.'s showed Chev ID numbered coils as a replacement for the Pontiac part. So can't always rely on that source.
More on this later.
Name:	coil 424 71 05D TA.jpg
ID:	188631   Click image for larger version
Name:	coil 424 72 10A Esprit.jpg
  #952
Old 11-24-2009, 08:44 PM
njsteve's Avatar
The 71 and 72 Service Manuals I have, do show the 1115424 coil for the V8s. I guess I'll stick with the 425 until I find a 424.
I'd love to know the exact application for the 1115425. The guy that linked it to my application did not have any Pontiac books to cross reference the 425 coil. Anybody out there have an old parts book?
  #953
Old 11-25-2009, 03:33 AM
Transamric's Avatar
Steve, I have original MPC's for every year printed from 1969 to 1983. I'll do some research & post the results. but as I said above, the catalogs I have checked, show Chevy part numbers for Pontiac Service Replacement coils. So they may not be of any help.
  #954
Old 11-25-2009, 11:34 AM
tdavidl's Avatar
tdavidl tdavidl is offline
for kicks & giggles i grabbed the coil that failed on my car 2 years ago @ 125k miles & it's a
424
B-R
can these be refurbished & what would be the cost & is it worth it ?
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
  #955
Old 11-25-2009, 12:19 PM
njsteve's Avatar
Did you test it?
For a coil that is out of the car, get an ohm meter and run the leads to the pos and neg terminals and see what the meter says - the spec is 1.7 to 2.1 ohms (remember to pre-check the meter itself by touching the leads together and if you can't zero the meter, then subtract whatever is showing from your test results. My meter showed .6 for its own leads so I had to subtract that amount from the coil test results). The secondary test is done by running one lead to the coil output and one lead to one of the terminals. That spec is 3000 to 20,000 ohms. My corrected results were 1.8 ohms on the primary and 10,900 ohms on the secondary.
Dont know if anyone restores them.
  #956
Old 11-29-2009, 03:35 PM
njsteve's Avatar
More minor things. Applied the "Trans Am" decals on the fenders. It took an hour to lay out all the tape to get the measurements right...and then took about 15 seconds to actually apply the decals.
Installed the original black rubber hood bumpers, three per fender. Got to use last year's X-mas gift: a set of plastic mini prying sticks. They worked great to push the rubber tabs through the slots in the fenders. Anything metal would have damaged the paint and split the original rubber bumpers.
Engine running nicely now that the original coil is back in place and the new set of points are installed.
Even the A/C is working nice and cold...now that it's nice and cold outside.
  #957
Old 11-29-2009, 09:38 PM
keepat's Avatar
keepat keepat is offline
Steve,
Looks great!
Pat
  #958
Old 11-30-2009, 08:36 AM
165th's Avatar
165th 165th is offline
Steve some of the pictures you post really show off the nice body lines, especially the lower line above the rocker and the mid line through the door. Your body man did a fantastic job.
  #959
Old 11-30-2009, 12:06 PM
CaptCrunch CaptCrunch is offline
Looking great!
  #960
Old 11-30-2009, 02:56 PM
72Formula's Avatar
72Formula 72Formula is offline
Steve, never give me your address. I'd become a car thief or a crying car lover. We don't want to find out which.
