#81
Yeah, it's come together pretty nicely. I will hopefully have the car running for my birthday on the 23rd.
I think everyone is probably in the ballpark. I'd love to see 550 or a bit above, but don't know how realistic that is with the intake and cam.
#82
533hp and maybe 548 torque
#83
I'll say 540-hp and 595-torqe.
GT |
#84
530hp and 599 torque
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
#85
I’m surprised with the <550 hp guesses. Is it due to the lower compression? IIRC, it’s been said the Old Faithful cam at 236/245 with 290cfm heads makes around 550 hp. The 230/236 Stump Puller in my Firebird with 290 heads and 10.4 compression made 521 hp.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '69 LeMans Vert, 350, #47 heads: work in progress |
The Following User Says Thank You to grivera For This Useful Post: | ||
#86
Maybe I need to clarify some parameters. The cam figures I provided are @.050. Advertised duration is 293/301. Gross valve lift is .596/.597 I'd love if the engine made between 550-575, but honestly, the number will be what it will be. I add the most recent photo from the machine shop as well as the cam card. I had hoped this would go to dyno this week, but I'm less certain that will happen. The new water pump was missed in the parts ordering, so we're waiting on that.
#87
Happy dyno or conservative dyno, which one will you be using?
I’m usually erring on the conservative side so that’s why I’m not at 550 or above on my guess. I have a friend up the street from me with a long-stalled Chevelle mild steel tube chassis race car project, we’re talking 30 years and it’s never turned a tire under its own power. It has a 327 with ported camelback heads, a tunnel ram with who knows maybe a pair of 660s on it and 14.5:1 compression which it must have a monster pop up piston dome and heavy cut on the heads to achieve that if it’s even possible. It’s supposedly going to make 600 horsepower and turn 10 thousand RPMs if he needs it to. I’ve already cautioned him that it needs new valve springs (rockers never removed for engine storage) and that aluminum rods can be a problem left sitting for long periods of time with the bolts torqued. He’s resisting tearing down a 30 year old never been fired race engine to lube and inspect it and replace a few things. I’m not gonna burst his little bubble with my amateur but more realistic horsepower guess but you get the picture.
#88
That certainly doesn't mean it couldn't be stingy or happy. Just an observation.
#89
Sorry to hear about your troubles. Just putting this out there as I installed Johnson short travel lifters years ago and the Rep told me that the lash was very crucial. From what I remember I was told to count the threads on the poly-lock to set lash. In other words it's not 1/2 turn and your done. 575 hp and 600 torque.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick. Best so far 9.95@134 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. |
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
#90
Do you have any numbers for open and closed pressures? Thanks
#91
The springs are rated at 395 lbs at coil bind. I'm at about 85% of coil bind with a 1.8 install height ant .596" of lift. So probably in the neighborhood of 335 lbs over the nose by some basic math.
-Jason 1969 Pontiac Firebird Last edited by JLMounce; 09-11-2024 at 02:17 PM. |
The Following User Says Thank You to JLMounce For This Useful Post: | ||
#92
1903 installed at 1.8 will give around 385 open pressure with a .600 lift cam.
The Following User Says Thank You to PAUL K For This Useful Post: | ||
#93
Perfect, thanks for the info!
#94
You're in Colorado so some here are going to bulk at the larger correction factor needed up there, not that it matters really. We have the same issue down here actually. I've found predictions from the Kauffmans to be a little ambitious when I've dyno'd stuff from them but you didn't hear that from me lol. Having dyno'd similar stuff to yours I'd bet it's around the 520 mark give or take, but it'll have a boat load of torque with a nice flat curve. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
#95
The engine was broken in and tuned yesterday. I swung by for the final dyno pulls this morning.
To say that I am thrilled is an understatement! She sounds wicked and puts up numbers to match. They forgot to paint the water pump, so they'll do that as soon as the engine comes off the dyno today and I'll pick it up likely tomorrow.
#96
579hp and 600 tq -- IMPRESSIVE BUILD!!
#97
Thanks, I'm through the moon on the build. I should have it in the car this upcoming weekend.
#98
Awesome Jason! That is going to be a blast to drive.
#99
It should definitely rip! Weight of the car with me in it is just over 3600 lbs.
#100
That 30 year old 327 build with ported double hump heads will not even make 380 Hp !
Those size piston domes needed to make 14.5 with a 327 cid motor will cut into flame travel like your buddy will not believe! With those chambers anything over 13 to 1 and your shooting your self in the foot, your right foot.
