#81
Yes, everything went back but had to really bend the tranny lines. The headers are reall close, almost touching the A-arms but it does fit and the ground clearance is as good as I've seen on a header. I went with 3-inch Pypes crossover kit and keeping the 2.5" mufflers and tailpipes. Should be worth 20 hp or so over the Ram Air manifolds and 2.5" crossover.
#82
My Doug's round port headers needed to be dented in the area the one passenger side tube went past the lower control arm frame mount. Those headers rusted in like 2-3 years.
On D-port heads, I use the Craftsman 'angled' wrenches, and 3/8 headed bolts. They work great. (pic) .
#83
I use a standard Craftsman combo wrench. Reaches every bolt.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. ![]() |
#84
Wow. 13 years.
Still look great.....
#85
It seems to me that all of the installs that went fairly well were with an automatic trans. Does anyone have a success story with round ports ,4 speed in a 1970 GTO
#86
Wondering the same thing on TKX install on a 71 GTO? Did anyone have to relocate the proportioning valve on the frame?
71 GTO stroker, with TKX 5 speed 65 Catalina 2DHT, 389 bored 0.060 over, Crower 60916 cam, #16 heads, CR Q-Jet, TH400, Continental 13", 3.42 Posi, Frame-off resto, RARE Long branch manifolds, 2-1/2" Pypes with X-pipe and Goerlich Turbo mufflers |
