Old 07-11-2008, 08:13 PM
Sporter's Avatar
Sporter Sporter is offline
Centerline Billet Saber 17x8s with 235/40-17's in front and 275/50-17 M&H drag radials in the rear.
1967 Firebird ragtop, 464, Weiand 8-71, ported 6H heads, Hyd roller, 4L80E, paddle shifter, Moser 9", Cal-Tracs, Vintage Air, Corbeau seats, 13"/12" disk brakes, Hydraboost, electric cutouts and M&H drag radials.
  #82
Old 07-11-2008, 09:19 PM
scott mills's Avatar
scott mills scott mills is offline
My wheels.
  #83
Old 07-11-2008, 11:48 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
my 67 with 17s
Name:	HPIM0998 (Medium).JPG
  #84
Old 07-12-2008, 12:37 AM
chief455's Avatar
chief455 chief455 is offline
Originally Posted by scott mills View Post
My wheels.
like the roof - nice!
  #85
Old 07-12-2008, 12:38 AM
chief455's Avatar
Originally Posted by Norwood View Post
You don't see these everyday
what was the factory thinking?
  #86
Old 07-12-2008, 06:54 AM
Norwood's Avatar
Norwood Norwood is offline
Pontiac got this one right...I can't think of a better looking factory wheel.
  #87
Old 07-12-2008, 11:12 AM
jeffhhs76's Avatar
jeffhhs76 jeffhhs76 is offline
Originally Posted by wytnyt View Post
whats the widest crager and tire that will fit under a stock 67 gto and clear the wheel well,,any comments appreciated
Didn't read throught the rest of the thread to see if you rec'd an answer on this. I have 15" wheels on my car and the widest I could put on the rear of my 67' is 255/60 .. I have 215/70's in the front... If you are going square on your car for the stock factory look I can tell you that a friend of mine tried 235/70's on his car and he couldn't turn the wheels without causing fender damage. 225/70's were too close for comfort. The 215/70's were perfect. Can't give you any info on 60 series tires in the front, sorry. I am currently changing the tires on my car and going with the 215/70's in the front and 235/70's in the rear all on refreshed Rally II's. After 7 years of having the 255/60's on the rear and cragar's all around I've decided to go for a stock look.
Jeff
  #88
Old 07-12-2008, 05:40 PM
tempest455's Avatar
tempest455 tempest455 is offline
You can fit a P275 or 28 x 11.5 ET Street w/ the right backspace. You did not have enough B-S.
Tempest455
  #89
Old 07-12-2008, 10:08 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
i think i like the bare look the best,followed by the early flat trim rings.never really liked the rounded trim rings,took them off all the cars i had with them;73 TA,74TA,78TA.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
  #90
Old 07-12-2008, 10:21 PM
cnc's Avatar
cnc cnc is offline
Default Weld Prostars
chief455 r those weld prostars your running there now
What size r they ???
To me they r SWEEEET....Ru u lookin to replace them ????
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
  #91
Old 07-13-2008, 12:41 AM
chief455's Avatar
thanks! yes, prostars.
15x8 4.5 bs 28x10.5 MT drag slicks
15x3 1.5 bs(i think) 7.10x4 Moroso
I like them, but am mounting drag radials and driving on the street soon.
Want to take the opportunity to change the look a little....
thinking width = 8,10 rear, 7,8 front on a 15, 16 or 17 rim
  #92
Old 07-13-2008, 01:10 AM
440GP69's Avatar
440GP69 440GP69 is offline
Chief Amazing car!!! i personally would not change a thing, those wheels with that stance looks BAD!!!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
  #93
Old 07-13-2008, 04:45 AM
chief455's Avatar
thanks, Bud!
I know - 99% people think that - I want the wheels to be less generic.
Billet Specialties come to my eye...
  #94
Old 07-13-2008, 03:41 PM
79TA455STROKED's Avatar
79TA455STROKED 79TA455STROKED is offline
I have the billet spec on my car.
15x10 with 5.5bs(28x13.50 hoosier qtp)
15x3.5(mickey thompson sportsman)
Dont mind the primer,cars is in paint now.
9.81 at 139.89mph
3400lbs
Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS!
370cfm butler eheads
port matched victor
1095 king demon
4.30gear,th400
MICKEY THOMPSON DRAG RADIAL tire
  #95
Old 07-13-2008, 04:29 PM
chief455's Avatar
you are killing me! I was hoping to be the first with BS street lites on a T/A around here! ARRRGHH!
I'm going 15x8, 15x7 for street combo, keeping the prostars for strip
nice man!
  #96
Old 07-13-2008, 05:43 PM
Here are a couple pics of the rear you asked for.Sorry about the quality,the car is in paint and i just threw a back tire on a snapped a couple pics.Its tight in the garage and i cant move the car because its on jackstands.You can see where i had to mod the seatbelt hump for the tire to clear.Its the biggest tire i could get in there without mini-tubbing.
9.81 at 139.89mph
3400lbs
port matched victor
1095 king demon
4.30gear,th400
  #97
Old 07-13-2008, 07:10 PM
chief455's Avatar
Dude - you are getting your car deep into the NAST zone rear discs, fat tires, big pipes, sick power - nice!
I'd only run a 10" wide tire on the 10" rim, so would not need to mod as much.
You might have just convinced me I need a big 10 inch......rim.
  #98
Old 07-15-2008, 08:39 PM
greenwood g machines greenwood g machines is offline
73 ta -- 18x9 yearone snowflakes with 5 1/2 backspace wrapped in bfg ta kdw 255 40zr18 up front and out back 18x10 with 6" backspace with 295 35zr18. nothing rubs and car is lowered 2".
ID:	136514   Click image for larger version
  #99
Old 07-15-2008, 09:17 PM
HWYSTR455's Avatar
This is an older pic, but the only I have at the moment. This is with 2" drop spindles, which I replaced with 'regular height' spindles, and adjusted the spring, which gave me about 1.5" higher ride than shown. It was too slammed, and the geometry was boogered. FYI, never use drop spindles....
ROH RTs
18x9.5 front, 5.17 BS, 265/35s
18x10.5 rear, 5.95 BS, 285/35s
I can squeeze a 295/305 out back, maybe a 315, but finding matching tires for the front is an issue. If I would have gotten a little more offset in the front, I could have done a 275. Rolled lips and trimmed inner fenders. 255s would go without the fender & inner treatment.
  #100
Old 07-16-2008, 07:25 AM
KCTurbo's Avatar
KCTurbo KCTurbo is offline
Sporter, how much backspace are you running with the 275/50 M/Ts?
Hey Stroked, That wouldn't happen to be a 944T in the background would it? I had a 944TS, one of the Silver Rose cars.
