Old 04-16-2014, 07:13 PM
1966geeto 1966geeto is offline
Anyone have a picture or a bare frame they can take one I need a close up of the frame right behind the pass tire there is a slot in the frame I think that is where my issue is it does not look right .
It does not have the same issue on the dr side so pissed right now I can't see straight.
  #82
Old 04-17-2014, 08:31 AM
Tempest's Avatar
Tempest Tempest is offline
I have a bare frame, but it is for a convert., so I think it will be different. (let me know if you want pics of that)
Have you measured using the 'X' method?
pick a spot on the rear pass side of the frame, and measure to a spot on the front driver's side. Then measure from the same points on the other sides, and see if there is a difference.
If there is a difference, then your frame is not 'square'.
  #83
Old 04-17-2014, 10:05 AM
I took it to a frame shop the guy has been doing frame work for 40 years the car measures within a 1/4 inch but the top of the rt tire is set back I can see a roll in the frame at the slot right behind the frt rt wheel does not look the same as my parts car frame.you frame is just boxed and has the xtra cross member but the cradle should be the same.
  #84
Old 06-20-2014, 05:27 PM
Default Never thought I'd be doing this again!
Working on the new frame I had delivered round 1 course wire brush on the Makita 2nd round 80 grit flap disc de bur all the welds and removed all extra slag 3rd round HF pressure blaster with medium grit media. Epoxy primer and ceramic paint this weekend. Forgot how much work went into the first one.. Talk about setbacks rather not.
Name:	frame dash 009 (Small).JPG
Name:	frame dash 010 (Small).JPG
Name:	frame dash 011 (Small).JPG
Name:	frame dash 012 (Small).JPG
  #85
Old 06-22-2014, 10:39 PM
400 4spd.'s Avatar
What happened with the frame shop guy that said the cradle was the problem? Did you have him try and fix it? Just curious what the final determination was regarding alignment problems with your original frame.
  #86
Old 06-23-2014, 06:56 AM
Default Frame measurements
I bought a 66 Lemans parts car and stripped it down to measure the frame the frt horns were exactly the same as mine I also measured the roll in the horns and it was the same on both frame .I took the frt clip off mine to measure the frame and borrowed a digital caliper from a friend the dr side was the same the pass side had a set back of 1.75 inches from the upper ball joint to my indictor marks the lower ball joints were the same so being that the eng would have to come out to make the pull and the frame heated and stretched the cost factor was about the same to replace the frame and there were no guarantees the pull would hold so here I am reconditioning another frame what a setback but almost done hope to have the epoxy primer on it today paint Wed then start the swap should take about a week .
  #87
Old 06-25-2014, 03:11 PM
Default Frame progress looking good
After many hours stripping under coat smoothing welds wire wheel glass beading it's done ready to start swapping anyone want to help! anyone free beer food pool extra rooms lol..Fla vacation..
2qt's House of Kolor black epoxy primer nice stuff to work with went on like silk.
2QT's Eastwood ceramic sating extreme chassis black
2 cans Eastwood internal frame coating stuff is great very impressed
Name:	frame 001 (Small).JPG
Name:	frame 002 (Small).JPG
Name:	frame 003 (Small).JPG
Name:	frame 004 (Small).JPG
Name:	frame 005 (Small).JPG
  #88
Old 06-25-2014, 09:33 PM
Nickv's Avatar
Nickv Nickv is offline
That is a piece or Art!!
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecargalore.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger Scat Pack 392, 6 speed
2021 Ford Explorer
  #89
Old 06-26-2014, 06:47 AM
Thanks was allot of work and it's smoking hot here now I have to figure out how to flip it.
  #90
Old 06-26-2014, 04:26 PM
Dick Boneske's Avatar
Forgive the simple comment here, but many have made the mistake of checking steering clearance with the front end jacked up and front suspension hanging. I didn't see in your postings how you were checking clearance, but it can only be checked with weight on the front end.
Tires hit the frame badly when the car is jacked up in front--a condition you would not encounter in actual driving.
BONESTOCK GOATS
'99 Bonneville SE Sedan
  #91
Old 06-26-2014, 08:06 PM
The car was never checked with the wheels off the ground it was also checked by 2 frame shops with a digital caliper verifying the the measurement I also measured it against another frame that I have here I would have used it bt the right frt horn is rusted believe me I would not be doing this if it were absolutely necessary.
  #92
Old 07-01-2014, 08:14 PM
Default Making some rogress
Making good progress on the new frame swap really hot out very disappointed in the quality of the muffler hangers already separating .
Name:	car 005 (Small).JPG
Name:	car 002 (Small).JPG
Name:	car 008 (Small).JPG
Name:	car 001 (Small).JPG
  #93
Old 07-06-2014, 12:22 PM
gtome's Avatar
gtome gtome is offline
Really looking nice! Your about ready to drop a body on it!!
  #94
Old 07-06-2014, 01:07 PM
Thanks Steve just got chased out of the garage lightning struck so close made the air on my arms stand up .Sent pcs of the hangars and they are sending me a new set. Pulled the motor and frt end today cleaning and tweakin some things wanted to do a little differently now just need to figure out how to transfer the body hard to do by myself.
  #95
Old 07-06-2014, 08:28 PM
gtome's Avatar
That's not a one man job! Unless you have a 2 post lift.
  #96
Old 07-07-2014, 07:59 AM
Had to do it by myself last go round slow and easy got it done.
  #97
Old 07-08-2014, 08:28 PM
gtome's Avatar
I used 2 old engine stands to make a frame "rotisserie". I just welded round stock to some rectangular pipe and used a torch to make big holes in the end to run a big bolt with a big washer and bolt it to the frame.
  #98
Old 07-09-2014, 12:36 AM
BB70's Avatar
BB70 BB70 is offline
I've been using a engine hoist- sorry for the crappy pic.
John
  #99
Old 07-09-2014, 08:19 AM
That's what I did last time but now I have glass in the car just have to figure out how to distribute the weight and have nothing under the car so I can roll the new frame in.
  #100
Old 07-09-2014, 10:07 PM
gtome's Avatar
Yikes!
