Old 04-04-2014, 08:11 PM
mike leech's Avatar
mike leech mike leech is offline
Looking forward to you beating my number mike!
TV
I will be starting a thread with the mod to prevent this issue from happening.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #82
Old 04-04-2014, 09:17 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
There you go sharing valuable, real world experience and tech again, you're just a hater.
  #83
Old 04-05-2014, 01:39 PM
Tom Vaught's Avatar
Boost Engineer
To clarify I hope you make more HP than the 106x HP number I posted for your dyno hp session at BES.
Not sure what you were talking about on the "mod to prevent this issue from happening." What does a mod have to do with making over 106o+ hp?
Tom V.
  #84
Tom Vaught's Avatar
Boost Engineer
To clarify I hope you make more HP than the 106x HP number I projected for your dyno hp session at BES.
Not sure what you were talking about on the "mod to prevent this issue from happening." What does a mod have to do with making over 1060+ hp?
Tom V.
  #85
Old 04-05-2014, 10:20 PM
john marcella john marcella is offline
Tom V.
He ain't makin no 1060. Would be cool if it did but, it don't have a chance at 1060. JMO
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #86
Old 04-05-2014, 10:49 PM
Tom Vaught's Avatar
Boost Engineer
Just throwing out a High Goal. Realize that it was the highest projection of the posts to date. Still Chris U. said he would take a leap and project 1050.
Would be nice if it came within 20 HP of the number.
Tom V.
  #87
Old 04-06-2014, 08:28 AM
Chris Uratchko Chris Uratchko is offline
Hey go big or go home!!! I like lofty goals .... if the engine struggles to make the number try everything available ....
Uratchko Racing Engines
www.ure-racing.com
  #88
Old 04-06-2014, 09:27 AM
mike leech's Avatar
I will!
EHTTFMF!
  #89
Old 04-06-2014, 12:58 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Was the problem on the thrust?
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
  #90
Old 04-06-2014, 01:21 PM
mike leech's Avatar
Wasn't a thrust issue. Checked thrust clearance was good. This was an issue at the rear most part of the rear main bearing. First things first.. once the engine is back together tonight I'll post some pics and a mod to prevent.
EHTTFMF!
  #91
Old 04-06-2014, 11:37 PM
mike leech's Avatar
Ready for round 2.
EHTTFMF!
  #92
Old 04-07-2014, 10:07 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Ready for round 2.
cool glad its back together and ready to make some numbers!!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #93
Old 04-07-2014, 10:38 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Good luck, Mike. I'm sure it will make you proud.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #94
Old 04-07-2014, 10:50 AM
Best of luck Mike.... go make those numbers!
  #95
Old 04-07-2014, 06:10 PM
Transporter Transporter is offline
Tomorrow's the day, right? Hope it surprises you, in a good way.
  #96
Old 04-07-2014, 06:14 PM
PN's Avatar
PN PN is offline
Good Luck Mike!!!
Ultrastreet / Real Street 275 65 GTO
570 IA2 Tiger Head/Single Carb NA
4.79@144, [email protected] - 2900#
Thanks to: Uratchko Racing Engines, John Marcella, CFM Performance, Allpontiac.com, BOP Engineering, PTC
  #97
Old 04-07-2014, 06:41 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Good luck. Hope it makes some HP.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
  #98
Old 04-07-2014, 07:50 PM
mysticmissle's Avatar
Gd luck mike
  #99
Old 04-07-2014, 09:35 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Best of luck to you and the crew. I have a strong suspicion you put some valve action in it. :-)
1021.7HP Giddy Up!
  #100
Old 04-07-2014, 11:05 PM
1021.7HP Giddy Up!
Hey , 1021 is my number.
John Marcella
[email protected]
ph. 248-259-6696
