Old 05-14-2014, 06:00 PM
Elarson's Avatar
Elarson Elarson is offline
Plenty of pressure entering the block but we're not getting enough volume to the #2 bearing. Nitro takes a TON of oil because the combustion event lasts so much longer than in a gas engine.
#1 is ok because we're putting oil in at the IA2 "turbo oiling hole" (thanks Travis & Rodney for that idea). We're looking at restricting flow to cam bearings and adding an extra feed directly into #2.
Eric
  #82
Old 05-14-2014, 07:20 PM
Default Priority main feed
Try feeding the mains first... will require a little bit of plumbing, but... if you completely block feeds from driver side galley to driver side lifters... ALL oil goes to the mains first...
plumb new lifter feeds from passenger galley to valley side of driverside lifter bores.. Doing so feeds ALL the lifters LAST... adding a restriction to passenger galley entrance then restricts flow to all 16 lifters...allowing even more oil to go to mains 1st...however even with no restriction there, all lifters feeding from one galley are getting half as much oil as only 8 are normally being fed from one galley.
  #83
Old 05-14-2014, 08:41 PM
Elarson's Avatar
We remembered your idea from a previous post and have discussed it as a possibility.
Eric
  #84
Old 05-15-2014, 12:54 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
How about two pressure stages? One feeding exclusively the bottom end. As I've totally split off the top end oiling (and scavenging) of my hemi four cylinder, I'm considering separate pressure stages (might not be necessary for me, though).
Any idea how much air is entrapped in your oil by mid-track? Are you using an air/oil separator stage for the scavenged oil?
  #85
Old 09-07-2014, 12:20 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Bump!
Congrats to the guys at KRE and everyone involved! I'll throw in $100 just because it's awesome!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
  #86
Old 09-07-2014, 08:29 AM
vin63's Avatar
vin63 vin63 is offline
Yep, congratulated Jeff and the team last night and notified them my portion of the gentlemen's bet is on the way to Glenmont, OH.
1963 Tempest Convertible
Pontiac-Powered Funny Car:
400 block, Littlefield 8-71 blower, Enderle injection,
custom blower intake, three-disc glide clutch, three-speed Lenco
  #87
Old 09-07-2014, 08:30 AM
Elarson's Avatar
Can you PM me Jeff's address?
Thanks,
Eric
  #88
Old 09-07-2014, 06:47 PM
Ken Criss Ken Criss is offline
Thanks,
Eric
Kauffman Racing Equipment
22280 Temple RD
Glenmont, OH 44628
  #89
Old 09-07-2014, 09:13 PM
J.C.you's Avatar
J.C.you J.C.you is offline
going to have to start a 5.49 pool....
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #90
Old 09-08-2014, 03:38 PM
3fastgtos 3fastgtos is offline
Or a 250mph pool
  #91
Old 09-11-2014, 11:12 AM
Steve Barcak's Avatar
Originally Posted by 3fastgtos View Post
Or a 250mph pool
I agree. The next tangible goal in the Pontiac world is 250mph in the 1/4.
On ET, it would be in the 5.80s but, 250 will be the next biggie.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
