#81
Eric
| The Following User Says Thank You to Elarson For This Useful Post: | ||
#82
Go to the last post on previous page for the important news
Eric
#83
Looks great..... Thanks for the pictures and update |
#84
What size tires and wheels?
And as Paul said a 3/8 NPT fits perfect in the timing cover.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#85
Eric
#86
This is awesome build Elarson!
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235 |
#87
Nice Eric. I cant imagine the feeling coming off a turn with that torque!!
#88
Real good power for 10:1 motor.
I showed my dyno sheets and got bitched out LOL. Great Job. GT |
#89
However the material is somewhat thin and brittle, you have to be careful not to run the tap too deep and not over tighten the plug. In an endurance application like road racing I’d feel a whole lot more comfortable completely sawing off the hose nipple and tapping the hole in the cover for a plug.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
#90
Your engine (is nice!) has a pile of toque.....what's the limit on the trans?
A conclusion is the result of analysis of information: sound logic must be used, as well as accurate, applicable information. |
#91
I had a bone stock Super T-10 in my '77 T/A that didn't have any of the upgrades (billet mid-plate, billet bearing retainer) that I put into this one. That transmission survived a 450 ft-lb 455-HO with 9" slicks, drag racing launches on sticky tracks and never broke. Road racing will have far less impact loads; so I'm pretty confidant that it will have a long, happy life. Testing will confirm or crush that assumption. Eric
#92
Nice setup for sure. Sticky tires sure make corners fun! I autocrossed by 78 TA with 23x10x16 road race slicks ,then the 79 Camaro that has the IA in it now with 25x10x16 road race slicks.
I took my 78 TA with the stock 180 HP motor and 2.56 rear gear(stock) to Texas World Speedway road course for a Porsche event. The little 180 hp could only pull 4000 with the 2.56 top speed, but about 130. It would also run most of the course in 2nd gear with the TH350!
#93
He undoubtedly had less torque than you, but you won't be nearly as violent with the clutch and your tires will probably hold less than his drag tires. Best wishes, and I look forward to some in car vids.
#94
Things are happening:
The car is close enough to being done that I booked and paid for the first open track day at Mid-Ohio on 30 April. Concerning the ST-10; I had a conversation with Paul from 5speeds.com. I asked him about the low factory torque rating. He says that it is rated that way for infinite life in new cars subject to warranty claims. The actual capability of the transmission is much higher. I'm going to start posting updates on the things I've done to the car in the last year. Eric
#95
Here's the exhaust. 3" pipe, Hedman x-pipe kit, Dyna Tech mufflers. They're still pretty loud and some tracks have noise limits so I'll be testing the db level when the weather gets better.
Eric
#96
The current project is mounting a low oil pressure light and shift light. They have to be in my field of view without taking my eyes off the track. I ended up deciding that it would be a cool Pontiac tie-in to mount them in a hood tach housing. Housing will be white to match the hood and internal mounting plate will get painted black.
Eric
#97
Nice!
When I autocrossed on N CA they checked db level on the cars all the time. I think a local Pontiac guy here Larry Navarro broke his ST-10 with a healthy 455 and was not even ban shifting it at the time.
#98
Looks great! Thanks for the updates
Your exhaust is similar to my brothers. If those mufflers are too loud there a plenty of quiet, good flowing options available. |
#99
One of my intended tracks is Waterford Hills in MI. They have a 78 db limit measured at 90' from the track. Decibel meters are surprisingly cheap so I bought one to do my own tests. Since we live in the country, it's easy to have a friend stand in my front field, 90' from the road, and do a full throttle drive-by. Eric
#100
The Magnaflows on my brothers car a very quiet. This video will give you an idea of how quiet they are.
https://www.facebook.com/share/p/1KqQnuLVrR/ I use Pypes 3.5 race mufflers. They're also very quiet. https://www.facebook.com/share/v/1EXVK7QxnS/ Both cars make pretty good power and run about the same with and without exhaust. The Super Turbos are great but unfortunately Dynomax discontinued the good one that'll fit our cars. They will start to restrict an engine making more than 550 HP ..... The two mufflers we use don't seem louder than the big turbo mufflers and they won't' resonate as much inside the car. I've never worked with a decibel meter but turned downs off the muffler angled towards each other seems to hide some of the noise. Last edited by PAUL K; 02-26-2026 at 04:17 PM. |
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
