#81
Yep, there’s another video where he takes it to get checked out. definitely has a ridge and need to go .060 over. God I’d have that thing mag and cylinders sonic tested before I’d go .060 over. I hate to say it also pressure tested.
| The Following User Says Thank You to Gach For This Useful Post: | ||
#82
Whitmore had to send it to his crank guy. Now I gots me one of those 1200$ cast China cranks you can not trust or give away. So I gave it to my brother and implore him not to run it all the time. He seems set on running it. Should be fine but............. |
| The Following User Says Thank You to Dragncar For This Useful Post: | ||
#83
Knowing the number of cycles on a crank is meaningless unless you also know the G force loads on it, and these loads go up with the square of the rpm.
A cast crank might live forever at 6000 rpm ( like the 455 SD was designed to do) but snap instantly at 8K.
| The Following User Says Thank You to steve25 For This Useful Post: | ||
#84
Nope. One of the 454 BBC cranks purchased from Competition Products in MI. Unless you have access to the metallurgical composition of the base cast iron used I would NOT purchase ANY off shore cast crank, period. The ONLY off shore forged crank I would use would be from SCAT or Molnar. Everything else has too much taper, too much O/R and are out of stroke on EVERY rod journal. I don’t like grinding new cranks .010 under or more to make them useable.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
| The Following User Says Thank You to hurryinhoosier62 For This Useful Post: | ||
#85
