Old 01-30-2010, 05:13 PM
njsteve's Avatar
njsteve njsteve is offline
Quite right on the metal plating choice. No one plates with cadmium any more because it tends to kill people. Look at the recent news about Chinese-produced charm bracelets for (our) kids. The Chinese were told that there was too much lead in the metals they were making kids toys out of previously, so they stopped using the lead and started using cadmium - up to 95% by weight, of cadmium - that's more poisonous than wearing a plutonium necklace!
I'll be happy to take you up on the offer. I can swap out with whatever I have. Also, aren't there several designs of fan blades differentiated by the number/size of fins?
  #982
Old 01-30-2010, 05:37 PM
70RAlll 70RAlll is offline
Yes, the main problem with Cadmium is that it steralizes employees working around it(ouch !!) chemical castration !! But, the EPA still allows a handful of companies to use cadmium. It is still mandated for aero use because scientist haven't found anything better for rust prevention. One of the EPA's 1st orders(recall it was Nixon that signed the EPA into law) was to regul;ate the usage and disposal of cadmium. Anyway, so there is a handful of companies that still use cadmium-mostly platers for aero engine rebuilders. You see somany zinc platers advertising cadmium plating, but if you press them if it is real cadmium or zinc, you will get the zinc answer. As long as you don't grind on it and breath in dust, or eat it(as kids do with anything) you will be ok.Yes, I have seen 2 different fan blade configurations on Pontiacs. The earlier one(which Corvettes and Camaros used) is rarely seen. EMail me directly at [email protected] and give me your address. I will send you one and a nut that has been plated. You can send me yours back after you decide you like the cad plated sheen better than the zinc.. you will.. I will just do an even trade.. no charge..
  #983
Old 01-30-2010, 05:38 PM
Also, the blades I have all came off of late 72 or early 73 '928 alternators. I have a half dozen 927,928 and one 902 alternators. Only a couple are early 70's the others are 72-73 dates.. SO I am sure I have the correct fan..
  #984
Old 01-30-2010, 05:44 PM
njsteve's Avatar
Thanks...Oh, and I changed the temporary mudflaps to some plain black ones and created some blacked out clips to hold them in place without damaging the paint. ;-)
  #985
Old 01-31-2010, 03:59 PM
njsteve's Avatar
I found an NOS 3026085 thermo vacuum switch and installed that today. Very careful installation due to the outlet nipple and prongs that stick out. Had to be real gentle with the large open end wrench. Not a lot of room in there to swing the wrench.
  #986
Old 01-31-2010, 04:17 PM
njsteve's Avatar
Originally Posted by x-bird2 View Post
Steve;
Are you still looking for the wiring straps? see my post above, if you have a pic of an original, post it here so i can compare what i have.
I believe they are these. This is a shot of an original wiring clip on my Grandmother's 75 Firebird:
  #987
Old 01-31-2010, 05:23 PM
Norwood's Avatar
Norwood Norwood is offline
Steve PY has those I'm sure, but if they don't the other big Pontiac vendor has them
  #988
Old 02-01-2010, 01:23 AM
Yes, Craig is correct.. All of the Pontiac repo vendors carry good copies of these clips. I would buy them from our host, just seems natural togive them as much business as possible...
  #989
Old 02-01-2010, 03:36 PM
njsteve's Avatar
Anyone know the PY part number, off hand?
  #990
Old 02-01-2010, 04:17 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
PY part number RFE50A, $1.50 each (in an older paper catalog).
Regards,
"455HO" Lloyd
  #991
Old 02-03-2010, 06:29 PM
njsteve's Avatar
How's this for weird?
The bearing that is used for the front of the alternator on most Delco alternators is the exact same bearing used for the idler pulley setup on the larger, fixed mounted alternators (65 amp?) on cars with A/C and rear refog. I replaced the idler pulley bearing on my Grandmother's '75 Firebird a couple years ago and saved the bearing in case I needed it in the future.
When I took my 55 amp alternator apart the other day I thought that bearing looked familiar and lo and behold it was the same "6203" bearing.
  #992
Old 02-04-2010, 10:18 AM
72Formula's Avatar
72Formula 72Formula is offline
njsteve,
Not weird at all. I had a neighbor who ran a bearing distributor warehouse that told me bearings are made to a standard. It carries over to different makes, different years, different components, and on and on. Dimentions will be the same. Quality of materials will vary. It's universal, pretty much world wide(as far as I know). I suspect engineers will design parts with these standards in mind. You might be surprised if you could find a list of all the applications that bearing is used, and not just automotive. Industrial, aviation, marine, etc. FWIW
  #993
Old 02-06-2010, 02:28 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
njsteve, could you share what type/brand of primers and paint they used on your car? I'm thinking about going the single-stage route on my '71 T/A.
  #994
Old 02-08-2010, 05:53 PM
njsteve's Avatar
I went to the bodyshop today to get your answer. It's a PPG single stage called Concept DCC:
  #995
Old 02-08-2010, 05:56 PM
njsteve's Avatar
He's getting all the panels ready to shoot all at once - the spoilers, tail panel, fender flares and hood. They are also working on the nose and plastic valance which will be shot seperately, with a flex agent.
  #996
Old 02-09-2010, 02:07 AM
Steve- If you wantthe nose to be 100% perfect, tell them notto paint all of it. There is a strip along the foward facing part that was left natural black and was not painted-99% of resto's paintoverthis part and it is technically incorrect. There are 4 screws that hold the bottom brackets to the front grilles(2 each side). The strip where these screws mount, is what I am talking about. We discussed this before and there are pictures on some other thread.. ALso, I recieved your pulley this weekend. it went to the plater with other parts I was sending this morning. I will have itback to you next week. bill
  #997
Old 02-09-2010, 08:45 AM
njsteve's Avatar
I thought that area was actually painted flat black? Do you have any photos I can show the painter?
With the pastic valance, all that area gets covered by the valance anyway. I guess it's more critical on the steel valance cars since that area is very visible with the open lower area.
  #998
Old 02-09-2010, 10:19 AM
I think I may have not explained myself good. The part I am talking about is at the top of the opening in the front of the nose. I will talk some pictures of an original blue nose Ihave. Yes, many paintit flat, but in reality...that area was just un painted. The endura material is a dullblack material, hence the flat black painting.. but it is really suposed to be un painted.. I will post a couple pictures later today..
  #999
Old 02-19-2010, 06:20 PM
njsteve's Avatar
Thanks to 70RAIII, (Thanks William!), I now have the correctly plated fan, nut and pulley on the the correctly finished (metal, not paint) 1100928 open-face alternator. William can chime in but I believe the finish he got is actually the correct cadmium, like the originals, which is more of a satin finish and not as chrome-looking as the clear zinc that is substituted these days for cadmium, by most industrial platers.
  #1000
Old 02-19-2010, 06:54 PM
Norwood's Avatar
Bill, is a cadmium freak LOL
