Old 06-10-2022, 05:58 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Originally Posted by 64speed View Post
Yes the light came on and it got to 230 today
David, Im not sure how far from you, but there's a shop called Classic Pontiac Rescue in Donald's SC. The owner is a member of the Palmetto Pontiac club with many knowledgeable members. Maybe by reaching out you could find some assistance.
  #1002
Old 06-10-2022, 06:52 PM
64speed's Avatar
64speed 64speed is offline
Yeah I sued him along with 4 other people
  #1003
Old 06-10-2022, 06:53 PM
64speed's Avatar
Ask Caster1 about CPR too. I was a deputy in Anderson County. I can tell you more than 4 horror stories
  #1004
Old 06-10-2022, 08:30 PM
68WarDog's Avatar
[QUOTE=64speed;6348665]Ask Caster1 about CPR too. I was a deputy in Anderson County. I can tell you more than 4 horror stories.
Wow he sounds like complete scum.Just saw his name pop up on the Palmetto club newsletter. Jesse Anderson and until a few years ago, Larry Snyder were also members, although I haven't touched base with them since Larry moved his shop.
  #1005
Old 06-18-2022, 02:08 PM
grivera's Avatar
grivera grivera is offline
Dave - any update on this filling system?
Will Rivera
  #1006
Old 06-19-2022, 06:24 PM
64speed's Avatar
Nothing to report,I have been at the beach. Truthfully I am at a loss. I don’t want electric fans but I don’t know what to do.
  #1007
Old 06-21-2022, 04:37 AM
64speed's Avatar
I called Derale and ordered their best 16 inch fan. It’s supposed to cool at idle. Trying to avoid that big shroud setup that cold case sells I really don’t want all that under my hood. I got enough crap as it is. I’m not excited about the fan but I gotta do something
  #1008
Old 06-21-2022, 09:00 AM
HWYSTR455's Avatar
Part number?
You really need to check your timing first, but since you already pulled the trigger...
  #1009
Old 06-21-2022, 09:50 AM
grivera's Avatar
Is a Mark VII fan to big?
Will Rivera
  #1010
Old 06-21-2022, 09:58 AM
64speed's Avatar
Ok I have tried and tried to get help with my timing and I can’t get anyone over here. I know my initial should be between 12-15 when cranking. I have the factory bushings in it that came with the Summit ready to run of which they provide you no information. It runs better on full manifold vacuum at idle or cruise but that would be if it’s like an MSD almost 41 degrees of timing. If I back it off it’s starts running like crap.
  #1011
Old 06-21-2022, 12:38 PM
grivera's Avatar
Is help needed for technical knowledge? I ask cause I have short arms and adjust timing by myself. Also, are you saying you've tried and verified 15 initial and 10 VA (manifold) and it didn't help with idle temp?
Will Rivera
  #1012
Old 06-21-2022, 12:53 PM
64speed's Avatar
I can’t see that great but I am pretty sure I’m on 13 initial. When I plug the vacuum advance and it’s just running whatever the distributor advance is it still creeps. Same with ported. If I put the vacuum on it it still creeps just much slower but I can’t get the summit guys to tell me how much advance the can adds. I’m 42 and have cataracts from Prednisone shots so it’s hard for me to see
  #1013
Old 06-21-2022, 03:48 PM
Tom Vaught's Avatar
Boost Engineer
I would suggest you send a PM to "Suntuned" & his dad and have them set up the distributor on their equipment properly for you. Worth the money to have them check it out on their distributor machine equipment.
Tom V.
The Following 2 Users Say Thank You to Tom Vaught For This Useful Post:
  #1014
Old 06-21-2022, 07:03 PM
77 TRASHCAN's Avatar
Bob, is one of the "answer men", here, and period!!!
Shut it off
Shut it off
  #1015
Old 06-22-2022, 08:36 AM
P@blo's Avatar
P@blo P@blo is offline
Your engine is a distributor machine and paired with the information available you are in a good spot to figure things out for yourself. And you might save a few bucks and learn a bunch along the way.
https://www.tapatalk.com/groups/raci.../ignition-f21/
And any info posted by Tuner is very informative including quadrajets. Especially quadrajets. He also modifies HEI advance by bending at the pivot points of the weights. Very smart guy and would likely be the answer man to our answer men.
The Following User Says Thank You to P@blo For This Useful Post:
  #1016
Old 06-22-2022, 09:23 AM
64speed's Avatar
My nephew is coming this weekend. I am gonna curve the distributor with the kit that came with the distributor as close as I can to the engine builders specs. I also ordered two 12 inch fans and a relay kit. If that doesn’t fix it then I don’t know what.
  #1017
Old 06-23-2022, 11:56 PM
64speed's Avatar
I got all my parts today but it was just too hot to work. I did drive it about 60 miles and with the ac on at stoplights it would go up to 200 but I wasn’t at them long. Start moving again and it would go back to about 185. Will do all the work that needs to be done this weekend and report back.
  #1018
Old 06-24-2022, 08:47 AM
Murf Murf is offline
Sounds like it’s cooling pretty well. If you don’t mind be asking, what temperature are you wanting to get to? Your car hasn’t ever boiled over has it?
Good luck!
Murf
  #1019
Old 06-24-2022, 09:07 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Good luck!
Murf
I agree. I don't think you're ever gonna get this to idle, with the A/C on, and stay near 185. Maybe put it on E85 or methanol. lol I'd say you're lucky to stay near 200. You can throw it in neutral when you're stopped and rev the engine up slightly. This can have a dramatic affect on your temp. I know it's a pain. But it does work.
  #1020
Old 06-24-2022, 09:12 AM
JSchmitz's Avatar
I never considered A/C an option on my '64. It was all I could do to keep the 455 cool. I had it under control. But knew that air would put it out.
The Following User Says Thank You to JSchmitz For This Useful Post:
