#101
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
#102
AG - Thanks for the comparison, that looks to me that the band is correct, or am I missing something? Do the Cranes ship with the cut in the body?
#103
Ok, so it's better to mod the block than the lifter, correct? .
#104
The Crane lifters come like that from Crane already cut. They look like the oil band is in the correct location like a stock Pontiac and not a Chevy lifter.
#105
Neat, that's what I just did with a DZ build (nitride and using solid flat tappets with EDM hole)
#106
Dang inbox was full, had to clean it up some...
So maybe it's worth spending the extra for the Crane HYD roller lifters? I'd like to see a Morel, Comp S, and Crane next to each other, if any have the ability to do that... .
#107
243/251 @ .05 with .569/.582 lift. The valve train noise is minimal and it runs like a scared rabbit. 3,500 miles and no issues.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds. |
#108
Most of the modern solid grinds today run pretty tight lash (.014-.018) from the ones I've used and seen, so they really don't make all that much noise anymore like they did back in the day when we would run .030" for instance.
#109
Yes.
#110
Where's a pic of what LSM did?
#111
Mine calls for .022" intake and .024" exhaust. I set both .002" tighter.
#112
#113
#114
I get that, but the cut upwards is not in line with the oil hole in the block, so it is still edge orifice oiling on the base circle. That cut upwards needs to be inline with the oil hole to be effective enough to provide the needed volume of oil during the very short time the lifter sits on the base circle. The top of the oil band is what's important, as long as the bottom side doesn't come out of the bottom of the lifter bore.
#115
I will have to think about getting the proper location machined to line up with the oil hole then. I don't want any issues with these after I install them.
#116
Lower the oil hole in the block, if the block is not assembled yet.
#117
Just make a channel (~0.040" deep?) leading from the oil hole in the block down about a 1/4 inch?
#118
I'd rather modify the lifter, easier to work on, than get a carbide bit chattering in a lifter bore, then having to deal with THAT...
#119
Paul, what tooling process did you use to add those slots in the lifters?
#120
The gist is that hydraulic roller lifters aren't correct for a factory Pontiac block without modifying the block or lifters. It seams at the very least this can cause excessive noise and likely not achieve the level of performance that one would expect. At the worst it could damage the lifters lifter bores or both.
-Jason 1969 Pontiac Firebird Last edited by JLMounce; 06-08-2016 at 11:14 PM. |
