Old 12-31-2010, 02:53 AM
webfoot's Avatar
webfoot webfoot is offline
Yep, that is the one from my 71 chevy pickup. Had to modify the fuel line a bit.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
  #102
Old 02-16-2011, 06:29 PM
webfoot's Avatar
Not much to report photo wise, except to say that the mechanicals are almost done, and I will be bleeding the brakes soon. Going to try some Marson platinum plus filler with my new "hutchins hustler" air sander, after I get some rust fixed from the bottom of the driver's door.
Got the wheel vintique rally Is today, 15 x 7 front, 15 x 8 rears, and ordered a set of 235/60/15 and 275/60/15s redlines from Diamond Back.
-Jeremy
  #103
Old 03-02-2011, 11:12 PM
webfoot's Avatar
Love em!
-Jeremy
  #104
Old 03-03-2011, 09:05 AM
jeffgoss's Avatar
jeffgoss jeffgoss is offline
Thumbs up
What size are those Redlines? Are they the Coker ones?
When my tires wear out, I'm getting a set of 15", just not sure what size I want to run.
They look great!
Jeff
1968 GTO
400 4 speed 3.55 posi
  #105
Old 03-03-2011, 11:23 AM
webfoot's Avatar
These are diamondback "LS5" redlines. i did a search on here and did not see many good reviews on the cokers.
Front are 235/60/15 and rear are 275/60/15.
I was glad these balanced out good, there was not much weight added.
-Jeremy
  #106
Old 03-05-2011, 11:34 PM
jeffgoss's Avatar
Sorry. I should have read your previous post. I just looked at the pictures and got excited.
The 275's should fit out back with no mods?
Where did you buy the tires, if you dont mind me asking?
The first site I googled for them listed them at what appeared to be an incredibly high price...
Thanks!
Jeff
1968 GTO
  #107
Old 04-12-2011, 08:58 PM
jeffgoss's Avatar
Webfoot,
Can you tell me where you bought these Redlines?
I think I would like to get a set.
Approximate price?
Thanks alot!
Jeff
1968 GTO
  #108
Old 10-18-2011, 11:23 PM
webfoot's Avatar
Originally Posted by jeffgoss View Post
Webfoot,
Approximate price?
Thanks alot!
Here is the link. Price was between 900-1000. http://www.dbtires.com/ Sorry it took so long, I didn't see your post initially. Yes, the 275s fit out back with no issues.
Not a lot of pics for a while but I have been working. I just sandblasted the LAST big piece (thank god thats over) and now just waiting for the new electric motor for my compressor to show up. (thats another ordeal altogether)
I bought a fender to replace the one that came with the car because it was complete junk. The replacement fender I bought from a member here happened to have some rust in the only place on my original fender that was any good. I cut it out prior to blasting because I knew I'd need to blow out a lot of rust and scale.
You can see from the inner bracing that this was very scaly inside, which caused the outer sheetmetal to rust through in several places. The 2nd pic shows the underside of the piece I cut off.
only thing now is to cut the piece out of the other fender. Just one little dimple to hammer out! I have both doors pretty much ready to go and one is hung on the car already. The other fender has the dogleg replaced already and is in epoxy primer.
-Jeremy
  #109
Old 10-19-2011, 01:28 PM
You don't see many '68s with Rally I wheels. I just bought a set from a member here and was thinking about it myself. Looking forward to seeing them on the car.
Old 10-19-2011, 01:53 PM
webfoot's Avatar
I know I am in the minority but I like the Is better than the IIs. Rally Is with redlines is original equipment on this one according to my PHS.
-Jeremy
  #111
Old 10-19-2011, 06:45 PM
I don't think you're in the minority there. I like them equally and I think most do...It's just that the Ones are harder to get and the Twos have been plentiful for years..(they are getting a bit harder to find any more though)... The Ones are kinda expensive too.
I bought mine because I always wanted a set and it was a good deal..even considering the freight shipping.
Here's a Rally I Chrome bumper '68 I've seen at two BOP shows now.
  #112
Old 11-10-2011, 01:55 AM
webfoot's Avatar
My compressor motor crapped out on 9/21 and I took it to a local shop to see if it could be fixed. They said it couldn't and they could order me a new one. It finally showed up Monday 11/7. I installed it the next day and got one tank full. When the pressure switch kicked on again it went silent. i was spraying some epoxy primer on that LH fender pictured above. Well, come to find out the pressure switch is smoked too. Jeez I can't wait to be making some progress for once.
-Jeremy
  #113
Old 11-10-2011, 10:03 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
[QUOTE=Greg Reid;4444986]I don't think you're in the minority there. I like them equally and I think most do...It's just that the Ones are harder to get and the Twos have been plentiful for years..(they are getting a bit harder to find any more though)... The Ones are kinda expensive too.
Got to agree.Rally 1's over 2's on a 68 just look sweet.
Leo
  #114
Old 11-12-2011, 01:12 AM
Jeremy, I've been watching your post as I to have been working the 1/4ers on my 68. I recently been finishing up putting patches on and found after trying to fit the w/w moldings on the 1/4 it seems to need to be trimed at the end(bottom) they I thinkb are to long. I was wondering if you tried fitting your moulding yet and had any issues? The third picture is the area I am concerned with. thank tom
Name:	gto 14 029.jpg
ID:	263209   Click image for larger version
ID:	263210   Click image for larger version
Name:	gto 14 027.jpg
  #115
Old 11-14-2011, 01:08 PM
webfoot's Avatar
haven't tried to fit the moldings yet as I don't believe I have them all anyway. But yes that looks like a familiar photo and I bet I will have to trim mine too. I would just cut a pie shape into the bottom and push it up once you know how much is needed to be lopped off.
-Jeremy
  #116
Old 11-23-2011, 12:46 AM
webfoot's Avatar
Got the top of the fender patched, now to tackle the lower one.
-Jeremy
  #117
Old 11-23-2011, 12:42 PM
Looking good Jeremy. Nice looking welds..which is something I still struggle with sometimes.
Old 11-23-2011, 11:39 PM
6869GTO's Avatar
Lines look great! nice job!
Leo
  #119
Old 03-20-2012, 09:54 PM
webfoot's Avatar
What a monumental day, i just finished my last big welding project. I had to trim 1/16" off the patch piece since it was too wide.
It is starting to get pretty exciting. Too bad it is too cold to spread bondo or I'd be up to my elbows in it still.
-Jeremy
  #120
Old 03-21-2012, 10:06 AM
You running those Rally I wheels on there? Looking good so far.
