Old 04-19-2017, 08:04 AM
Kurt L71S's Avatar
Kurt L71S Kurt L71S is offline
Made the trip to Chuck's Engines yesterday. Chuck has her breathing once again...and breathing very well I might add!...
The TH350 Trans is a total rebuild and is ready to install...
Thanks Chuck Peterson for everything you have done for me! It is an honor to have you as a friend!...
I have a video of the 350 running on the stand. You will need to visit this Facebook page to check it out!
https://www.facebook.com/kurt.keller.969
Name:	71 Lemans Engine Started 002.jpg
ID:	452449   Click image for larger version
Name:	71 Lemans Engine Started 005.jpg
ID:	452450   Click image for larger version
Name:	71 Lemans Engine Started 012.jpg
ID:	452451   Click image for larger version
Name:	71 Lemans Engine Started 014.jpg
ID:	452452   Click image for larger version
Name:	71 Lemans Engine Started 015.jpg
Kurt L71S....1971 LeMans Sport Coupe 350/TH350
  #102
Old 04-21-2017, 01:21 PM
JG'SGTO JG'SGTO is offline
Good to hear you are making progress.
  #103
Old 04-27-2017, 11:43 AM
Kurt L71S's Avatar
Thanks JG,
I now have the 350 engine back in the shop and ready to get her installed along with the newly rebuilt TH350 Trans...
My hope is....this Sport will sound and run great! Can hardly wait to fire her up!
ID:	453179   Click image for larger version
ID:	453180   Click image for larger version
  #104
Old 05-02-2017, 07:47 AM
Kurt L71S's Avatar
Made some serious progress yesterday. Mated the Trans and the Poncho 350 and shoe-horned them into place. She fit like a glove...
Removed the Front End for an easy install of the Engine/Trans. I needed to secure the front fenders having removed the radiator Core. Installed hooks in the ceiling and used straps to hold them in place...
I now have the honor of making sure everything finds a place to live....the alternator, power steering pump, lines, fuel pump, etc....:3
gears:
Name:	71 Lemans Engine_Trans Install 002.jpg
ID:	453625   Click image for larger version
Name:	71 Lemans Engine_Trans Install 007.jpg
ID:	453626   Click image for larger version
Name:	71 Lemans Engine_Trans Install 010.jpg
ID:	453627   Click image for larger version
Name:	71 Lemans Engine_Trans Install 011.jpg
ID:	453628   Click image for larger version
Name:	71 Lemans Engine_Trans Install 013.jpg
  #105
Old 05-02-2017, 07:51 AM
Kurt L71S's Avatar
More from yesterday's work in the shop!...
Name:	71 Lemans Engine_Trans Install 015.jpg
ID:	453630   Click image for larger version
Name:	71 Lemans Engine_Trans Install 016.jpg
ID:	453631   Click image for larger version
Name:	71 Lemans Engine_Trans Install 018.jpg
ID:	453632   Click image for larger version
Name:	71 Lemans Engine_Trans Install 019.jpg
ID:	453633   Click image for larger version
Name:	71 Lemans Engine_Trans Install 020.jpg
  #106
Old 05-02-2017, 11:49 AM
Judge-1969's Avatar
Judge-1969 Judge-1969 is offline
Looking good Kurt!!!
1971 Lemans Post
  #107
Old 05-02-2017, 12:57 PM
West Coast GTO's Avatar
West Coast GTO West Coast GTO is offline
Kurt,
Boy, it really makes it easy to get the engine/ trans in the bay with no front sheet metal!
I also have to remove the radiator support to R and R; how did you attach the other end of the straps from the fenders? Ceiling studs?
Also, any pictures of the support modification from 70 to 71?
  #108
Old 05-02-2017, 01:01 PM
Kurt L71S's Avatar
Originally Posted by West Coast GTO View Post
Kurt,
WC,
Yes I used Porch Swing hooks drilled into the rafter studs....Worked like a charm.
I don't have any further photos for the support..do have the top removed from the 71 core...should be a cakewalk from here on the core....I will post photos when we get it welded up..will do that when it goes to paint....
Will get the car running next. I will post photos of the core as it is now....
Thanks WC
  #109
Old 05-02-2017, 01:03 PM
Kurt L71S's Avatar
Thanks Judge,
So nice of you to look and comment.....
  #110
Old 05-02-2017, 08:06 PM
Kurt L71S's Avatar
With time..&..an Assembly Manual....Things have a way of finding a home on the block...
About ready for the Core Support and Radiator. Ordered the GTO exhaust and chrome splitters. Get them installed along with the wiring and the shifter linkage.....It'll be time to fire her up....
Name:	71 Lemans Engine Acc Install 002.jpg
ID:	453677   Click image for larger version
Name:	71 Lemans Engine Acc Install 007.jpg
ID:	453678   Click image for larger version
Name:	71 Lemans Engine Acc Install 009.jpg
ID:	453679   Click image for larger version
Name:	71 Lemans Engine Acc Install 010.jpg
ID:	453680   Click image for larger version
Name:	71 Lemans Engine Acc Install 012.jpg
  #111
Old 05-03-2017, 03:00 AM
Shiny Shiny is online now
You're seriously getting this DONE!
Looks great, nice of you to share your success through all these photos.
Keep having fun!
  #112
Old 05-03-2017, 07:52 AM
Kurt L71S's Avatar
Keep having fun!
Thanks Shiny,
We are having a GR8 time with this Poncho! I appreciate your taking the time to look and comment...
That is what THIS is all about....Enjoyment for us and OTHERS!...
  #113
Old 05-04-2017, 09:26 AM
Kurt L71S's Avatar
Started work on the new 1970 Core Support. I drilled out the spot welds and removed the top from the 1970, ground the rough spots, primed and painted. Ready to tack the top from my 1971 Core....
Also reinstalled the driver's door now that the new pins and bushings have been installed. ...
The original radiator with it's tag still intact.....
Name:	71 Lemans Radiator Core Support 003.jpg
ID:	453773   Click image for larger version
Name:	71 Lemans Radiator Core Support 005.jpg
ID:	453774   Click image for larger version
Name:	71 Lemans Radiator Core Support 001.jpg
ID:	453775   Click image for larger version
Name:	71 Lemans Radiator Core Support 002.jpg
ID:	453776   Click image for larger version
Name:	71 Lemans Radiator Core Support 007.jpg
  #114
Old 05-04-2017, 09:30 AM
Kurt L71S's Avatar
Kurt,
West Coast,
I have included a couple of photos with the hooks I used for supporting the fenders of "Blu BiYu".....
They are working wonderfully and haven't let her down yet!...
Name:	71 Lemans Engine Acc Install 003.jpg
ID:	453778   Click image for larger version
Name:	71 Lemans Engine Acc Install 004.jpg
  #115
Old 05-04-2017, 09:36 AM
Looking good. You are getting there.
  #116
Old 05-04-2017, 09:38 AM
Kurt L71S's Avatar
Thanks JG....
Won't be long now....should be getting the new exhaust tomorrow
  #117
Old 05-04-2017, 12:34 PM
Kurt,
Your car is going to be awesome when you are done. Thanks for the photo of the fender strap supports and radiator support modifications.
Can't wait for the video of the engine running in your car!
Originally Posted by Kurt L71S View Post
West Coast,
  #118
Old 05-06-2017, 10:03 AM
Kurt L71S's Avatar
Need some information regarding the center caps for the Rally I....
Has anyone had a set of these caps on Corvette rallys 15 x 8?
I have included a couple of photos. I am looking to possibly use my Corvette wheels and try finding a set of Rally I caps if they WILL fit the wheels.....
ID:	453914   Click image for larger version
ID:	453915   Click image for larger version
  #119
Old 05-06-2017, 01:26 PM
Kurt,
What happened to the Torque Thrust D's you were going to use? I thought they looked great!
  #120
Old 05-06-2017, 01:39 PM
Kurt L71S's Avatar
Kurt,
WC, I'm still planning on using the AR Torque Thrust D's. I would also like to try the others too... 😎
