Old 04-03-2019, 06:38 PM
pastry_chef's Avatar
Originally Posted by Navy Horn 16 View Post
Have you tried it in all gears? Same thing at same RPM in each?
I recall you had an interesting issue, in your case a little intermittent.
http://forums.maxperformanceinc.com/...65&postcount=1
What are the odds?
  #102
Old 04-03-2019, 06:55 PM
mchell's Avatar
mchell mchell is offline
Originally Posted by TAQuest View Post
Bog. Loss of power. Will not go any faster. Like valve float. Maybe a bad carb float setting? Messed up carb? I'm on it tomorrow. Learning what it's not. It has the right power to the HEI. Fuel is being delivered correctly. The heads seem fine. It has great compression. Runs great right until it hits the rpm wall at about 3K now.
Might want to set up your phone and take some driving video with sound?...might shed some light
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
  #103
Old 04-03-2019, 07:03 PM
TAQuest TAQuest is offline
I have that, I took the video of the fuel gage with my I Phone. You can't hear much though. It sounds like it runs great. Just a little 'breaking up' sounds at the end of each gear.
  #104
Old 04-03-2019, 07:08 PM
mchell's Avatar
Post it
  #105
Old 04-03-2019, 07:13 PM
Post it
How would I do that from my I phone? Is it easy?
  #106
Old 04-03-2019, 07:18 PM
mchell's Avatar
Sure ..... tons of ways.....YouTube, Vimeo, cloud link........etc etc
  #107
Old 04-03-2019, 07:19 PM
Can I text it to you and you post it? Thanks
  #108
Old 04-03-2019, 07:25 PM
mchell's Avatar
Try this first
Click on the video on your phone.... use the box with the up arrow like you are going to send it to someone.....scroll through your sending options and use “copy iCloud link” .......using your phone to navigate to this site , open the thread and paste the link.... should work
  #109
Old 04-03-2019, 07:35 PM
I followed your instructions. When I pressed on copy icloud link it said it was preparing then it went back to the video. I went to this thread and didn't know what to do next. I didn't see how to paste it in a message. How do you do that part?
  #110
Old 04-03-2019, 07:37 PM
mchell's Avatar
Start a reply to this thread with your phone ....click anywhere in the reply window and “paste”
  #111
Old 04-03-2019, 07:40 PM
When I click on the reply window the keyboard pops up. How do you paste? Don't know how to do that with an iPhone.
  #112
Old 04-03-2019, 07:42 PM
mchell's Avatar
Tap on screen (once briefly)until you see blinking cursor....tapping again should show the paste option
  #113
https://share.icloud.com/photos/0iS4...r_Township,_MI
  #114
Old 04-03-2019, 07:46 PM
WOO HOO Did it.
  #115
Old 04-03-2019, 07:52 PM
mchell's Avatar
Interesting....the fuel pressure is dropping quite low...very difficult to tell what’s actually going on due to wind noise...I thought I did hear it start to bog down in some fashion
Need another one from in the cab pointing at tach maybe?
  #116
Old 04-03-2019, 07:58 PM
Sure thing. Right after I swap the carb tomorrow morning.
  #117
Old 04-03-2019, 08:10 PM
mchell's Avatar
You’re on a roll!
  #118
Old 04-04-2019, 07:56 AM
STEELCITYFIREBIRD's Avatar
Curious if it does the same thing if you roll up and then beyond that RPM, but aren't standing on it??
  #119
Old 04-04-2019, 08:14 AM
I'm swapping the carb off my old plow truck. Same carb just old, dirty and off a Chevy. Feels wrong. lol
Then I will take a test drive with a video and it will be easier to see what's going on.
  #120
Old 04-04-2019, 08:55 AM
Default Possible
Only seen this happen on Carter/E-carbs, where the needle's seat screws in pointed up. Seat loose and backs out BUT the float drop tang doesn't let it back out all the way.
Float level ends up way low closing the needle and seat. And at the same time, not enough fuel leaking through the threads for the carb to load up and flood. Did see one that would load up if you let it set at idle for a long time.
On a dual plane intake you end up losing four cylinders when the bowl gets sucked dry.
Depending on float drop setting, the fuel starving could get worse with time as the seat backed out and dropped full float level. Float pushing up against the seat kept it from backing out all the way at one time.
Only seen this a few times (3 maybe) in the past 45 years or so.
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
