Old 04-20-2026, 01:45 AM
jhein's Avatar
jhein jhein is offline
Maybe even an air dam on the lower leading edge of the tank would help cool it.
Just thinking out loud...
That would be pretty cool, but it's beyond my skill level.
Separately, I will say that my driving habits for this car are pretty routine. I drive in the morning and here in my part of OR even in the summer when the highs are in the 90s+, when I'm diving it is usually in the 50s with continuous travel, no stopping. So there's lot's of convective cooling.
Now, I know it's not a great idea to build a car that can only tolerate a narrow range of conditions, I get that, but just saying.
Old 04-20-2026, 06:57 PM
jhein's Avatar
OK, this is the most clearance I can get. It is an improvement. That is with the upper rear edge of tank hitting the stops that are on the floor pan of the trunk.
My carriage bolts are much longer than they need to be. Not a big deal on the right side but on the left side the tank is pushed up against it. I think I need to cut that bolt a bit. Also, there are some large spacers on the bolts that are limiting how much I can tighten the straps. I think those both need to go. You can see in the pictures that the straps aren't tight up against the tank along the whole length.
Another thought is that I could use some strips of rubber as spacers to drop the rear of the tank about an inch to clear the stops on the floor pan. That would give me a little more clearance from the muffler. Or, I could just go to a dual muffler exhaust and make this a lot easier. Although Formulajones seems to do these tanks systems with the transverse mufflers without difficulty, so maybe I'm just missing something.
Oh, and here's how my pump fittings worked out.
The Following User Says Thank You to jhein For This Useful Post:
Old 04-20-2026, 08:18 PM
Gator67's Avatar
Gator67 Gator67 is offline
Was the old fuel tank further away from the muffler? Just wondering why this is a problem now and not before. I apologize if you explained this already and I missed it. It looks like you have sufficient space…why not run it for a while to see if you run into issues?
The Following User Says Thank You to Gator67 For This Useful Post:
Old 04-20-2026, 11:35 PM
jhein's Avatar
I never really paid that close attention the previous setup since I didn't install it. But you're probably right that it was likely similar. I'm sure it will be fine. I just need to get the straps and bolts figured out so I can move on to the rest of it.
Old 04-21-2026, 02:00 PM
73ta's Avatar
73ta 73ta is offline
I went hard lines from the tank tucked into the seam of the tank insulated and wrapped the muffler with heat shield. No issues, but I run an in tank pump with a return reg via 1/2" lines which circulates the fuel and probably helps also.
Old 04-21-2026, 04:41 PM
Gator67's Avatar
Can also reduce heat with a fuel controller that adjusts pump speed based on demand (rather than the pump running at 100% regardless of fuel demand).
Old 04-26-2026, 07:29 PM
jhein's Avatar
Made some good progress today. I got the tank straps bent/shaped about as good as I think I can, so that's done. I got the hole cut for the access door. Mounted the relay and circuit breaker. I'm gonna pause here because my suspension parts are on the way from PTFB and I want to do the rear before I "permanently" mount the tank. But really, everything is pretty much done except for the fuel lines. I still need to do some proper cable management, but I'll get that all tidied up.
Old 05-02-2026, 03:28 PM
jhein's Avatar
I've made the decision to ditch the transverse muffler setup. It will just make things much easier. Plus, I got the Pypes SGF41V, dual violator muffler setup so that will mean a little better flow and a much more aggressive sound. I ordered the kit from Summit. It was $14 less and had free shipping. It's shipping directly from Pypes who were going to charge me like $180 for shipping. So not a bad deal going through Summit.
