Old 04-22-2017, 10:32 PM
Tiger Paw Tiger Paw is offline
I would think this level of performance would demand a dry sump system.
Old 04-22-2017, 10:36 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Why?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 04-22-2017, 10:57 PM
Elarson's Avatar
Elarson Elarson is offline
It will get difficult to keep a wet sump pickup covered with oil at both ends of the tracks if you run in the 6's (roughly speaking).
If your bearings show distress, don't be shy about raising your oil pressure. Rodney and Travis run something in the 125-140 psi neighborhood. Especially watch your rod bearings. If they run too dry and spin bearings, it will tear rods loose.
Eric
Old 04-23-2017, 12:45 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Originally Posted by Elarson View Post
... It will get difficult to keep a wet sump pickup covered with oil at both ends of the tracks...
Listen to the man!
Old 04-23-2017, 08:49 AM
Tom Vaught's Avatar
Boost Engineer
Dry Sumps have many advantages over a "WET" Oil system.
Very Fast Street Car with today's Dry Sumps can live on the street for a long time.
Porsche Cayenne has one stock, Ford GT Has one stock, (did not say Mustang).
Marty ran one in 1996 (FOR A REASON).
You really have to "cover all of the bases", not just slap some turbos on a engine and call it good if you are running quick times in drag racing. Road Race cars, (except the street type stuff or Hobby stuff) typically run a dry sump for better oil control and also for SAFETY.
The basic systems should be covered before the other parts are added or at least designed into the basic package FIRST. Not as a afterthought when the stuff you used does not work. Then you are just doing "DO-OVERS"
Bob and Frank did a killer Dry Sump system for a Pontiac (VERY PROFESSIONAL DEAL) THEY MAYBE SOLD A HANDFUL OF THE SYSTEMS TOTAL). Sad.
Tom V.
Old 04-23-2017, 10:05 AM
Elarson's Avatar
I love the simplicity of a wet sump. Grocery Getter was fine with one into mid-7's and we tried it on funny car but it let us down.
Eric
Old 04-23-2017, 10:09 AM
Tom Vaught's Avatar
Boost Engineer
The Parts Ed is putting on his car reflect a 6 second capability.
Food for thought.
Tom V.
Old 04-23-2017, 03:58 PM
Dragncar Dragncar is online now
Leech told me he had to go dry sump at the RPMs he wanted to run. Either that or a lot of time. effort and risk making a pan with serious baffles.
Shifted @8,800 and crossed the line 9K+ I believe. Out of E heads with stock valve location and stock E guides. Safe to say they were maxed out.
I have L jacks old E heads done my Gabby. Flow 408cfm. Mikes went 414 (and Marcella with tell you cfm is only 48% of the answer, I believe him)
Gabby told me the heads will pull to 7500 with a 535 and 7800 with a 505.
Almost the same cfm and Mikes heads had 1000RPM more "pull" to them with a 565 no less.
Tells you its all about the combo. That and 18-1 and a BOP with a ton of work done to it.
Anyway, might want to consider dry sump.
Old 04-23-2017, 05:46 PM
Build yourself the whizziest oil pan and baffles you can dream up. Put it in your hands full of water then slosh it as hard as hope your car will launch. You might want to wear waders cause your gonna get real wet. now imagine all that sloshing oil gets into a spinning crank and gets thrashed and whipped into a froth. Scrapers help but they are an indirect route to the pickup.
I ran tricked out wet sumps with accusump backup, but they were marginal at best. Put a dry sump in it and forgot about it. Dude you are building one of the coolest badboy Pontiacs out there. You'll be launching and initial accel at 3G's Don't go cheap here. Too risky for your engine, your car and your safety!
Good luck with your car, It looks amazing!
Old 04-23-2017, 06:05 PM
John Langer's Avatar
John Langer John Langer is offline
If you "have" to go dry sump, it's because you have other issues inside of the oil pan...
Old 04-24-2017, 09:22 AM
Tom Vaught's Avatar
Boost Engineer
Can't disagree on that point, just easier for a lot of people to remove a given amount of oil and put it in a container designed to remove the air and then pump it back into the engine vs having the knowledge to design a pan that will minimize air mixing with the oil, oil running away from the oil pick-up on acceleration and braking, and oil over-temp issues on a given amount of oil vs pumping oil thru a oil cooler (air or water cooled) to a larger volume remote reservoir.
Dry Sumps take more hp typically from the engine but have other benefits as mentioned above.
Not everyone is a John Langer, especially in the Pontiac World.
Tom V.
Old 04-24-2017, 10:29 AM
It is not just the oil pan. It is also how you drain the oil back, bulkhead mods, crank mods, bearing mods etc...
Old 04-24-2017, 01:13 AM
Stan Weiss's Avatar
Maybe you should talk to John Marcella about why those 414 cfm heads pulled 1000 more rpm than someone else's 408 cfm heads will on a 566.
Stan
Pontiac Pump Gas List
Old 05-02-2017, 06:00 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Stan
I shift my new 540 at 8200.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 04-23-2017, 07:42 PM
There you go have Langer build you an oil pan!
Old 04-24-2017, 12:09 PM
P/S, F1,IRL and Comp run dry sumps. Even Big Chief! They all have the mods done to every component. By the time you add external drain backs you've paid for some plumbing for your drysump. You can size the pressure stage to your needs. The scavenge sections do not make any appreciable psi so they add negligible loss. How much more power do they take? Not much, you can prime your engine with 1/2 hp electric drill motor.
Old 04-24-2017, 12:16 PM
Stan Weiss's Avatar
My question for John would be .Does the class he runs legally let him run a dry sump?
Stan
Old 04-24-2017, 01:06 PM
Stan
Yes 5% of the engines cid in pounds. It isn't worth the weight for the added hp. Additionally it isn't worth the additional 50+'pounds on the nose.
Old 04-24-2017, 03:56 PM
cgeise's Avatar
cgeise cgeise is offline
That class has more rules that the Betty Crocker cook off -- for most guys the 20 some pounds is a cheap price to pay for some engine Insurance.
Old 04-24-2017, 12:11 PM
Tom Vaught's Avatar
Boost Engineer
Good Info from everyone. Thanks
Tom V.
