Probably a stupid question , but the fan is turning the right way? and pulling correct?
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
It has been really hot here, but this thing ran these temps when it was cooler too. It's definitely pulling heat out of the rad. The controller works as advertised. It comes on slow speed until it heats up, then it runs on high. It never wavers off high speed though, since I have the cut in speed set for 180 or so, and it isn't able to cool it down that far. As I said, regardless of thermostat rating, no thermostat etc., it'll run 195 all day sitting still. It's when it's moving is when it creeps up. Exactly opposite of what it did with the mechanical fan. Even the low/high temps are the same! Today, I got caught in a thunderstorm, and it was POURING (my poor car!) and it ran at 195 during the rain. As soon as it stopped, it crept up quickly to 210. I pulled in my driveway, let it idle a minute, and the temp was coming back down. Mixture is good too (I run an LM1 all the time). I have to recheck my timing...... although the odds of it slipping at the exact time I changed the radiator and fan is like winning the lottery. |
Lower hose collapsing??? It sounds like it should cool better than it does.. Vacuum leaks? Carb tuning? In the rain it should be ice cold!!!
Video??
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
It might be the lower hose..... I put a spring in it, but maybe it's still collapsing...... That would make sense.........
I want ya to try something if u can? Jet up your primary about 3 sizes, on your middle carb since that is the one u drive on correct? don't care what the meter says, I was using my meter earlier this spring and it said i was rich at cruise so i went down 3 sizes and sure enough it ran alot hotter! put them back in right back to normal.It was only like 65-70 sunday morning and my car stayed at 170-175 all the way to the track(about a 1/2 hr drive) fan didn't even need to be turned on! give it a try and report back
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's Last edited by grandville455; 07-29-2010 at 07:11 AM. |
Thanks Gville, but that isn't it. It would cool down at cruise on these jets with the mech fan. I run 69 (holley) in the winter, and 68s in the summer. It's in the high 13's at cruise right now.
It has to be something with the new radiator/fan setup. These are my thoughts. The Griffin simply doesn't have enough capacity for the engine (not likely, as others are running the same one with no issues) or The fan is blocking too much bypass air at cruise. or The lower hose is collapsing at rpm. or The water pump isn't pumping enough , and it was masked by the old Rodney Red (maybe it was larger than the Griffin?) It's not the end of the world. It is not overheating, and is still running in the same operating range that it always has. It's just that I wanted the electric fan to keep it from creeping up at idle. I never thought it would reverse the issue. |
Well mine runs at 180 in 80-89* and 190-195* in extreme weather. If it is in the 70's forget about it. The car runs at t-stat. So for you to be running at 190 in the driveway and them creep up when moving is odd. I would start from scratch. Look at everything. I would even get a laser gun and see what the temps are at the top inlet and the bottom outlet. I know that mine is at least 30* cooler going into the engine. The difference from the taurus to Mark VIII is almost nothing. The car SHOULD be running cool. I will look over the posts to see if anything sticks out. Rad cap pressure??
Ok well I just know mine showed high 13's to to even high 12's with that meter too and it ran alot hotter cruising... thats when i put back the 75's in the primary of my 850 Holley
You do have the cast impeller water pump? and not the stamped POS!
Cast impeller..... from the get go....... As much as it pains me to do so (I am tired of draining the thing every few weeks!), I am gonna pull the water pump and check the clearances again. When I put the engine together, I made the plate touch the impeller without a gasket, so the clearance is that of the gasket, I'm guessing 1/32 to 1/16"?
My LM1 appeared pretty accurate. When I was jetting the center carb, if I got right to 14.7 or higher, I'd get that lean stumble at cruise speed. One jet size larger and it was fine. Neither made the slightest readable difference in the water temp though FWIW. Like most Pontiac folks, I watch that gauge like a hawk....... and the bottom line is that the current jetting was fine with the mechanical fan. This is the story of my life with this engine and I've been struggling with it for almost 5 years now. And I can say that NO expense was spared in trying to solve it. |
Is this an automatic? I read that a guys transmission was making his engine run hot because the tranny fluid was way to hot going into the rad.
I see that you have aluminum heads, can you run more initial timing with out detonation?? Spark plug heat range? Brakes dragging while moving? Underhood temps too high? My car is 30* cooler on the gauge with the hood off. Obstruction in front of rad? Are you missing the nipples in the timing cover from the water pump plate to the back of the cover? Water Wetter? Makes a difference... I know that some of these are DUH!! But a fresh set of eyes solves more problems than you think. Plus when you drain the car enough to get it down blind folded, then we can talk. I can not remember how many time I drained mine!!!! PLEASE POST PICTURES!!!!!!!!!!!
67T,
Thanks.... If any of those things were an issue, I think they'd have shown up in the 13,500 miles I drove the car with the mechanical fan. Nothing but the fan, radiator, alternator and lower rad hose have been changed (other than me trying a different thermostat/no thermostat. The reversal of the issue came about right when I changed those things. As much as I hate to say it, I think I'm gonna put the mech fan/shroud back on and see what it does. At least that will eliminate one major thing that I changed. I posted a few pics. What else are you interested in seeing? |
Water pump, t-stat. IDK just pictures i guess. Odd issue you are having. Curious as to what can be the issue.
Hmmm.........
It's definitely not the thermostat. I tried several and even removed it entirely. There was no difference at all in the way it acted.
Maybe the water pump is messed up in some way. It's been on there for 5 years..... |
well i just got back from testing my dual fans and had to have it on high all the time, came back put the lincoln fan on went for a drive samething! i was like wtf?..well i hooked up my factory gauge a couple of weeks ago i look at that one its not even close to 195 like the auto meter one says. so i turn the fan off when i get home just letting it idle in garage ,autometer starts creeping to 210 factory not even close as thats the middle on my gauge! take heat gun 165 at thermostat housing tap the auto meter gauge drops right away to 195 still too hot according to gauge, but something is funky there, also my sending unit top spins, i dont think thats normal?..so i will be ordering a new sending unit and then seeing what happens, but why that gauge would drop to 195 from 210 is beyond me if the sending unit is bad!...just something for u to think about or look at also ok!
good info here! http://www.autometer.com/tech_faq_an...x?sid=1&qid=57
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's Last edited by grandville455; 07-29-2010 at 08:38 PM. |
My mechanical Auto meter reads high some times tap it and it will go 10* cooler sometimes. 5*'s other times. I am seriously thinkng about going to another gauge.
Autometer or other but electrical..
Maybe I am chasing a friggin gauge error...... I have an autometer too.... I need to check the water temp with a meat thermometer.....
Yep U need to verify what the gauge is telling. Did u read that article? u have a electrical one?
I should take a video. I was driving home last night after a cruise. It was 190* downhill at 60~ish outside. I tapped the gauge and it went to 165*. So I know that I need a replacement.
Should I go electrical? Or is mechanical the way to go??? Thanks Dave
I just got off the phone with auto meter, and he said electrical is by far the most accurate, also said if your tapping on the gauge something inside has gotten funky or out of whack! I have a new sending unit coming tomorrow to try first se if it gets any better. U have your gauges inside the car don't you? Mine see's water at times from driving in a rain storm or when i wash the car. U may have to send it in to them he said its free to look at it other than shipping
