Old 05-04-2011, 03:28 PM
GaryK's Avatar
GaryK GaryK is offline
Default MY 62 Tempest Daily Driver
Almost done with my 62 Tempest daily driver. Here are some before and after shots of the car. It has a 4 cylinder 1 bbl auto trans with 3:08's. Going to show it for a while before I put into daily use.
ID:	243382   Click image for larger version
Name:	DD62TEMP AFT FT.jpg
ID:	243383   Click image for larger version
Name:	DD62TEMP AFT RR.jpg
ID:	243384   Click image for larger version
Name:	DD62TEMP MOTOR B4.jpg
ID:	243385   Click image for larger version
Name:	DD62TEMP MOTOR AFT.jpg
  #122
Old 05-04-2011, 09:28 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default 62 driver
Gary,
Looks like you upgraded the master cylinder. Did you go with disc brakes? Nice looking car!
Jerry
  #123
Old 05-05-2011, 09:33 AM
GaryK's Avatar
Originally Posted by c5farmer View Post
Gary,
Jerry
Thanks Jerry!! The master cylinder is from a 72 AMC Gremlin 4 wheel drum brakes all around. No plans to convert over to discs yet.
Gary
  #124
Old 05-05-2011, 06:11 PM
pontiaclady's Avatar
pontiaclady pontiaclady is offline
Gary,
It really looks great - especially when looking at the before and after !!
Pontiac Addict
66 GP 421-TriP/auto - purchased for $75 in 1978
65 2+2 421-TriP/auto
61 Tempest 2 dr Coupe - survivor
64 GP - work in progress
71 GTO Convertible - in 1000 parts
and 69 Firebird
  #125
Old 05-10-2011, 04:35 PM
R 70 Judge's Avatar
A little progress in the chassis shop
BTW - the mid-plate is being modified and adapted to a BOP pattern.
ID:	243941   Click image for larger version
ID:	243944   Click image for larger version
ID:	243946   Click image for larger version
ID:	243949   Click image for larger version
James
1970 Trans Am
  #126
Old 05-10-2011, 04:40 PM
R 70 Judge's Avatar
Here's how you trick your unibody car into thinking it has a full frame
This car will still retain it's full factory interior as well.
ID:	243951   Click image for larger version
ID:	243952   Click image for larger version
ID:	243953   Click image for larger version
ID:	243954   Click image for larger version
James
1970 Trans Am
  #127
Old 05-13-2011, 07:14 PM
blueghoast's Avatar
Is this welded to the subframe
Qiurios how you've attatched this to your sub frame.
On my 62 I used 2x2 square tubing inside the sub frame
on the top side, I like how yours looks too.
  #128
Old 05-14-2011, 07:58 AM
GaryK's Avatar
Originally Posted by pontiaclady View Post
Gary,
Thanks Pontiac Lady!!
  #129
Old 05-17-2011, 09:05 PM
R 70 Judge's Avatar
The bars are bent to the shape of the subframe and welded.
James
1970 Trans Am
  #130
Old 05-19-2011, 03:41 PM
pontiac rodder's Avatar
pontiac rodder pontiac rodder is offline
Default Injunnuity IV
Started last November Off to the track tonight
ID:	244853   Click image for larger version
ID:	244854   Click image for larger version
ID:	244855   Click image for larger version
ID:	244856   Click image for larger version
  #131
Old 05-19-2011, 04:03 PM
R 70 Judge's Avatar
Nice car! Details of the build?
James
1970 Trans Am
  #132
Old 05-20-2011, 02:09 PM
Arizona car it has a 8.50 cert ,ford 9 inch with 4:10 gears, on a 9 inch slick. Fresh built 461 with Wenzler heads and tunnel ram 2 800 Edlbrock carbs tubo 400 T brake (4500 stall) The car has a full interior Glass hood and trunk lid and glass bumpers.
Made a few shake down passes last night foot brake only went 12.90 12.60 last pass 10.71 with a lot more left in it Just need to get seat time as it is new to me.
I want to run N/SS and I think it turned out pretty close.
  #133
Old 05-20-2011, 03:30 PM
R 70 Judge's Avatar
Very nice. Do you have any interior and underside pics? Any idea how much it weighs?
James
1970 Trans Am
  #134
Old 05-20-2011, 05:56 PM
OldS-man OldS-man is offline
"went 12.90 12.60 last pass 10.71"
I bet that got few looks. nice looking car.
I see you are from Wisco. are those heads out of John Stolpa's shop?
  #135
Old 05-21-2011, 08:04 AM
I'm not sure I know John Stolpa. Wayne from Shicantek Performance built the motor and C&S performance rebuilt the heads for me.
  #136
Old 06-01-2011, 02:29 PM
fasteddy's Avatar
fasteddy fasteddy is offline
Default My 63 finally goes to work
Drove it to work today. Been a fun project. 195, 4bbl, high compression, 3 speed, original body color and interior. Now to get my Cameo White Lemans finished.
Name:	Car 1 05-31-11.jpg
ID:	245884   Click image for larger version
Name:	Car 4 05-31-11.jpg
fasteddy
  #137
Old 06-01-2011, 02:39 PM
mechanickeith's Avatar
Thats a great looking car. Love the big back window cars.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #138
Old 06-01-2011, 03:58 PM
fasteddy's Avatar
Thanks Kieth. This little car is a blast to drive. I put the 4GC in the trunk and put a 400 CFM AFB in its place. That helped the response quite a bit.
fasteddy
  #139
Old 06-01-2011, 07:49 PM
Thats a great carb for the Tempest 4 cyl motor. I have ran the 4gc, an afb, a 390 cfm Holly & even had a Q jet off of a sprint motor on one for a while just for kicks. By far the Carter AFB was the best. I even ran a set of side draft Webbers for a while. Ran like a raped ape!! Just couldnt keep them in tune. I am guessing due to the vibration.
What year LeMans?? Interior color??
Keith Collier
Tech advisor
POCI.org
  #140
Old 06-02-2011, 01:45 PM
GaryK's Avatar
I am having problems with my 4GC and was going to have it rebuilt. Maybe I should just replace it, where did you get your AFB?
Gary
