Old 07-10-2015, 11:50 PM
ta man ta man is offline
How fast is your buddies 555 BBC?
Actually not much faster...
  #122
Old 07-11-2015, 09:53 AM
chuckies76ta's Avatar
Just a thought as was mentioned. Monitoring Air/Fuel with both intakes.
Charles
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
  #123
Old 07-11-2015, 11:18 PM
Originally Posted by ta man View Post
All this testing may come to an end soon,I've decided to make the best of my engine combo.The 3.08's are great on the highway...but I really want now is to push into the 10's...and really give SD's head cam combo what it deserves..plus I want to lay a spanking on my buddy with his 555 BBC on 110 octane !
I'm sticking with the 3.08's,I already have my buddy beat as far as street cars go,I have 93 less cubic inches,I run pump gas,I drive to the track and run almost as fast.I took the car out for a good drive yesterday..and made my mind up.I have a few ideas how to drop a bit of et.
  #124
Old 07-11-2015, 11:19 PM
Charles
Excellent plan...
  #125
Old 07-13-2015, 01:55 AM
68blackbird's Avatar
68blackbird 68blackbird is offline
Do tell... After all. I don't think he's on this board
Rich
68 Firebird 400, #16, xe274, street dominator, 850 DP, hooker headers, t400, 3500 stall, 3.73, 295/65 bfg drag radicals... best 13.27 @ 102.8, 1.90 60ft
  #126
Old 07-13-2015, 07:44 PM
Rich
Doing a few little mods,taking a bit of weight off the front end,reducing rolling weight,adjusting intial timing,finally port matching my torker 2 for a start..
  #127
Old 07-20-2015, 06:33 AM
Any updates?
Charles
950 Quickfuel.
  #128
Old 07-20-2015, 07:46 AM
No real updates yet..I've ran the performer rpm a few weeks ago...its in the other thread...I'm presently doing a few tweaks..hoping to knock down the et and raise up the mph.Goal is another 11.3x timeslip this year at 120...first one was wind and weather aided..
  #129
Old 09-14-2015, 12:55 PM
Weather permitting finally hitting the dragstrip Saturday,and a few more times this year.Just installed a Hughes th 350 with a low first gear set,seems to work good!Replaced front wheels with 15x4's and tires with M/T 165/85/15,dropped 7 lbs each side ,replaced 40lb battery with a Braille 2015 15 lb battery(works great),removed rpm intake and replaced with my Torker 2 which is finally port matched.Also replaced rear wheels which had quite a wobble to them...With good traction and decent air..should run in the low 11.3 range maybe quicker.
  #130
Old 09-14-2015, 03:47 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good luck!
Go fast, see Elvis!
  #131
Old 09-14-2015, 06:35 PM
69FIREBIRD76MM's Avatar
Sweet. You got a great combo there, good luck.
  #132
Old 09-14-2015, 07:36 PM
grandville455's Avatar
grandville455 grandville455 is offline
Ernie, your 350 now has a 2.75 gearset? Should be interesting, changed a lot of stuff!! Good luck man!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
  #133
Old 09-14-2015, 07:50 PM
Yes different tranny altogether...did a few test runs on the street works good...,gasket matching and blending my torker 2 this week...also found my vacuum port plugs weren't flush with the top of the inside of the runners,have made all three almost flush,and will be when I'm finished.
  #134
Old 09-22-2015, 03:59 PM
Went to the track Friday...had to test the port matched Torker 2 and new transmission under full power with a timeslip...Track was not prepped and very slippery..spun hard after initial launch..ran a 11.6780 at 120.37,60 ft was 1.7619 with a hard spin ...pretty content with that...mph was even with the best ever..tranny worked fine,shifted quick,engine is much happier again with the Torker 2 back on...Heading to Grandbend Motorplex Friday on a much better track..see how it does.Car should 60 ft in the low 1.6's with the 3.08 gearing and 28 tall tire..
  #135
Old 09-22-2015, 09:07 PM
PAUL K's Avatar
Thanks for the update.....do you think traction issue was strictly track related, or do you think the steep gear set may have been to blame?
Go fast, see Elvis!
  #136
Old 09-22-2015, 09:25 PM
Track for sure ..had four hours of rain during the afternoon..very minimal track prep for evening...
  #137
Old 09-23-2015, 08:21 PM
wheelspin's Avatar
Arrow Works for me too...
Hey Ernie,
Thanks for your extensive testing and feedback, particularly your success with using a 3200 stall verter and a 3:08 gear . My tight 10" Continental works great with the tall gear and I dropped 300 rpm @ 75 over my old 3:42 gear in my 550hp TA with no detectable change in acceleration .
Les Iden
  #138
Old 09-23-2015, 10:46 PM
Originally Posted by wheelspin View Post
Hey Ernie,
Thanks...just trying to help out...works great on the highway doesn't it!
On a side note..my new tranny as recommended by the builder uses Type F...I flushed my convertor,cooler and lines to insure no Dexron left...and I swear my trap rpm is down slightly..not like it was an issue.I wonder if the Type F has tightened up the convertor slightly...?
  #139
Old 09-25-2015, 11:56 PM
Did testntune last night at Grandbend Motorplex ran three times..11.408 at 119.96 with a 1.731 60ft,11.457 at 118.82 with a 1.718 60 ft and a 11.435 at 118.73 with a 1.714 60 ft.
Last two runs were into a good headwind..pretty content with the times with the soft 60ft...a bit of fine tuning could drop the 60ft times.My fuel pressure also now drops to 3 lbs by half track which is an issue.
I did manage to outrun my buddy's Chevelle..we were betting on best timeslip for the night...he ran in the 11.5's with one slip at 11.45.He is 555 cuinch 110 octane 3.73 gears...
  #140
Old 09-26-2015, 12:00 AM
Thumbs up
Very nice.
