Industry Stuff new repro's, updates, other info.
Old 06-16-2013, 08:42 PM
richmas5 richmas5 is offline
Just a made in the USA part,oh that's right I forgot every American is lazy,or wants too much money to make the part,I don't understand GM if they had all the original dies and tooling,they should have made all the reproductions,they would have made a killing,maybe I am missing something
  #1402
Old 06-17-2013, 07:55 AM
Dstransam's Avatar
Dstransam Dstransam is offline
how about this, since they repro the rear tail panel and the inner lower tail, lets see someone make the little panel that connect the trunk drop off with the inner lower tail panel. Mine were tore up so bad i had to make them, it sucked.
  #1403
Old 06-17-2013, 11:57 AM
Dave R's Avatar
Dave R Dave R is offline
I think GM never understood the parts business. They seemed eager to pull parts support as soon as possible - 10 years was standard. On some parts, the price was often stupidly high. Some NOS parts today aren't even bringing what GM was charging for them back in the 80's.
  #1404
Old 06-20-2013, 11:10 AM
twotone '64 twotone '64 is offline
On the tripower equipped '64 - '67 GTOs (probably several other apps as well) there's a vacuum check valve at the front carb which is needed if the original vacuum operated secondaries are used. I know most guys just go to mechanical secondaries, but it would be nice to be able to get the parts to bring it back to original design. The check valve would be as easy to make as the one for the brake booster, so it should be relatively inexpensive.
  #1405
Old 06-21-2013, 11:45 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
Make the plastic base for the lamp holder in the fancy dome lights.
http://forums.maxperformanceinc.com/...d.php?t=729406
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
  #1406
Old 06-30-2013, 10:07 AM
67cruiser 67cruiser is offline
Default 15 and 17 inch Hurst wheels would be nice!!
Love to see these repod,ed
  #1407
Old 06-30-2013, 01:14 PM
njsteve's Avatar
njsteve njsteve is offline
Default the 1972 Thermostatic purge valve #3026085
http://www.ebay.com/itm/NOS-1972-Pon...699e0e&vxp=mtr
This emissions control valve came on every 1972 Pontiac V-8, regardless of performance level. You are already making the 1971 version so you have all the metal parts done. Just make the top that fits it for 1972 and we won't have see crazy prices like the one in this ebay ad any more.
I have an original (cracked) one you could borrow.
ID:	328124   Click image for larger version
ID:	328125   Click image for larger version
ID:	328126   Click image for larger version
ID:	328127   Click image for larger version
The Following User Says Thank You to njsteve For This Useful Post:
  #1408
Old 07-01-2013, 07:33 PM
hondo237 hondo237 is offline
I LIKE TO SEE 1971 LEMANS FENDERS LH AND RH
  #1409
Old 07-02-2013, 10:13 AM
1beautifuldaughter 1beautifuldaughter is offline
1971 gto front grill pot metal chrome surrounds would be awesome, because the re chroming process would likely ruin an original, I think they would sell, and go over very well if reproduced nicely.
  #1410
Old 07-08-2013, 04:36 PM
Rick Briggs Rick Briggs is offline
Frt & Rr bumpers for 71 GP
Radiator Support for 71 GP
To really reach .... hood for 71 GP, if not metal fiberglas
  #1411
Old 07-08-2013, 04:43 PM
Yaw and the 71 GP gas tank.
  #1412
Old 07-13-2013, 06:56 AM
Sanduners's Avatar
Sanduners Sanduners is offline
Default 63 Tempest front valance
The 63 front valance and the convertible windlace end caps would be nice.
  #1413
Old 07-13-2013, 04:35 PM
Jazz's Avatar
Jazz Jazz is offline
The Rear Metal Package Shelf would Be WONDERFUL ! !
"Whatever" It Takes, We're Coming In !
  #1414
Old 07-13-2013, 05:56 PM
Tooling wears out. In restoring this Trans Am I noted that the control arms had very rough edges, indicative of worn stamping dies. GM junked the tooling pretty much as soon as the 81 left the line.
  #1415
Old 07-15-2013, 06:32 PM
Blk12wls Blk12wls is offline
There seems to be a lot of interest so I'll try to get everyone up to speed on sheet metal. I worked at GM in body stamping for decades in the tool and die dept. GM kept old dies that had product demand, from dealers. The dealers would order parts and when they had a big enough order to make a run they would, usually in the summer. These were flame hardened tools on the working surfaces so they lasted indefinitely. I ran 69 GTO convert quarters in 1989. 68-69-70 Firebird quarters too. By the way, the Camaro and Firebird convert quarters were made with the heaviest guage metal ever used in a body die, bar none. Those run in the later years all have zinc coating on both sides and are rust proof.
Any part can be rerun today. Original tools are gone. They are either in the hands of a licenced after market supplier that can meet same quality or they have been scrapped. In that case, semi hard tools, kirksite, can be cast and finished to the original tools. It's a bit costly but not impossible. You need enough demand to ammortize the cost affordably. Many parts are made this way. With CAD it's getting cheaper all the time. Scan a fender and cut the same day. Hand finish and stamp. It's all about demand.
Richard
  #1416
Old 08-04-2013, 08:41 PM
mgoblue mgoblue is offline
Default Heater Core that can be installed from a service standpoint
I have a 1969 Firebird, but this probably applies to many makes. Heater cores were installed at the factory seconds before the blower motor case (and well before the installation of the fender). There was plenty of room to pass the pre-bent tubes (inlet and outlet) of the heater core thru the firewall. But as a service part, this is a nightmare. The blower motor housing covers up a potion of the holes in the firewall that the tubes pass thru making it (in my case) impossible to install a new heater core. This is the rare time when it really does not make sense to make the reproduction exactly the same as the original. I understand the reason the tubes have a bend, but maybe it doesn't have to have the full bend or maybe there is some other solution that involves a heater core with straight tubes and then some type of attachment of other tubes on the firewall side. Right now I'm forced to run a bypass until I figure something out ....really don't want to butcher my firewall or take the hood and fender off.
  #1417
Old 08-04-2013, 09:30 PM
mgoblue, you might try carefully unbolting & dropping the inner fender, realize the front bolts can be stubborn. I always spray them down with Kroil or PB blaster before taking on such a task.
  #1418
Old 08-04-2013, 09:52 PM
Thanks 'ol Pinion Head, I may give that a try. Are you suggesting that by dropping the inner fender I can get more access to remove the blower motor case (or at least pull it back a couple inches from the firewall). If I can get the blower motor case off, then installing the heater core becomes much easier. Right now, there are two speed nuts under the fender that I cannot get to.
  #1419
Old 08-07-2013, 04:05 PM
Willshire's Avatar
Willshire Willshire is offline
Default 64 b-body lenses
parking lens,back up lens, tail lens, especially for the GP
It's hard to soar like an eagle, when you're surrounded by turkeys!
My wife says she'd llike my car a lot more if it wasn't mine.
64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam.
  #1420
Old 08-08-2013, 06:23 PM
Bigcat's Avatar
Bigcat Bigcat is offline
Remake the 1965/66 catalina 2+2 quarter panel emblems only ones you don't reproduce guess the company you had making them went out of business let's get sample emblem get going on reproduction if some body wanted to clone a catalina can't do it I am purist but to each there own just nice knowing you could order them with out paying through the NOSE!
